Question about Dell 5100cn Laser Printer
Dell 5100cn error code 016-302. What does this mean?
Dell 5100cn error code 016-302. What does this mean and how can it be corrected?
My printer is connected directly to a network.
Corysf62
  • 188 Answers
SOURCE: 5100cn error 016-310
The controller card on the 5100CN is located at the rear of the printer.
Rotate open the paper tray cover, remove the 3 screws securing the controller card assembly to the chassis. ( one at the bottom middle, one at each of the top two corners ), and slide the assembly towards you to remove.
NOTE: If you have a replacement Controller card that you are going to replace, you must migrate the existing NVRAM Chip from the old card to the new card. Even if the replacement card contains an NVRAM Chip, the old chip must be used in order to prevent an NVAM error.
Also ensure use of proper ESD Handling proceedures to prevent damage to the board and NVRAM Chip.
Posted on Sep 28, 2008
Corysf62
  • 188 Answers
SOURCE: 010 397 Error Message on Dell 5100cn
The following steps are the troubleshooting steps that should be followed for error code 010 397.
First, the definition of the failure is <IOT Fuser Failure>, and means a Fuser Error is detected.
1) With power off, reseat the fuser by physically removing it from the printer, then reinstalling it and locking it in place. Turn the power back on. ( if the error is still present, proceed to step 2 ).
2) If reseating the fuser did not resolve the problem, Replace the fuser with a known good fuser.
( if problem is not resolved, proceed to step 3)
3) Replace the LVPS ( low voltage power supply ). ( if problem not resolved, proceed to step 4 ).
4) Replace the PWBA MCU ( printed wiring board assembly - machine control unit ).
END of troubleshooting.........
In most cases, the fuser itself is the problem. If you tried to reseat or replace the fuser while power was still on, the LVPS could have been damaged just as if there were an electrical storm.
Hopefully this helped.
Posted on Oct 02, 2008
SOURCE: Error 016-302 on Dell 3100cn
drum cartridge replace soon
Posted on Oct 30, 2008
kakee
  • 1269 Answers
SOURCE: dell 5100cn change ip address
Changing Printer's IP Address isn't that complicated. There are two ways on how to change the printer's IP Address.
If you know the old printer's IP address, you can simply type that old IP address on the Address Bar of your Internet Explorer or any other browser (ex: http://192.168.1.101). It should redirect you to the printer's User Interface. From there you can go to Network then TCP/IP settings. You can change the IP address of the printer. Make sure to use an IP address within the same range of your network.
The other way to change the printer's IP address is by its own Menu/Settings on the printer's LCD panel.
On your printer, press Menu then got Settings. Look for Network or LAN settings and click on Advance. Select TCP/IP and click on Edit. You can now change the IP address of the printer from there. Click on Done or Save after that.
Note: Make sure the use the correct IP address within the network's range.
Posted on Jul 16, 2009
Turk_97
  • 132 Answers
SOURCE: how i can fix the error 016-302 restart printer???
This is a little bit of a tricky one, First, remove any LAN/USB cable and cancel any print jobs. You will have to remove the top cover to easily rotate the "rubber" belt until you see the silver square appear near the foam "window"...actually more like a cutout.
OR
Remove the drum cartridge from the top of the printer. Now, stand it up with the blue roller up and facing you. Then turn the blue roller on the very edges, so your fingers did not touch until a silver box shows up in the window (where the foam was) on the bottom right. Put it back together, and that should do it!! Good Luck :)
Hope This Helps
Posted on Oct 08, 2009
Dell 5100cn Error cod 010-397 Restart Printer
ahmad, does the printer show as default? if not make it. Try test print and make sure all printer compartment are securely closed.
Jan 11, 2014 | Dell 5100cn Laser Printer
Dell Printer problem
Generic toners often cause this error. Was the cyan you purchased a aftermarket compatible?
Jul 26, 2012 | Dell 5100cn Laser Printer
I am getting a PCL error code on my Dell 5100cn
Try to re-install the driver for this printer. Try to go here. Let me know if that works for you.
Jul 20, 2011 | Dell 5100cn Laser Printer
What does error code 006-370 mean?
http://support.dell.com/support/edocs/systems/5100cn/en/UG/section18.html
see this page for detail, i hope this helpfull, if you think this helpfull please rate very helpfull or helpfull. thanks for using fixya
Jan 20, 2011 | Dell 5100cn Laser Printer
Dell Laser 5100
Means the Yellow Toner Cartridge is not communicating with the printer. If you've installed a third party yellow toner cartridge, go to the Dell Printer Configuration Web Tool to set the toner to non-Dell toner. If it is a Dell cartridge, the procedure is to turn the printer off, wait 10 seconds, and turn the printer back on.
Feb 24, 2010 | Dell 5100cn Laser Printer
Dell 5100cn has error message: Clean CTS Sensor -
I've included a link below to the manual for your printer. Please follow the instructions listed under "Cleaning the Automatic Density Control (CTD) Sensor".
http://support.dell.com/support/edocs/systems/5100cn/en/UG/section21.html#1097283
Jan 19, 2010 | Dell Office Equipment & Supplies
Error code 010-397 dell printer 5100. Have change fuser and restart printer keeps coming up as error message
) The fuser gets very Hot!! Let cool for 10 minutes after turning off the power and unplugging the copier!
2) Pull the two blue locking tabs forward and remove the fuser unit. Reinsert and push back on the tabs to lock back into place. Sometimes just reinserting the fuser will allow the catch on the locking tab to function correctly and push the trigger on the sensing unit. Turn the copier back on and pray the error code doesn't reappear..
3) Mine reappeared. Evidently the catch on the fuser unit was still not pushing the trigger forward, causing the copier to surmise that no fuser unit was installed.
CBR Tech Solutions or http://www.cbrtechsolutions.com
Oct 14, 2009 | Dell 5100cn Laser Printer
Need IP address for Dell 5100cn printer
You will need to print off a printer settings page. Usually found under the Reports menu or something similar. It will list the IP address. Once you have the IP Address, make sure it is set correctly in your printer drivers in the Control Panel on your computer.
May 26, 2009 | Dell 5100cn Laser Printer
Dell 5110 004-310 reset printer error
This may not solve your problem but it did mine when I got the "reseat cartridge" error. I had inadvertently ordered the cartridge for the 5100cn, which looks exactly the same as the 5110cn and actually fits if you order the generic version (the Dell 5100cn cartridge looks like the 5110cn but doesn't quite fit).
So, first make sure that you ordered the 5110cn cartridge. (And if you need two opened 5100cn cartridges, I've got them up on ebay :( !!!!)
Jan 23, 2009 | Dell 5110cn Laser Printer
Apr 04, 2008 | Dell 5100cn Laser Printer
Dell 5100cn Laser Printer Logo
2,264 people viewed this question
Top Dell Office Equipment & Supplies Experts
David Patricia James
Marvin
Marvin
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
