Question about Sportsart 6300 Treadmill
I have a sportsart 6300 that keeps blowing up Q2 and Q3
    President:
  • Sportsart Master
  • 832 Answers
The bridge rectifier is shorted with gives Q1 and Q2 the appearance of being shorted and blowing the 15 amp ceramic fuse
Posted on May 13, 2010
SportsArt 6300 error display 04 -0015 help...
the power supply is receiving too low or higher currents.You must test this. Or you need to call the service tech. However try to RUN the s. calibration if you can. Otherwise reset the machine. and see the block diagrams attached.
God bless you
Dec 05, 2012 | Sportsart 6300 Treadmill
Sportsart 1080hr has power, but only red emergency stop lights are flashing. Magnetic key in place. Nothing happens if I reset the emrg stop?
1) adjust the REED switch, test for open or defective, clean it, and tight the plug or connector very well.
2) After you fixed RUN the software calibration for easy diagnose, troubleshooting. and fix it.
God bless you
Nov 28, 2012 | Sportsart 6300 Treadmill
Rane me 15 blows fuse
If at off position, fuse doesn't blow
• check shorted/leaky components after the capacitors
such as Q3, Q4 , Q5 and regulators Q1 and Q2
• or simply remove them all, put it back one at a time to find the cause
but be sure to mark , so you can put the good ones back .
Sep 10, 2012 | Rane Me 15 Graphic Equalizer Eq
Fuse blows at the onset of starting the track
disconnect the motor from the motor control board under the motor hood ( follow the wires from the motor) and turn the machine on. If it lights up ok then the motor is blown.
Apr 13, 2012 | Sportsart 6300 Treadmill
Need an owners manual for A sports art 6300 TR 63
Go to SportsArt America.com click on support drop down and click on manuals click on owner's manuals scroll down treadmills and half way down you will find t6300 owner's manual
Sep 16, 2011 | Sportsart 6300 Treadmill
Hello. My sportsart give's error 7 ? I don't now what the problem is. Can you discribe the problem en the solution for this? Thanks Gert Jonker
When I turn on the machine it beeps and reads Error 7 on the screen. Do you have a support phone number for Australia
Feb 12, 2011 | Sportsart 6300 Treadmill
15A fuse going out. Replaced 3 with no success, spark on low end of board after about 5 seconds, thenn fuse went.. Unplugged power wires to the lower board, powered up treadmill and the fuse survived. ...
You are going to need a motor controller, or find someone who can repair the one you've got there.
If it blows the fuse immediately on power up, it may require a full wave bridge rectifier replaced on the controller. If it blows when the start button is pushed, it might be a MOSFET or SCR found on the motor controller..
Sportsart fitness can be reached by phoning 1-866-709-1750. The website is found at
http://www.sportsartamerica.com There you can find a dealer/service depot in your area.
Dec 19, 2010 | Sportsart 6300 Treadmill
SPORTSART 6300 SHOWING E 1
Error 1 come up when the drive motor is not moving. Unplug unit then remove motor shroud then plug unit back in and you will see a circuit board with multiple lights. On Lower portion of the board you should be able to see a amber LED this is your speed sensor light . To test the speed sensor just manually rotate motor fly wheel ( where Drive Belt is visible) and you should be able to see the amber light flickering that means speed sensor is good. Next thing to do is unplug unit and check the motor they sometime get stuck in their chamber so be gentle pulling them out and blow out the excess carbon material out of motor wear a mask when doing the black dust can be much then re assert motor brushes and it should take care of problem. If they are worn (less than 3/8 in. in length) then call Sports Art @1-866-709-1750 the people their are good to work with and any further question they will be able to answer.
Feb 11, 2010 | Sportsart 6300 Treadmill
Sportsart 6300 Treadmill Logo
336 people viewed this question
Top Sportsart Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Steven Brandon
Steven Brandon
GymWorld
GymWorld
Level 1 Expert
Are you a Sportsart Exercise and Fitnes Expert? Answer questions, earn points and help others
