Question about Kenmore 43142 Front Load Washer
Kenmore HE2 110.4751
Th emachine was making funny noises. i stopped and and went to turn it back on and it started flashing error code F 01.
  • 619 Answers
Re: Kenmore HE2 110.4751
For the F10 code ? Unplug the washer open chech the funny noise / belt are worn out / slap to the brackets and other near obstacles . Replace belt broken.
Detergent leaking /ovewr flow clean w/ fish nylon # 150 just 40 cm /insert in the hole put water to soften the hard detergent forward and backward to clean detergent hose.
Posted on Jan 09, 2008
0 characters
3 Points
What does E27 on display mean
Bosch washers come with built-in sets of error codes used to diagnose and correct common problems. The E27 code isn't often listed in Bosch manuals but relates to the washer door lock
The E27 error flashes on the washer LCD screen and stops the current load. Unplug your washer for 30 minutes and then plug it back in to reset the code.
Open and close the door two or three times to reset the sensor. Sometimes the door has been closed too hard and the sensor reading fails.
Mar 10, 2011 | Bosch Washing Machines
Its flashing code f-01
The F01 error is a communication error and most likely the cause is a bad central control board. You tried to unplug the power and the machine still will not start so next I'd recommend trying to run a diagnostic cycle to verify the operation of the central control.
In the image below are the instructions to enter and run the diagnostic routine. If the process is done successfully all of the LED light will come on for 5 seconds then display the last error. Push the same button until the error code ends and all the lights come on again for 5 seconds then the test will start.
If the test runs through okay then the central control unit is most likely okay. If it fails to enter diagnostic then the control has failed and needs to be replaced.
The last thing to try is to check the connections on the control. A loose connector might cause this problem and the 2nd image shows how to access the console and you can wiggle, jiggle, pull and push on the connection, with the washer unplug from the wall so no voltage is present..
LINK FOR IMAGES:,wbqgggwgkbbqkffxgtqsskgwtqkq,th/kdrdrkfgsxkdqfbbssk/1/1303472/5961991/image46797img-th.jpg
Please rate this solution. Regards.
Nov 09, 2010 | Kenmore HE2 Plus Front Load Washer
Trouble shooting the hotpoint aqualtis aqxxf149pi flashing f08
my hotpint aqualtis aqxxf149pi make a funny grinding noise when it spins help please?
Jun 25, 2009 | Hotpoint Washing Machines
My kenmore elite he3t showed an error code f02, i unpluged it and plugged in back in i tried to run a drain/ spin and the machine make a strange noise i suspect the motor filter is clogged and the moter is...
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
***You stated that there was a noise when you started a manual drain. This may be a damaged drain impeller. in this case, replace the entire pump(drain).
Jun 07, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
I pushed the start button and got some clicking noise, then I got an alarm sounding beep with a "F" flashing, then another alarm sounding beep with a "dl" flashing...which continued until I cancelled
If you give a specific model I could get a manual and see what i can find out but what i will do is direct you to the Kenmore questions line which is, (one last thing try unplugging the washing machine and then plug it back in maybe that will reset it, if you still get the error look below.)
Product questions
Call 1-888-KENMORE (1-888-536-6673).
also if you do not have the manual for the product you can obtain an online version here.
if you look on the right hand side of the page you will see in bold letters.
Find Owners Manual
We've got manuals for every major brand in your home
just enter your model number in there and look through the manual for the troubleshooting section and then error codes.
Jun 01, 2009 | Kenmore Washing Machines
Kenmore HE2t Error Code F 01 flashes
sF01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
This error code can sometimes be caused by a glitch or power surge through the electrical lines.
You may be able to clear this code by unplugging the washer for 5 minutes.
If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
The procedure for accessing and replacing this control board is shown in this image...,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 16, 2009 | Washing Machines
F 01 code won't come off, washer won't start
you have to buy a new ccu unit in sears if you dont have warranty the cost is betwen 175 to 200 $$
Aug 12, 2008 | Kenmore Elite 45986 Front Load Washer
F01 Error code
most likely suspect main control bd
Apr 11, 2008 | Kenmore 46462 Front Load Washer
Error codes
if this is a fridgidaire washer, I guess it's a clogged coin catcher. You have remove the front access panel and clean it out. I am working on that now.
Nov 05, 2007 | Washing Machines
Kenmore 43142 Front Load Washer Logo
1,184 people viewed this question
Richard Roth
Richard Roth
Jesus  Colon
Jesus Colon
Level 1 Expert
Fred Sops
