Testimonial: "Do i really need dvd/cd player to use speaker?because i only have av502a amplifier konzert where my 2 speakers connected.."
if your amplifier has RCA connectors for the audio input no need to use DVD/CD player to drive it
place Amplifier where the cd /dvd player was in the diagram. The switch box gives you more flexibily to connect more devices and share the amplifier between them. You could feed the Audio out RCA from the TV directly to the amplifier input RCA but no other devices would be able to be switched to the amplifier when needed. You cannot play the multiple devices on the amplifier all at the same time with the switch box. If for some crazy reason you want to mix all the sounds together and play devices all at the same time you get a pre-amplifier mixer and feed the output into the amplifier. http://www.radioparts.com.au/product/014...
If the audio out if analogue you may be able to get cable converters to convert between the different types of audio connectors usedand whatever the other standard is .https://en.wikipedia.org/wiki/Audio_and_...
what sort of audio out connect is on the TV ?
and what sort of audio connector is on the amplifier ? do they match or are you dealing with different standards ?
Thank you very much sir brett..i got the sound from my speaker already..i tot the jack with red yellow and white same what i need..its was just red,yellow and white and the other end was just like universal headset plug.....got it..tnx much..
