Question about MSI K8N Neo-FSR Motherboard
BIOS Setup Can't open BIOS Setup
    Problem Solver:
  • 5 Answers
Open the case and take out the battery and insert it after counting 30 second.. if the problem still persistent. may be the problem is related with battery itself.. replace that thing..
Posted on Jul 12, 2009
PC SHUTDOWN UNEXPRCTEDLY,SO I NEED TO UPGRADE BIOS.BUT HOW
Turn on the computer and immediately press the F10 key repeatedly until a BIOS Setup screen opens. If nothing happens, press the F1 key repeatedly. In the BIOS Setup utility, do one of the following: On the Main tab, find the BIOS version.
Oct 09, 2018 | Computers & Internet
So if i have a dell dv051, and i go in to the F2 setup utilities how do i set everything up?
Why are you in BIOS setup? Is their a problem? If you are in the BIOS setup and don't know, just leave it alone. If you alter the BIOS you may be opening Pandora Box.
Feb 04, 2013 | Computers & Internet
How to skip bios setup
F2 is your BIOS Setup enter key?
As SOON as you press the Power On button, start tapping on the F2 key.
Tap in 2 second intervals.
You may hear beeps. These are Stuck Key Error code beeps. You know what they are now, so just ignore them.
The BIOS Setup screen goes by F-A-S-T. You have a very small window of opportunity. This is why you are tapping on the enter BIOS Setup key, as soon as you turn the laptop on.
In BIOS Setup there is an option to bypass the P.O.S.T screen.
For additional questions post in a Comment.
Regards,
joecoolvette
May 21, 2012 | Computers & Internet
No operating system found
check the bios setup for hdd detection if hdd detected in bios then reinstall or repair your OS
if hdd not detected by bios setup then you have to open hdd cover
you will find a fpc cable betwen hdd & mother board
just open the connector carefully & refit & apply a small tape pice on the connector lock after reinsert the cable
Feb 19, 2011 | Samsung X05 Notebook
Installed new bios for windows 7, not working,on start up, computer locks up, able to unlock- but didn't happen with original bios. Looking for old bios to re install sholder012001@yahoo.com
o open the BIOS Setup screen: Reloading the BIOS default settings To reload the factory BIOS settings to the setup default:
  1. Press the F5 function key.
  2. Select Yes or OK.
  3. Press the Enter key.
  4. Press the F10 function key.
  5. Select Yes or OK to save the defaults.
You can also complete the following steps to reload the factory BIOS settings using the menu:
  1. In the BIOS Setup utility, select the Exit tab.
  2. Select Load Setup Defaults.
  3. The system prompts you to load the optimized setup defaults. Select Yes or OK and press the Enter key.
  4. Select Exit Saving Changes.
  5. Press Esc and then press Enter to exit Setup.
Please don't forget to rate this if it fixed your problem. Four thumbs up is basically what means your problem was solved. Anything less means your problem was not solved. Not sure people here understand that as far as how we get rated.
Jan 15, 2011 | HP DT PAVILION ELITE E9120f DESKTOP PC
Why do not support usb ni intel motherboard?
May be the USB support is disabled in BIOS setup.
To correct this enter the BIOS setup.
If oyu are not familiar with BIOS setup, open all main menus and check for 'USB support' (but do not change any setting!!!)
If 'USB support' is set to 'disabled', set it to 'Enabled'.
Save and exit from Setup.
Restart computer.
Check whether USB ports are working now.
Nov 12, 2010 | Intel D946GZIS Motherboard
When I open bios setup, some of the selections are dimmed and I cannot access them. How to fix it?
open yout cabiner then reset your bios setup but interchanging the jumper setting available on motherboard once u restart comp. later switch off n then place the jumper to its original place n start ur comp n try accessing bios.
Feb 17, 2010 | Intel Desktop Board D845GLAD Motherboard
Laptop bios password , not going on bios setup
Remove the Bios Battery and let it sit for 15 minutes...
I had this problem and that cleared it.
Enjoy!
Jun 11, 2009 | Lenovo 3000 Y410 Notebook
OPEN PASSWORD BIOS
How to enter the BIOS or CMOS setup. Reasoning: IBM compatible users may need to enter the BIOS or CMOS setup to setup or change how their computer's hardware is currently configured.
Solution: Because of the wide variety of computer manufacturers and BIOS manufacturers over the evolution of computers, there have been numerous different ways to enter the BIOS or CMOS Setup. Below is a listing of the majority of these methods as well as other recommendations for entering the BIOS setup.
Notice: If you are unable to get into the BIOS or CMOS setup because of a password please see document CH000235.
New computers Thankfully, computers that have been manufactured in the last few years will allow you to enter the CMOS by pressing one of the below five keys during the boot.
A user will know when to press this key when they see a message similar to the below example as the computer is booting. Some older computers may also display a flashing block to indicate when to press the F1 or F2 keys.
Press <F2> to enter BIOS setup
Tip: If your computer is a new computer and you are unsure of what key to press when the computer is booting, try pressing and holding any key on the keyboard. This will cause a stuck key error, which may allow you to enter the BIOS setup.
Should get ya back on line , Good Luck
Dec 01, 2007 | Fujitsu LifeBook C4135 Notebook
MSI K8N Neo-FSR Motherboard Logo
112 people viewed this question
Top MSI Computers & Internet Experts
Alun Cox
Computer Links
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
