On my monitor it is showing some waves... picture is not clear.. showing some lines(less darken)
    Scholar:
  • 50 Answers
If it is a flat screen monitor: you should try different monitor resolutions and refresh rates. Specifically, you should set your resolution and refresh rate to the specifications set by Sony. You can also use the "detect displays" button in the "display" system preferences.
If it is a CRT: Try the above, but also try "degaussing" your monitor. This is a command on the monitor itself, and it's location depends on the brand / model. turn on the On Screen Display menu and look around for it.
Posted on Jul 24, 2009
Full screen of vertical colored lines, What do I need to check?
Disconnect from computer and try it on another.
might be a video card issue, disconnexion will show if this is the problem. Does it do this when the computor is off?
If it is not a computer issue then try resetting to factory default.
It might be that the screen is going but this is usually evidenced by loss of picture or darkening rather than vari-colour lines
please amend and resubmit query
May 28, 2015 | Hyundai L70N 17" LCD Monitor - 16 ms 1280...
What can cause the tv picture to have waves lines
Sounds like this may be electrical or magnetic interference. could be flouresent lights or maybe a elec. motor running on the same circuit as the TV.
May 06, 2014 | Televison & Video
My problem is that with this monitor I have noticed that there is a red line that moves up and down the screen - in a random manner. I thought that the line only showed in the background but it also...
With this I would normally tell you that you have a dead pixel and you need to return the monitor to the supplier. But it is very strange that the line moves.
Dec 17, 2012 | LG 22" FLATRON LCD Monitor
Vertical lines showing in picture, especially noticable on black
in these issue you can see vertical lines due to filter capacitors bad in the secondary power supply. 100micfarad/j35volts, 220microfarad/25volts.
Jun 09, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Picture ok,waves show run left to right
CHECK THE MENU FOR OPTIONS ,,CHANGE ALL JACKS AND CONNECTIONS,,
May 15, 2009 | Sony Televison & Video
When i switch the moniter on i see faint lines running up my moniter ( very faint ) as if they are some kind of interference lines, my colleagues are using the same screen on the tables next to me but have...
Hi this shows your monitor has a interference by:
1) by screen refurbish frequency you may try to change this frequency from PC, go to screen setting go high level setting click monitor and change the frequency to 70(or other than 60) ,also you may try from your monitor.
2)stil trouble there, your monitor has a problem with power supply,
the capacity wave filter not very good condition. need to change 5V wave filter capacity (two),should be solved.
Dec 22, 2008 | HP L2208W Monitor
White corners SONY KDL52XBR6
This is called a dark shading error. All the LCD consumer sets have some visible degree of this effect. Some will be a little less or more than others even from the same batch in the assembly run. This has to do with the optical design quality of how the back-plane lamps illuminate the screen. The design and assembly tollerance of this area is very critical.
Normally, LCD screens don't show their best picture in a darkened room. The very black regions of the picture content may look a little washed out. LCD screens are best watched in a room that is lit, but not very bright. You have to consider that there is a powerful set of lights behind the polarized panel of the LCD display, and there will always be some breakthrough of light.
If you want a TV that is more like a CRT in its characteristics a Plasma would have been a good choice. The trade-off with the Plasma is that it does not have the picture sharpness of the LCD. A Plasma set is best watched in a darkened room.
If you have an LCD computer monitor, take a look at it in a dark room with a black screen. You will most likely see the dark shading errors. Only the very expensive production studio type LCD monitors have less of this error than the consumer sets, and they are not absolutely perfect.
Jerry G.
Nov 19, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Logitech webcam
in my view the hardware ciruit (IC) may develop heat that make this problem, change IC
Dec 26, 2007 | Logitech Webcam
Computers & Internet Logo
175 people viewed this question
Alun Cox
David Payne
David Payne
