Question about Panasonic Lumix DMC-FX8 Digital Camera
Memorycard My Panasonic DMC-FX8 will not function with 4GB San Disk Ultra II SDHC card. The card was tested in an another camera and was functioning ok. What might be the problem?
  • 73 Answers
Some cameras have a limit to the amount of memory it can have you may just be exceding the limit. try using a smaller card.
Posted on Jul 12, 2009
Can a panasonic dmc-fx8 use a sdhc memory card
This camera cannot be upgraded to read SDHC cards. The maximum is 2Gb Secure Digital.
Sep 18, 2014 | Panasonic Lumix DMC-FX8 Digital Camera
Will 4gb sd card work on panasonic DMC-FX8?
No. The camera works with SD cards up to 2GB in size.
Jun 28, 2011 | Panasonic Lumix DMC-FX8 Digital Camera
I have a Panasonic Lumix DMC FX30. Why aren't there SD memory cards in 4gb or higher? Can I substitute any of the other SDHC cards?
There are no SD memory cards 4GB or larger because the Secure Digital standard limits card capacities to 2GB. While SDHC cards will fit into the slot, they are electronically incompatible and will not work in the DMC-FZ30. You will need to stay with SD cards 2GB and smaller.
Feb 25, 2011 | Panasonic Lumix DMC-FZ30 Digital Camera
I bought a SDHC 4GB card and introduced in the camera. When turn on, came the message "memory error". What should I do?
Check your instructions, is a 4GB SDHC card compatible with your camera.
if you don't have a manual, just google "panasonic lumix dmc-fx01 manual" several options will appear.
Page 16 deals with card compatibility, it states that the maximum you can use is a 2GB Sd card, no mention of SDHC.
Nov 19, 2010 | Panasonic Lumix DMC-FX01 Digital Camera
Panasonic DMC--LZ2 gives me ''memory card error'' message if i put a SanDisk SDHC 4GB card in.
The DMC-LZ2 is specified to work with SD cards, not SDHC cards. While SDHC cards are physically compatible with SD cards, they will not work in SD devices. SD cards will work in SDHC devices, but that doesn't help you any here.
It's a hardware incompatibility. No firmware update can get around it.
Apr 05, 2010 | Panasonic Lumix DMC-LZ2 Digital Camera
The camera accepts a memory card of 256 MB but rejects a new memory card of 4 GB, initially I thought it was a card problem so exchanged the card for a new one of the same capacity but still the same...
Your camera can only use standard SD cards up to 2GB capacity, and even then they must be formatted to FAT16 and not the usual FAT32 used on most pcs these days. Standard SD cards actually go up to 4GB and your camera would accept those with a suitable firmware update but Panasonic never released one and they certainly no longer support the FX8.
Most 4GB SD cards are actually SDHC cards, and your camera cannot handle these as it lacks the internal hardware to do so.
You'll need to stick to a standard SD card of 2GB maximum capacity: don't worry about the FAT16/FAT32 thing as your camera will correctly format the card when you first use it. Carrying 2 x 2GB cards is more reliable than carrying 1 x 4GB card anyway as you always have a spare if one of them fails.
I hope that you appreciate my answer and I ask in return only that you take a moment to rate my answer.
Oct 02, 2009 | Panasonic Lumix DMC-FX8 Digital Camera
Computer won't recognize san disk 4gb ultra
Since your card is password protected,computer will not recognize it..so remove the password and then try it will work..
_______________________________________________________
Thanks for using fixya technical support
Jun 17, 2008 | SanDisk ULTRA II 4GB Compact Flash Card...
Message: Memory Card Error - Memory Card Parameter Error on 4gb SDHC card
I recently bought a DMC-TZ3 and have been researching memory cards. Several sites sell cards with the camera and list the card type. I would suggest buying one of these cards. Any cards larger than 2gb must be SDHC type SD cards. There appear to different types of SDHC cards, 1.0, 1.1 and 2.0. Check out Wikipedia.org for a description. 2.0 cards are not compatable for devices developed prior to 2.0 so that may be the reason for the camera problem. So far I haven't seen anything that states what type SDHC card the camera requires. I found a computer memory site that that sells memory that they say will work. There may be others.
http://www.mymemory.co.uk/compatible-memory/Digital_Cameras/Panasonic/Panasonic_Lumix_DMC-TZ3
Dec 13, 2007 | Panasonic Lumix DMC-TZ3 Digital Camera
DPOF Print Mark Function
The DPOF Print Mark Function allows you to sort through the SD Memory Card and select the images you want to print by electronically marking them. You can then print the marked images on any DPOF compatible printer by hitting the AUTO PRINT button.
Aug 30, 2005 | Panasonic Lumix DMC-FX8 Digital Camera
Unlimited consecutive shooting function
This functionality allows unlimited consecutive shooting up to the capacity of the SD Memory Card in the camera—ideal for capturing fast-moving objects in high resolution. The number of shots may vary depending on memory card size, picture size, and compression.
Panasonic Lumix DMC-FX8 Digital Camera Logo
128 people viewed this question
Top Panasonic Cameras Experts
Computer Links
ogerfire
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
