Question about Canon PIXMA iP3300 InkJet Photo Printer
Won't print because it says operator error.what shoul i do??
Operator eror
i have prees the RESUME,but it's dont work...?
have solution please?
Posted on Dec 28, 2009
    Sniper:
  • 58 Answers
Hi
$i chacked there's nithing called operator error
try this , diconnect the camera from the printer
turn off the printer
put off the power cord of the printer
after two minutes
try again
hope this helps
Posted on Jul 12, 2009
Service code interrupt
Error type T11 [Pressure-control motor lock]
T11-***
!!System Error!!
Press Reset Key
If Recovery has Failed, Call Service
Reset method Jam reset or switch on power again
Error point Error conditions
600
Timeout error for reducing pressure (OFF -> ON) during print-pressure home
positioning.
601
Timeout error for increasing pressure (ON -> OFF) during print-pressure home
positioning.
602 The print-pressure limit sensor does not change during print-pressure operation.
620 Print-pressure operation was called with the print-pressure motor locked.
621
Incorrect print-pressure operation timing (print-pressure operation command was
received when the print-pressure should not change).
622 Sensor A is ON and sensor B is OFF during movement from area A to area D.
623 Either sensor A or sensor B is ON during movement from area D to area A.
624 The current area data is undefined.
625 The target area data is undefined.
626 Timeout during relative print-pressure movement.
Error type T12 [Master-disposal-section motor lock]
T12-***
!!System Error!!
Press Reset Key
305
The master compression sensor does not go ON within 6.5 s after the master
compression motor operates in the return direction.
306
Master compression sensor does not go OFF within 2 s after the master
compression motor operates in the compress direction.
307
compression motor operates in the compress direction, and the mastercompression-
motor limit sensor cannot count up until the compression-limit
position.
309
The master-compression-motor limit sensor does not change within 200 ms
during compression operation.
hope to be of help
Sep 27, 2013 | Riso RP 3700
The printer's lying to me
The printer requires both cartridges to have ink before the printer will initialize and operational. Even if you are only printing black and white both cartridge have to contain ink or the printer will error out. This is standard on all ink jet printers from every manufacturer. You will have to get ink before you can print.
Apr 28, 2013 | Canon Pixma MX410 All-In-One Printer
My office jet G85 won't print. No error messages appear,it has a new color cartridge,it copies, but won't print from my computer.
If it copies ok, then the issue is either the way it is cabled to computer or the print driver software settings on pc.... How is it connected via USB? Check port and correct driver is in windows/control panel/printers. Reinstall.
Nov 30, 2011 | HP OfficeJet G85 All-In-One InkJet Printer
How do I get A920 All-in-One to connect?
Hi Doris,
Please make sure the Operating System you are using corresponds with the printer driver.In other words,make sure the driver you're installing is compatible with the Operating System on your PC.
Check out your Operating System's compatible drivers for downloads from this Dell support site.
Make sure you unlock the scanner bed by pushing the scanner lock down.
Check the USB cable connections and make sure its secure.
If problem persists,return the product if still on warrant.
Hope this helps.Thanks!
Nov 11, 2011 | Dell A920 InkJet Printer
Installed The Print Shop 2.0 Deluxe on my Windows XP, SP3 & seemed to install fine. Won't run, gives me error message - "The configuration file is missing or invalid; you may have to repair...
Hello there, At first, go to start menu, all programs, accessories, system tools, open System Restore. Restore your system to restore point created before installing The Print Shop. After that, try to install it again. Otherwise, you can try to install it from different CD, or installation file. Sincerely, Steve TM
May 28, 2011 | Computers & Internet
My Dell V305 printer will not print the whole page of an email. This is a document that I need the whole page.
You can get the half document when yhr printer runs out of memory ie too big a or too detailed a print job or if the document itself contains what the printer is seeing as control or commad characters and errors out. It can also be a port error.
Usually its just too detailed a print job. When you print click on the printing preferences and then look for either a DPI setting or a Quality setting. Turn any of those down and try printing. You may have to turn it down more than once to get it to behave. Most new printers can print at 2400 dpi. Unless you know what too look for you won;t be able to see much if any difference even down to about 300 dpi.
Sometimes you cn get port errors and those can be hardware or operating system caused. You can try another usb port. Also try rebooting and printing with nothing else running.
Aug 26, 2010 | Dell Office Equipment & Supplies
Cannot print; scanner, copier works fine.
whta may have happened is that the first print job has an error if yu right click on the printer on desktop you shoul see all the print jobs in line cancel the first job and see if the others print you can also go to printers on the desk top and right click on the printer go to properties and then port make sure it is highlighted for you connection type. you can also test print from here to cjheck connection. make sure it is set on the port for the correct connection either usb or tcip or parrallel and that it is connected as a -_local printer. good luck
Mar 18, 2009 | Brother DCP 7010 Multifunction Laser...
Laptop won't boot up
That shouldn't affect the laptop booting, hold down the power button for 10 seconds, it shoul boot up., if not then remove the battery and replace it. then try it again, good luck, Gym
Dec 18, 2008 | HP Compaq nc6000 Notebook
My printer is not printing Lexmark 5400 series
www.lexmark.com has the drivers you'll need by model and operating system
http://tinyurl.com/6qcpgy
Jul 30, 2008 | Lexmark X5470 All-In-One InkJet Printer
Printing error
when i send for print i et
PCL XL error
subsystem: KERNEL
Error: IllegalTag
Operator: 0x1b
Posittion: 7
Jun 15, 2008 | HP LaserJet 6p Printer
Canon PIXMA  iP3300 InkJet Photo Printer Logo
1,775 people viewed this question
Clive
Clive
old marine
old marine
