Question about LG Washing Machines
My WD16330FD can't be started.
LG Washing Machine Probl: My WD16330FD can't be started anymore. It's exactly one year old. The timerdisplay says "CL".
No button reacts to pressure. Making the machine powerless for several hours(up to 12) doesn't work either.
What to do?
jsrock516
  • 5911 Answers
SOURCE: Kenmore Washing Machine MOdel 22622100
If the sound is a grinding noise, this is usually a symptom of a gear case (transmission) going bad. However, it could also indicate a motor coupling that's starting to fail. If you look under the washer check for any drips or puddles of oil. If you find any, the transmission has begun leaking and needs to be replaced. If you find a black powdery looking substance, this is an indication of a motor coupling that is failing. I hope this may help you. Let me know what you find.
Posted on Jul 10, 2007
  • 1294 Answers
SOURCE: LG Intello washing machine, model: WD12235 Front Load
Why dont you people read the user's manual? You wil learn abt your machine, to a certain extent. Try "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds. Works for other machines...............And please rate me if helped................
Posted on Jan 06, 2008
SOURCE: CL ERROR
"CL" means Child Lock. Press and hold RINSE+ & PRE WASH Simultaneously for about 3 seconds to de-activate.
Posted on Jan 23, 2008
SOURCE: my washing machine does'nt start
Had that problem before. CL means child lock. You need to press the wash and rinse buttons together to unlock.
Posted on Apr 03, 2008
  • 112 Answers
SOURCE: LG "WM12336FD" washing machine is displaying ,CL,
I cannot find that model number in any of my LG data.
There is a button on the control panel that will say Child Lock. That button will have to pushed and held down until you hear the chime.
Posted on May 03, 2010
Lg wm2140cw washer error code cl My lg washer show cl and I couldn't use my washer
CL means that your washing machine’s CHILD LOCK is ON. You can find two buttons Temp and Options in the panel.
Turn ON the machine, press these two buttons together for 3 seconds and that’s it.
It might have a little kids face above a lock key, in between the wash and rinse buttons, hold these for 3/5 seconds and it should work.
Jul 29, 2016 | LG Washing Machines
How do I clear the CL code on my LG washing machine
The CL code stands for Child Lock. If you are unable to deselect the child lock function, then there could be a problem with the door latch assembly.
Oct 14, 2014 | LG WM Washing Machines
On an LG front loading washing machine, what does the code CL mean?
Hi Emma Haigh,
CL means Child Lock, please follow my below Tip on how to remove the setting:
L.G CL ERROR/CODE
Kind Regards
JEDMEYER1
* If you found this solution helpful, please rate it
Aug 01, 2011 | LG Washing Machines
The washing machine doesnt start at all. The displayer says: CL.
CL means "means chils lock" to disengage hold temp and echo/rapid together and this should solve the problem
Jun 21, 2009 | LG Washing Machines
Water remains in detergent drawer
bpkaplan - did you find a solutiion? I have the exact same problem with my LG Tromm WM2477HW front load washing machine. It is about 2 1/2 years old.
Nov 24, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG WM1285 WASHING MACHINE
hi Hills659.
this is all i could find out.
What does CL mean on LG washing machine?
LG Washer CL Code Definition (What does it mean?) = The CL Code on front loading LG washing machines simply means the CHILD LOCK feature is turned ON.
The CHILD LOCK feature on your LG washer is meant as a safety precaution so children are not able to change wash settings. CL is not an error code. It is indicating that the CL or CHILD LOCK feature has been turned ON and is active.
LG Washer Error Code CL How To Turn CHILD LOCK Off
Dec 17, 2017 | LG Washing Machines
LG-Trom Getting error CL .now not able to operate.after switch on it gives CL in display
Hai Idiots
ITs on CL (Child lock)
This occurs only if the power is turned off during the washing period
Press the TEMP and OPTION together for 3 seconds and it will go off
Amber
Jun 12, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My washing machine does'nt start
Mar 23, 2008 | LG WM-1480FHD Front Load Washer
CL on display panel - washing machine will not respond
CL stands for child lock to take it off press and hold TEMP and TIME DELAY at the same time and this should remove it
Dec 11, 2007 | Washing Machines
Washing Machines Logo
102 people viewed this question
Top LG Washing Machines Experts
Marvin
Marvin
Mike
Mike
reliableservice
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
