SOURCE: locate fuel filter
It is located just under the driverside door tucked inside the frame rail.
SOURCE: i want to change the fuel filter on my 2001 bmw 740i
Under vehicle, driver side, below seating area, mounted on frame in fuel line. Let me know if you have any other questions. Thanks for rating my response and for using FixYa!
SOURCE: Fuel filter and pump location
The fuel pump is located in the fuel tank while the filter is located in the hood close to the panel.
Testimonial: "Good info but what panel does he mean? "
SOURCE: i need to replace my fuel pump for my 2004 bmw 325ci coupe
Location is in the Tank of the car you might want a Pro to do this it is not safe for unexpierianced hands you can get gas in your eyes while serviceing such unless you empty the tank of contence before service you will find the area after you drop the tank to the floor it has various hoses and cable leads disconect them with precaution and note where they are for return in the future also if needed take pictures these will help to reconnect when you are done
SOURCE: Where is the fuel filter located on a 2004 Chrysler Sebring Sedan
Some of the Sebrings have two filters(one is called a sock).The sock(which all sebrings have) is located in the fuel tank itself on the pump module.If this model is the JXI then the external filter is located on the belly of the car between the tank and drivers rear seat. I hope I could help!!!
