Question about HP Compaq nc6320 Notebook
HP Compaq nc6320 Boot Disk
I have a HP Compaq nc6320 laptop and i've recently reformated my hard drive thinking that i have a boot disk, but unfortunatly that's not the case and boot disk is nowhere to be found. Is there any way around this problem? Perhaps someone knows of any boot disks that are available online and that's for HP? Is the boot disk the only way to install your OS back onto your laptop?
  • 1 more comment
  • ose123 Jan 04, 2008
    Mine is same Note book is HP pavilion dv 1000 requiring a boot disk which I don't know where that is. I went into set up, I saw all kind of ID of the note book. System Board #308F ; BIOS version F.07 etc, etc
  • Anonymous Mar 26, 2014
    I need recovery media HP Pavilion dv3-1075us .. No longer available from hp .. Where can I obtain equivalent
  • Anonymous Mar 30, 2014
    boot sequence
  • 121 Answers
In case you can get a non boot disk , u can install it by using a start up floppy disk for win9x
Posted on Nov 15, 2007
I have an hp compaq nc6320 laptop that i am trying to reboot and nothing seems to be working right, when i restart the computer it only makes it to the windows did not load properly screen and restarts...
1st of all you have to make sure your hard disk in enabled in system setup. maybe f2 when you boot. go into hard disks and see if your hard drive shows up. then boot priority and make sure your your hard drive has a check next to it because the check means its enabled. if not then it looks like you might have a bad hard drive. you can try to purchase a usb enclosure and install your hard drive inside,then take it to any 2.0 usb pc or laptop port and see if you can retrieve any important data then do a full format and install it back into your laptop and install windows again
May 29, 2011 | Computers & Internet
Boot flash drive
Download the HP Format Tool and install it. Get your boot disk or the downloadable files and copy/extract them to a folder on your HD. Make sure anything on your USB Drive is backed up because we are going to format it...
Open the HP Format Tool
Start/Programs/Hewlett-Packard Company/HP USB Disk Storage Format Tool
It should automatically select your USB Drive.
Select FAT or FAT32 Under File System.
Select Create a DOS startup disk
Select using DOS system files located at and point to the folder containing the boot disk files.
Then click Start
Or you can download Win to flash ,follow the bellow link for details,
For Windows xp
For vista
Hope this helps.
Let me know if you need more information
Apr 26, 2011 | HP Compaq nc6320 Notebook
I have laptop hp compaq 6710b, it cannot boot & hard disk not detecting.
Step1: Go to the BIOS and select first boot devise as hard disk. If you get same problem or hard disk not detecting. Replace the hard disk. Step2:If BIOS is not showing replace the RAM and check it..
Feb 10, 2011 | HP Compaq 6710b Notebook
I'm receving "disk boot failure" error. Compaq wf1907 monitor
if your computer has a floppy drive and you have inserted a disk, remove the floppy disk and try booting again.
if this is not your case you can try out a couple of things
1. Check the CMOS of your computer
To do so
- Boot your computer and on the manufacturers logo window press F2 or Delete depending on your computer.
- In the bios check for the availability of a hard disk drive under the storage category if it exists look for the boot order window or menu. check i your hard disk is enabled for booting in this page.
- If all the other methods do not work and your OS is Win XP you can reinstall it in repair mode. Otherwise it would be better to visit your nearest service store.
Nov 03, 2009 | HP Compaq WF1907 Monitor
Computadora hp no lee el hard disk
usteed tiene que incertar el disco del sistema operativo y hacerle el boot de el disco.
posiblemente algunos drives se corrompieron
por eso no lee el el disco duro
Aug 13, 2009 | HP 413670-001 - HP Compaq nc6320, nx6310,...
You are missing boot file for windows to start. If you have a recovery disk, insert it and follow the on screen instructions. If you do not have the reocovery disk, you may need to reinstall windows or contact someone who can reinstall the boot files for you.
Good Luck
Aug 05, 2009 | HP 413670-001 - HP Compaq nc6320, nx6310,...
HPnc6320 Bios lockout.
download the manual from the internet, it will give you all that information.
Feb 14, 2009 | HP Compaq nc6320 Notebook
Presario 2200 won't boot up
your hard driver is broken or it can be your motherboard sata controller.
replace your hard drive and run a restore. you can get your restore cds from HP.
check if you have warranty left. then you can go to nearest hp reseller and get your motherboard or hard drive changed for free.
good luck
Aug 10, 2008 | HP Compaq Presario 2200 Notebook
Hard Drive with password protected.
I had the same problem. This is how I reset my password on a compaq or hp nc6320.
1. unplug the power cord
2. unplug the battery
3. take two screws from the ram cover on the back of the laptop (see youtube for this step)
4. open the keyboard
5. unplug the cmos battery cable (very easy to do)
6. plug power cable and turn on the laptop
7. laptop would erase passwords.
8. put everything back together.
A pleasure to help.
Javier Blanco
Mar 24, 2008 | HP Compaq nc6320 Notebook
Compaq v2000
Do u have installed recently, some software?
Try to boot up pressing the F8 button, when the menu appears select the option "Windows in safe mode" if u can boot to windows. View our software installed.
If it is not software try, boot whit the windows installation disk enter to the setup and select the option repair, u will go to a DOS prompted window (all black whit white letters) must appear "c:\"
used the command "chkdsk /f /r" let it run he will try to find any problem in the disk.
Nov 08, 2007 | HP Compaq Presario V2000 Notebook
HP Compaq nc6320 Notebook Logo
591 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
