Question about Nokia N70 Cellular Phone
N70 not charging
Whenever i connect the charger to my phone, it displays NOT CHARGING.
    Guru:
  • 125 Answers
Here is a generic solution for all mobilephones!
This problem could be caused by either battery, charger or firmware failure. you can try the following to secure which!
-Try your mobilephone with another charger or connect it to a PC using a USB cable
> if ok? the problem is your charger!
-Try your mobilephone with another battery
> if ok? the problem is your the battery!
-Try your battery and charger on another phone
> if ok? the problem is your mobilephone/firmware :(
If you dont have access to other phone, battery, charger or USB-cable you can at least try the steps below:
1. Turn off your mobilephone
2. Take out your battery, Sim-card and memmory-card
3. Connect your charger
4. Put the battery in
5. Turn on the phone
If it doesn't help, with a little luck! you should get a USB-cable, back yor phone up and reset it to factory default and upgrade your firmware/software on the phone to the latest version!
OBS! You should only do it with a fully charged battery! or you could damage your phone irreversibly!!!
Posted on Jul 12, 2009
  • einghel Jun 05, 2011
    thanks it helps a lot
N70 not charging
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Oct 10, 2013 | Nokia Lands Phones
Nokia n74 not charging
Hello My Dear Friend:
First Option:
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Jan 12, 2013 | Nokia N70 Cellular Phone
Nokia N70 no signal problem
First Option:
Second Option:
Jan 10, 2013 | Nokia N70 Cellular Phone
My nokia n70 phone does not charge even with new batery. pls give me an advise.
Hello, when a phone does not charge, it means that the phone charger or the port at which the charger is inserted in the phone is faulty.
Might be due to dust or dirt. You can Clean charging port on the phone with a brush and alcohol to remove dirt.
After cleaning it,if still not charging, you can test charger with another phone to be sure if the charger is working. And if charger works with another phone,that means the charging port on the phone is faulty and will need to replaced.
Take care.
Sep 15, 2010 | Nokia N70 Cellular Phone
Charging problem
hi :) have your phone has been water damage ?? most after water damage,phone mother board's charging piont will be pro,tat only way u can do,pls send to mobile shop for repair it.
Jul 08, 2010 | Nokia N70 Cellular Phone
When i charge my N70. the screen displays "Not Charging".. what should i do?
HI, IT COULD BE THAT THE CHARGER YOU ARE USING IS NOT COMPACTIBLE WITH THE PHONE, TRY USE THE CHARGER THAT CAME WITH THE PHONE.
Jun 01, 2010 | Nokia N70 Cellular Phone
N70 not charging
try replacing the charger or the charging point.
Nov 17, 2009 | Nokia N70 Cellular Phone
My Nokia N70 doesn't charge.
Either your charger port has got damaged due to moisture or your charger is not working properly. Go to the Nearest nokia care centre (service centre). They will solve your problem in seconds.
Jul 12, 2009 | Nokia N70 Smartphone
Charging
charger not supported can be a software problemor a hardware problem.in an case we need to take it to nokia centre.before that check with another charger weather it is giving the same error or not.this is one of the phones which supports usb carging as well so whenever ou connect a charger you dont see anything on display.but if the phone is completely dead it takes atleast 15 to 20 minutes before it starts charging.
Can be battery problem..
Thanks
Fame !
Apr 27, 2009 | Nokia 3110 Cellular Phone
Nokia n70-music isn't charging...
if the unit has really a software problem, the unit OS must be formatted and reinstalled with a new copy of OS..
Aug 16, 2008 | Nokia N70 Cellular Phone
Nokia N70 Cellular Phone Logo
647 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
Damen Wong
Damen Wong
