Question about IBM ThinkPad T41 Notebook
How do I replace the LCD screen hinge on my IBM T41?
The right side LCD hinge is broken. The hinge is severed, not bent or otherwise damaged. Where can I order a replacement part? How much should I expect to pay and how do I replace it?
  • Anonymous Feb 22, 2009
    I have a Thinkpad 390X that has a broken hinge and wanted to know where to get a replacement hinge and if it was repairable and how expensive?
    Sergeant:
  • 324 Answers
I'm sure you could get these hinges from IBM, but no idea as to their cost. They are available on e-bay for $8-$35 (depending on whether you want 1 or a set) plus $8-$10 shipping.
As far as replacement. You will have to remove the Top cover assembly from the base of the PC. If you need help with that, just let me know and I'll talk you through that.
To replace the hinge, you will have to disassemble the Top cover assembly.The screws that you will need to remove are covered by small black adhesive covers. There are 3 round ones along the bottom of the bezel, 2 square ones up at the top of the bezel (to the left of the white LED keyboard light, and 6 (trapezoidal shaped) on the outside of the cover (3 on each side). Carefully remove those covers and the screws that are under the covers. Keep track of where the screws should go back in.
The actual bezel is held into the top cover with some internal snaps. Start at one of the corners, run a knife blade along the seam (between the cover and bezel) and you will hear each fastener "snap" as you slide the blade past it. Once the bezel is loose, lift it off of the LDC screen. There is one additional screw that is located up in the upper right hand corner. That one will need to be removed, also.
Gently lift the right hand side of the LCD assembly a couple of inches and place something of appropriate size to hold it in the raised position. You will see 2 additional screws that hold the hinge to the LCD assemble. Remove those and the old hinge will come right off.
Position the new hinge and replace the two screws that you had just removed. Reverse the removal sequence to reassemble the display.
Before you start snapping the bezel back into place, check to make sure that the two cover catches (those hook things, up at the top of the LCD assembly) are both operational. The link going to the left hand one tends to easily fall off.
This procedure should take in the neighborhood of 45 minutes to an hour.
If you need any additional information, please feel free to ask. If this information has assisted you in the resolution of you problem, please return here to give my assistance an appropriate final rating. If this information has answered your question and/or lead to a resolution, please rate it as "Fixya!".
Thanks you, and have a super day!
Ron-
Posted on Nov 15, 2007
  • Ron Roske Nov 15, 2007
    I forgot to mention, if you want a copy of the service manual for this system, click on this link:
    http://www-307.ibm.com/pc/support/site.w...
    Ron-
    Well, that didn't work too well. Guess you'll have to copy the lick from the previous post and paste it into your address bar. Ijust did that and it worked OK. Don't know why it didn't show up as an active link in the last message.
    Ron-
Hello my laptop t41 power is not even flash but the adapter is working,am technician and i have troubleshoot allot.
I concur with what Diegotech stated.
To iterate further;
1) The DC Power Jack (DC IN), may have cracked solder joint/s on the motherboard connector, (Female), where the DC Power Jack plugs in.
Resolder
2) The DC Power Jack may be broken.
Center Pin mount, and/or body of DC Power Jack, and/or Outer Shell mount.
Replace DC Power Jack.
3) Wires from the DC Power jack plug to the female connector on the motherboard, may be bad.
Two examples, of a place to buy an IBM ThinkPad T41 DC Power Jack,
1) http://www.buy.com/prod/dc-power-jack-connector-socket-for-ibm-thinkpad-t40-t41-t42-r50-r51-r52/q/sellerid/23962916/loc/101/215782035.html
2) http://www.machinaelectronics.com/store/buypart/IBM_Thinkpad_T41/DC-P001
Past this point it's a bad DC sensor on the motherboard.
Replace motherboard.
IBM ThinkPad T41 Service Manual, (Free),
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-ibmlenovo
On this page go down to the 8th line.
The one that starts with > ThinkPad T20.
Go across, and click on > T41
Takes approximately 2 seconds to see the first page, and additional time to fully download.
Page 142 for 14.1 inch LCD screen
Page 151 for 15 inch LCD screen
(PDF file page number box at top)
Dec 01, 2010 | IBM ThinkPad T41 Notebook
My IBM Thinkpad T41 LCD screen blank when power is ON.Please assist me.This happen because I did not use my laptop for about 6 months.
Hi, This issue is clearly hardware and might be related to 3 part, Inverter card, LCD cable or LCD Panel ( Or systemboard, just to make sure try with an external display if the issue reproduce it's systemboard/graphic card related, if not LCD related ). If you are still entitled to warranty then this hardware failure is covered by the terms. You should have the 3 parts stated below replaced as it s a common issue with Thinkpads.
In case you are out of warranty cover you still can try to subscribe to a warranty extension, you can check on www.lenovo.com , otherwise you might want to order theses parts on a website such as ebay. To swap the pieces requires quiet advanced skills as you have to take down the whole computer, obviously LCD Panel included. Unfortunalty this is hardware related, not much you can do... I hope this help ! Thanks and have a nice day ! J -
Jan 07, 2010 | IBM ThinkPad T41 Notebook
I've got a second hard drive caddy for a T41 IBM thinkpad, all slotted in, but nothing is being shown on the computer
Check your pins and make sure they didn't get bent. Otherwise, you might have a bad hard drive.
Oct 09, 2009 | IBM ThinkPad T41 Notebook
It wont turn on, and when it turns on, the slightest movement of the laptop will make the screen black and sometimes, the screen has a glitch, i can't move my pointer anywhere and it just hangs. Please I...
Most likely its the LCD cable from motherboard to the screen. This can get damaged especially in the hinge area and can prevent the laptop from turning on and the other problems you mention. Replacing the LCD cable should solve all your problems.
Sep 12, 2009 | IBM ThinkPad T41 2373 Notebook
RE: How do I replace the LCD screen hinge on my IBM T41
here is the manual from IBM http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-46464
Sep 17, 2008 | IBM ThinkPad T40 2373 Notebook
Replace LCD screen
All modern thinkpads are similar, you start by taking apart keyboard and top cover, then you unscrew hinges and remove screen. Here is some movie:
Thinkpad LCD Removal
Removing Thinkpad 600 Series Display - Part 1
Replacing Thinkpad 600 Series Display - Part 2
IBM ThinkPad R40 -- Fixing the black-out LCD Screen
This is not an easy job, there is risk to cause further damage to your laptop if you do not have enough experience.
May 28, 2008 | IBM ThinkPad T60 Notebook
IBM T41 Hinge Replacement
Repair4Laptop: Repairing of Laptop and Notebook LCD Displays IBM ThinkPad T41: Screen inverter replacement guide, explaining how to fix a laptop backlight problem. ... Samsung X10: (An illustrated display hinge replacement guide)
Good Luck ...........Please dont for get to Vote, Thank You.
Dec 18, 2007 | IBM ThinkPad T41 Notebook
IBM ThinkPad T41 Notebook Logo
6,428 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
