Question about Compaq Presario 2100U Notebook
Computer stuck? Hi,my laptop comes on but cannot find the os.onetime it said that one of my drives is stuck. should i replace my hard drive?
    Scholar:
  • 112 Answers
I would try removing the hard drive with the laptop turned off without the power adapter connected. Then reinstall the hard drive and reconnect the power adapter. Check in the BIOS to see if the hard drive is reconogized. If all this fails I recommend replacing the hard drive and reloading the operating system
BPCS
Posted on Nov 15, 2007
Ca i replace the hard drive in a acer aspire one 8'9 with one from a hp mini110? thankyou
Hi
most laptop hard drives are same size 2.5
but the hard drive from the hp may have a different face plate or holder but can easily be removed
also the os system on the hp will not load up and work on the acer
you will have to
either use windows easy transfer to copy your entire hard drive files and save onto spare hard drive
so that when you replace and format different hard drive you can then transfer it back onto new hard drive
or if pre windows 7 os you could use something like norton ghost to copy your existing operating system and files and make a system image and store on spare hard drive then when you replace the hard drive
you boot up with norton ghost and ask it to find the image and restore it to the new drive
Or if your lucky enough to have the operating installation disk or can get your hands on another retail installation disk you can reload a new operating system using the product code which should be on a sticker on the base of your laptop
Hope this was useful to you
Feb 25, 2011 | Acer Computers & Internet
There's a hard drive failure, I need to replace it, what kind of hard drive should I get?
hi use yr failure hard disk for sample to get new one hard disk then u need install os and other progrem in yr laptop to make it working
Feb 19, 2011 | Toshiba Satellite M35X-S163 Notebook
I have a Dell Inspiron 1545 laptop that won't boot. When i perform a BIOS diagnostic on it it comes up with error code 2000-0146. "Hard Drive 0 - self test log contains previous error(s)". I...
The problem is either the Hard drive has failed and needs replacement or the hard drive is operational but it lost the OS. (Operating System). If the OS is gone, you need to re-install it again..
Feb 09, 2018 | Dell Inspiron 1545 Notebook
Panasonic CF-51 computer getting stuck, and making clicking noise. Have to turn off manually and restart.
Listen carefully to the HDD bay of the CF-51, If the "Clicking" sound is coming from that area then it is possible that the hard drive is failing causing the whole laptop to freeze up.
If that is the case then you're looking at a new or replacement hard drive.
Regards.
May 27, 2010 | Panasonic Toughbook CF-51 Notebook
Hd may be corrupted
Yes, definitely you can buy replace with any 2.5" laptop hard disk make sure that you buy HD with correct interface, if you old HD is IDE then buy IDE hard disk , elsei if SATA buiy SATA harddisk
RATE THIS SOLUTION!
RNJ VINOD KUMAR
Sep 13, 2009 | Dell Latitude D600 Notebook
Gets stuck on the "asus" screen when i trun my laptop on.
Could be that the hard drive is not making a good connection. Turn the laptop upside down. Find the "latch" where the hard drive is "housed" and remove the drive... Then carefully and firmly replace it and make sure it makes good contact. Then try again to boot the laptop. If it still does not start up TAKE IT BACK to where you bought it from and let them sort it out 'cause it is supposed to be under warranty for at least 1 year
Aug 03, 2009 | ASUS Eee 4G Notebook
Blue screen on my laptop when I start reinstalling a deleted win Vista OS
I would get a different hard drive. Hard drives can be very tricky sometimes. I had that problem with My D600. replaced the hard drive and everything was okay. Hope that helps.
May 25, 2009 | Acer Aspire 6930-6771 Laptop
Hard drive caddy stuck
Try giving it a lift and then try to remove it.
Feb 05, 2009 | Dell Inspiron 2200 Notebook
Does not find hard drive
Hi!!!!
try to open the laptop find the hard drive?
pull out the hard drive and then put it back again
may the hard drive was not connect properly
Sep 20, 2008 | Sony PCG-TR3A Notebook
My notebook makes noises
mayb your hard drive crash...
try to change new hard drive...
it will be can fix it...
good luck.
Apr 20, 2008 | Sharp Mebius PC-PJ2-S3 Notebook
Compaq Presario 2100U Notebook Logo
59 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
