Question about Fujitsu Siemens SCENIC E600 PC Desktop
I have just put in new hard drive as old one was to small. It is now saying there are no ethernet drivers. So i cannot connect to internet.
  • Fujitsu Siemens Master
  • 13,433 Answers
You need to use another computer to go to the fujitsu siemens website.
http://www.fujitsu.com/us/support/
download the drivers for the machine, under desktops.
Then transfer the drivers to the right computer with a usb memory stick or anything else
install the drivers.
Posted on Jul 12, 2009
I need a modem or an ethernet card -- where can I find/buy one
You can use a Ethernet cable connected to the computer. What OS, Win XP? Hp Support will have all the drivers: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&dlc=en&docname=c00250583&lang=en&lc=en&product=242222& If a "Professional" could not get on the internet and install drivers, I would find another professional, I'm just saying.
Dec 23, 2012 | HP Pavilion ze4220 Notebook
Windows vista crashed. changed bios to load xp. worked. old files on hidden drive. problem is cant connect to internet. driver files on hidden drive. Now what? Try to find driver and load it?
Patricia,
Left-click on Start, then Right-click on My Computer.
Left-click on Properties at the bottom of the list.
Left-click on the Hardware tab.
Left-click on Device Manager.
Once Device Manager has fully loaded left-click on the + sign, next to Network adapters.
What Ethernet chipset are you using? Intel, or Conexant?
http://www.dell.com/support/drivers/us/en/19/Product/dimension-1100
Communications (6)
A) Intel - Driver 9 /5/ 2006
B) Conexant - Driver 10/ 21/ 2005
Network (3)
A) Intel - Driver 12 / 1 / 2005
If you have an Intel chipset suggest you download AND install both Intel driver files listed above.
Burn to a CD disk. Put it in your optical drive of the needed computer. Go to My Computer, and DOUBLE-click on the drive letter, of the optical drive with the CD in it.
DOUBLE-click RIGHT ON the file name.
Follow the instructions of the Installation Wizard.
(Just click on Next, Next, and Finish)
Driver: Small piece of software that allows the Operating System to communicate with a device.
Windows XP is the O/S, the ethernet chipset is the device.
When asked to restart the computer - No.
Turn the computer completely off, then after 1 minute turn it on.
(Hard Start)
Still no?
Ethernet adapter card is shot,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3350631&CatId=200
For additional questions please post in a Comment.
Regards,
joecoolvette
Sep 27, 2012 | Dell Dimension B110 PC Desktop
Ethernet driver missing on hp dc7700cmt computer. I have tried to use the drivers form the HP download site but the driver still comes up missing. I can't connect the computer to the internet to let...
Open the Device Manager (you can do a Windows search for it if you don't know how to open it).
Look in the Network Adapters section.
Remove your Ethernet device. Right-mouse-click it and make sure it's not disabled. If it's disabled, enable it and you should be fixed.
Otherwise, click it to highlight it and press "delete" to remove it. Then right-mouse-click on "Computer" (at the top) and "scan for hardware changes." Windows *should* install the correct driver.
Otherwise you'll need to go to the HP support site on another computer, save the driver to a flash drive, external hard drive, or CD or whatever, and then install that on your computer.
Jan 03, 2018 | HP-COMPAQ DC7700 CMT C2D/2.4 2GB-160GB...
I can't connect to my access point. my compaq 420 presario's driver proper installed and the wireless switch was on. what's the problem?
if you are refering to your internet connection
you might have put in the wrong password or user id check to make sure you have put these in correctly first make sure the caps lock is on/off what ever applies to your user and password id that you provided to your ISP
also
make sure your modem/routers settings are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet you might check your modem first to make sure that you are getting a connection
click start control panel administrive tools computer management device manager scroll down network adapters + expand Ethernet driver right click you will have options to update driver disable uninstall or select properties general you will have the options to troubleshoot or to update driver rollback or uninstall
a yellow? question mark means you need to install/update driver right click to install driver
last resort ring your ISP internet sevice provider get them to check your modem for internet access online
hope this helps
Apr 07, 2011 | HEWLETT-PACKARD Hewlett Packard HP-Compaq...
Can't connect to the internet new hard drive installed, windows XP pro installed when checking hardware : says ethernet controller driver - not installed. tried finding it on the installation CD, get a...
You need the Intel Pro 100 driver for XP. Go to the following web link at Intel: http://www.intel.com/p/en_US/support/highlights/network/pro100ve and download the driver. Copy it to a flash drive. Put the flash drive into your PC that needs the LAN driver and double-click it to install it.
Oct 25, 2010 | Microsoft Windows XP Professional
Dynex10/100m router not connecting to internet
1. check the router to see if you have a firmware update
2. check cables ( make sure you don't have a crossover cable.
3. check firewall in router and the PC OS ( operating system)environment.
4. check the setup for the XBOX
Apr 18, 2010 | Dynex 4-Port Ethernet Broadband Router...
Wanted ethernet drivers
You can download the driver here: Click Here
Apr 26, 2009 | Computers & Internet
LOST ETHERNET DRIVER
If you have the "Windows XP" operating system then follow these instructions...If you have a second computer with an internet connection then you can search on the internet for that driver...type the make and model of your computer plus the word "ethernet driver" and after you find it you just download it into "My Documents"...after that, copy the driver onto a blank CD disc...Take the CD and put it into your notebook and it should open and extract the file ..If it doesn't open up when you load the CD, go into "My Computer" and then double click on the "CD/CDRW/DVD/DVD-RW drive...restart your computer and remove the CD from the disc drive...Now plug your DSL into your ethernet port and see if it works...if it still does not work then go into "Control Panel" and then "Network and Internet Connections" and then "Network Connections" and then "Create a New Connection" and then follow the instructions...restart your computer and see if it finds the ethernet port and receives the signal through the ethernet cord
Apr 18, 2009 | Computers & Internet
T3256 needs ethernet driver
Dear Cedrich,
I found an "unofficial" e-machines website for you: http://www.e4allupgraders.info/
And the following is a link to your Ethernet driver:
http://www.e4allupgraders.info/dir3/files/drivers/lan/AU31_Ethernet_xp2k.zip
Here is the page for your particular model:
http://www.e4allupgraders.info/dir1/motherboards/socketa/au31_downloads.shtml
If you need any further assistance, please request it,
Jem
Jan 04, 2009 | E-Machines T3256 PC Desktop
Fujitsu Siemens SCENIC E600 PC Desktop Logo
280 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
