Question about House Brand Computers & Internet
NERO / JET AUDIO CANNOT FOR ROM DRIVE
NERO / JET AUDIO CANNOT FIND MY ROM DRIVE
  • 696 Answers
Thanks for coming to FixYa, The problem you have is either a well documented software problem, a damaged Nero install or a failing drive.
Click the below link, then scroll down and click the "Fix It" button. Follow the onscreen instructions, restart when it's done and see if your drive re-appears. If it does, you're done, if it doesn't work then try uninstalling and re-installing Nero, again if that fails then your drive is most likely failed and you should replace it.
www.microsoft.com/kb/341060/
Hope this helps FixYa,
Chris
Posted on Jul 18, 2009
Unable to copy music to cd by using nero7
First you need to locate your music/audio. If it was downloaded from Limewire/Frostwire the default location would be C:\Documents and Settings\**Your Username**\Shared
You can also access your music/audio through Limewire/Frostwire, by going to your Library, then highlighting a file that you want to burn and press explore. This will open the folder containing the highlighted file.
Alternatively use the search to search for something you know is in the folder you want to access or eg. search for the extension of the music/audio you want to burn.
First it may be worth mentioning that there are two ways of burning audio in Nero 7. Using Nero Express or Nero Burning ROM (The original Nero program). I find both very simple to use, but prefer Nero Express, so That's what I will use here.
First open Nero StartSmart:
Pressing add is not necessary. You can also open folders outside of Nero Express, and then you drag and drop the same way.
You can make mp3 disks using Nero Express as well. Just choose make Data Disk instead of Audio CD in Nero StartSmart. The only difference you will see is that instead of minutes you will be adding size (MB)
In case you run into playback issues when using Nero Express, then you have two options. You could try using Nero Burning ROM. Raaf explains here how to do that with Nero 6, but Nero 7 is very similar:
Burning a (audio) CD from your MP3's (Windows)
Another way is to run a tool called CD/DVD Drive Speed (can be found in Nero StartSmart under Tools, where you let Nero burn test disks for checking the best speed for this type of disk.
Aug 03, 2012 | Ahead Software Nero 7 Essentials Suite...
Combo drive reads cd but not dvd
Hi ,it could be that your dvd is dirty,scratched or corrupted.Try your dvd in another computer to see if it is ok .If you use Nero Burning Rom go to your Start menu.a All Programs ,Nero.In the sub menu Click on Nero Tools and select Nero Info Tools and see what that brings up.Hope this helps you.
Regards Bill
May 26, 2010 | LG (GCC4522BK) CD-RW/DVD-ROM Combo Drive
How to test if a dvd burner is wore out
Hi, if you are using Nero Burning Rom, go to Start/All Programs, Click on Nero Burning Rom,and in the sub section click on Nero Info Tool and see what that brings up.You could also try and clean your drive as dust and dirt can stop it from working.
Regards Bill
Feb 24, 2010 | Computers & Internet
Nero problem
You should reinstall your nero software and DVD/ Writer should be on master and CD rom shoul be slave. Then it will work at all.
Thank You
Jul 30, 2009 | Sony Optiarc AD-7170S Burner
My cd rom won't detect blank cds
try re-installing your burning software ( nero-Roxio et,c )
Does it play a standard Music/Audio CD.
if not un-install and re-install the drive.
Are the cables to the drive connected correctly ?
Does the drive support CD+ And CD- media ?
Are the cds definately Blank, any small amount of data written to them, after failed burn attempts will not show the disk as being empty.
Mike @ Compurepair.
Jun 13, 2009 | Dell Computers & Internet
Dvd rom wont detect any dvd movie or an audio, but ther is a cd rom drive found in my computer.. windows xp2 my os...
purchase a new dvd drive ( the laser lense in the dvd drive you have now has died or burnt out ) and you cant fix it yourself.
May 10, 2009 | Computers & Internet
Can't find burner for windows vista
Here's a list I found online. I personally recommend Nero but anything on that list will do.
* AnyDVD v5.3.2.1 (32 Bit)
* AnyDVD v5.9.4.1 (32 Bit)
* AnyDVD v5.9.6.3 (32 Bit)
* AnyDVD v6.0.0.4 (32 Bit)
* Ashampoo Burning Studio v5.51 (32 Bit)
* CloneDVD v2.8.4.1 (32 Bit)
* CloneDVD v3.6.0.0 (32 Bit) [NOTE: All works, but the box of Audio and subtitle selection don't show the content of DVD!]
* Daemon Tools v3.33 (32 Bit) [NOTE: Works perfectly.]
* Daemon Tools v4.0.3 (32 Bit) [NOTE: New version runs perfectly.]
* DVD Decrypter v3.5.4.0 (32 Bit) [NOTE: Displays error on close, but burns no problem.]
* DVD Shrink 3.2 (32 Bit)
* Frog ASPI v0.29.4 (32 Bit)
* ImgBurn v1.3.0.0 (32 Bit)
* InterVideo DVDCopy v3 (32 Bit)
* Gamejack v4.0.0.590 (32 Bit) [NOTE: Two virtual drives included.]
* Gamejack v5.0.3.3 (32 Bit) [NOTE: One virtual drive included.]
* Nero Burning ROM v5.5.10.5 (OEM) (32 Bit)
* Nero Burning ROM/Ultra Edition v6.6.0.14 (32 Bit) [NOTE: Nero Express crashes, but Nero Burning ROM works perfectly fine.]
* Nero Burning ROM/Ultra Edition v6.6.0.16 (32 Bit)
* Nero Burning ROM/Ultra Edition + OEM v6.6.0.80 (32 Bit)
* Nero Burning ROM/Ultra Edition v6.6.1.4 (32 Bit)
* Nero Vision Express v3.1.0.08 (32 Bit)
* PowerISO v3.2 (32 Bit)
* Roxio Easy Media Creator v7.5.0.47] (32 Bit)
* Sonic DVDit Pro v6.0 (32 Bit)
* StarPort v2.6.1 (32 Bit) [NOTE: Includes working virtual CD/DVD drive!]
* UltraISO v7.6.5.1269 (32 Bit)
* Virtual CloneDrive v5.1.3.1 (32 Bit)
* Virtual CloneDrive v5.1.4.5 (32 Bit)
Mar 20, 2009 | Computers & Internet
Nero burning on cd writer
use this tool to reset the cd in the registry
after you run the file - reboot the computer -
http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
Oct 08, 2008 | Compaq Presario 1200,1600 (297657-001)...
Nero cr-rw burner install
is your hard drive the master on the primary cable? You shouldn't need a digital audio cable unless you want digital audio. Are you using Nero software witht he drive? may have to re-install the software, or better, uninstall it, clear the registry with CCleaner (free download on the web) and then try a fresh install.
Dec 13, 2007 | LG CED 8120B CD-RW Burner
CD-RW/DVD-ROM BURNER
if you wish to burn cd's which is your burner then you need a software called nero burning rom or any other burning software that lets you burn data or audio cd's or vcd's to burn with if you wish to burn dvd's then you need a dvd burner combo drive which lets you burn dvds
Aug 11, 2007 | LG GCC-4241N CD-RW/DVD-ROM (Combo) Burner
Computers & Internet Logo
81 people viewed this question
Top House Brand Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a House Brand Computer and Internet Expert? Answer questions, earn points and help others
