Computers & Internet Logo
Posted on Jul 12, 2009
Can we use x-10 technology in controlling any other devices ?
Can we use x-10 technology in controlling any other devices except home appliances? from ay other devices i mean any medical devices...or any devices which are used to produce non renewable sourses of energy???
Anonymous
Level 1:
Filmmaker:
Uploaded 5 video answers.
  • Contributor 43 Answers
  • Posted on Jul 20, 2009
Anonymous
Contributor
Level 1:
Filmmaker:
Answers
43
Questions
0
Helped
13083
Points
87
X-10 uses the home riing to transmit signals (codes) that tell the receiving box to perform a function (turn on/off, dim) they can also send video or audio data. What would you want to control? I would not use X-10 to control medical devices.
I need a user manual
PDF]MICROWAVE OVEN - Whirlpool
www.whirlpool.com/.../Use%20and%20Car...
Whirlpool Home AppliancesWe have provided many important safety messages in this manual and on your appliance. Always ... Read all instructions before using the microwave oven.
Free Microwave Oven User Manuals ' ManualsOnline.com
kitchen.manualsonline.com > Kitchen Appliance
Free kitchen appliance user manuals, instructions, and product support information. Find owners guides and ... Agilent Technologies Microwave Oven Manuals.
Ap dropout
Things That Affect Wireless Router Signals
1. Many wireless routers are using the same wireless channel. Many manufacturers choose channel 6 as the default. Change to another channel. 2. Analogue video senders used to send audio and video to other TVs in the home. 3. Microwave ovens emit interference in the 2.4GHz band. 4. Wireless speakers and console controllers can cause interference with the wireless router. 5. Bluetooth devices, newer Bluetooth devices can jump to different frequencies if there is a connection problem. 6. Power cables located near the wireless router can cause dropouts and speed reduction. 7. Fish tanks will cause massive Wi-Fi shadow on the other side of the tank from the wireless router. 8. Depending upon the location of large mirrors will reflect wireless signal away your computer. 9. Building materials will block wireless signals such as plasterboards with metal foil, reinforced concrete walls and floors. Also objects near the wireless router such as metal filing cabinets and other electrical appliances. 10. Blinking Christmas lights can reduce Wi-Fi performance by 25% when it is close to the wireless router.
My wifi will not use my wifi router after upgrading ubuntu to ver 11.10 it worked before and i can use different wifi routers lspci 00:00.0 Host bridge: ATI Technologies Inc RS690 Host Bridge 00:01.0 PCI...
first make sure your wireless adapter is not disabled you can check it by running rfkill list in terminal if it is type sudo rfkill unblock wifi [second you can try activating and deactivating by typing sudo ifdown wlan0 and sudo ifup wlan0 me personly have kept to 10.10 the 11.04 seem to have a few glitches you can also check for additional drivers
4helpful
How to secure the router
HI
please find the ans.
Features
  • Firewall protection for your network
  • Parental control to supervise Internet activity
  • Works with wireless 802.11b/g adapters
  • Backward compatible with 802.11g and 802.11b devices including game consoles and digital media player
  • Secure wireless network using advanced
  • WEP, WPA, or WPA2 encryption
  • Easy to get started with D-Link Quick Router Setup Utility
Description The D-Link DIR-615 Wireless N Router provides better wireless signals for your network than existing wireless 802.11g technology. Upgrading your home to Wireless N provides an excellent solution for sharing an Internet connection and files such as video, music, photos, and documents. D-Link Wireless N products use Intelligent Antenna technology to transmit multiple streams of data which enable you to receive wireless signals in the farthest corners of your home. Not only does D-Link's Wireless N technology extend your wireless range, it also works with your existing 802.11g and 802.11b wireless devices.
Easy To Set Up:
The D-Link Quick Router Setup utility quickly configures your new Wireless N Router to get you up and running in minutes. Our D-Link Quick Router Setup walks you step by step through the installation process to configure your Internet connection, wireless network settings and security, and everything else you need to get your network up and running so that you don't have to be a networking expert to get it set up.
Easy To Secure:
The DIR-615 supports the latest wireless security features to help prevent unauthorized access, be it from over a wireless network or from the Internet. Supportfor WEP, WPA and WPA2 standards ensure that you will be able to use the best possible encryption, regardless of your client devices. In addition, this Wireless N Router utilizes dual active firewalls (SPI and NAT) to prevent potential attacks fromacross the Internet. Delivering great wireless performance, network security and coverage, the D-Link DIR-615 Wireless N Router is ideal for upgrading your existing wireless home network.
Specifications Technical Specifications Standards: IEEE 802.11n (draft) IEEE 802.11g IEEE 802.11b IEEE 802.3 IEEE 802.3u Device Interfaces: 4 10/100 LAN Ports 1 10/100 WAN Port Antennas: Dual external 2dBi Gain reverse SMA antennas Security: 64/128-bit Wired Equivalent Privacy (WEP) data encryption Wi-Fi Protected Access (WPA, WPA2) Advanced Firewall Features: Network Address Translation (NAT) Stateful Packet Inspection (SPI) VPN Pass-through / Multi-sessions PPTP /L2TP / IPSec Device Management: Internet Explorer v6 or late Mozilla Firefox v1.5 or later Java enabled browsers Leds: Power Status WAN WLAN (Wireless Connection) LAN (10/100) Internet Status Power Input: DC 5V 2.5A, through external power adapter Dimensions: 193 x 116.8 x 30.5 mm Weight: 940 grams (0.7 lb) Operating Temperature: 0ºC to 40º C Storage Temperature: -20ºC to 65º C Operating Humidity: 10% to 90% Storage Humidity: 5% to 95% Certifications: FCC Class B IC CE
1helpful
Need firmwere wytron-699
Cds burn ok except they do not appear to be finalised as they wont play on other machines. The machine shows fail on the copy but ejects ok.
I HAVE A PNY OPTIMA PRO ATTACHE 2 G AND IT WONT WORK IN MY COMPUT
then download the software, this device can run with his own program...
X10 mini controler will not turn off pool light
the unit is probably transmitting but the receiver on the lights is not getting an acceptable signal.
try placing your controller on a line closer to your main electrical panel.
Unfortunately x-10 technology is very unreliable its convenient but its also a pain in the ****.
Do the basics make sure the controller is close to your panel, make sure its not plugged into the same circuit that your appliances, computer or electronics are plugged into as they generate RF interference.
Smarthome.com sells several X-10 boosters, if your home has a 2 phase power get one that plugs into a 220v outlet that will "bridge" THE TWO PHASES.
Grand Canyon Tech
Grand Canyon Tech
