My DVD drive not detecting.Some time PC detects it & working properly. Some time PC dosent detect it. Why is that?
  • 39 Answers
Try changing your IDE/SATA cable. It may even just be loose.
Posted on Jul 12, 2009
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
LAPTOP DVD NOT WORKING
Re-seat the DVD drive so it makes proper connection then boot up the laptop and go into the BIOS then check the BIOS to see if the DVD drive is detected. If the DVD drive is not detected then it is faulty and needs to be replaced.
Mar 09, 2013 | Computers & Internet
Unable to boot internal devices? bug?
Did you go into the bios settings and check the status of the hard drive? it would seem that is where the problem lies.
Jul 06, 2012 | ASUS Computers & Internet
External Hard disk is not detecting on my desktop PC
Try a different usb port. Maybe a 1TB external hd is too big for your old computer to recognize. Old computers cannot handle a drive that large.
Jun 08, 2012 | Computers & Internet
My CD Rom drives cannot be detected by my CPU
make sure that ur cpu power is OFFfirst, check the power cable in the cpu and check of the drive led is on. second, make sure that the data cable is well captured in the the drive to detect on the computer. third, if this dosent worked well is must the problem of the drive self and i advise to get it to ur Maintenance Center
الاستماع
Jun 05, 2011 | Computers & Internet
My dell optiplex 210 L cannot see DVD drive in "my computer" and also in device manager. Even after going through registry as advised, i don't see lower and upper entries that iam supposed to...
Check the DVD Drive cable connections, make sure they are plugged-in properly. Check BIOS if DVD is detected; you may have to reset to default configuration. If it's detected in BIOS, press F12 while on the Dell screen to access advance boot menu & select CD/DVD drive option. Insert a bootable disc like windows installer & see if your drive will read it. For cabling setup refer to this link http://support.dell.com/support/edocs/systems/op210l/en/ug/mtdrvs02.htm#wp1136008
Mar 24, 2011 | Dell OptiPlex 210L PC Desktop
My PC detected my LG DVD reader/writer rom but the rom is not reading maybe you can help me troubleshoot this problem thanks
Make sure the software for this DVD drive is installed into the PC and then your drive is connected to be detected and installed, This will also remove off all previous drives that might cause errors.
Sep 25, 2010 | Computers & Internet
(LG GSA H42N) IS NOT DETECTING ANY DISC
if u r sure about properly working of software & os ,u must check internal hardwares of it,like lens motor & its lever.even,sometimes by an easy cleaning of the lens,u can solve thisproblem...
May 16, 2010 | LG GSA-H42N 18x DVD RW DL IDE Drive...
Dvd drive not detected. After burning a DVD the drive went dead and is no longer detectable.
If you have some experience in opening up the PC. remove the main cover & unplug the power connector & the Data Cable from the DVD Drive. ( the conputer power has to be switched off) Replug back the cables as it were & start the PC.
It should detect by now
May 08, 2010 | Dell DVD-rom DVD Drive
Cd dvd drive not working
Check the BIOS, see if the drive is detected and identified If it is properly detected, then run this fixit
http://support.microsoft.com/kb/314060
If the drive is not detected in BIOS, then the drive may need replacement
Sep 30, 2009 | Dell Inspiron 1501 Notebook
Problem in opening cd.
Please checked in bios, is your dvd detected ?
if your dvd isnot detected, most of the time is your dvd, sometime it mainboard problem.
Also checked in the device manager, is your dvd there and need driver ?
if yes, you have 2 option, you can reload your OS or you can edit the registry.
follow this step if you want to edit the windows registry:
Mar 11, 2008 | Dell INSPIRON 6000 CENTRINO...
Computers & Internet Logo
77 people viewed this question
Alun Cox
k24674
