My antenna light stays on even after I have realeased the mike
Try checking the SWR's on channel 1, 20, and 40. The SWR's will change from the low channels to the mid channels to the high channels. The key is to make sure that the SWR's are around 1 or less at all three points.
If the light goes out when checking one of them, then the problem is most likely the SWR's. If the light stays on when checking these channels, the issue might still be the SWR's but I would look at the grounding on the antennas. When holding the talk button on the mic and switching from calibrate to swr, can give a false reading. This is due to the calibrate circuit remaining open until you release the talk button.
Take the SWR reading by releasing the Talk button on the mic after calibrating then pressing the talk button again after switching back to SWR. This will be the most accurate reading.
From everything you described, I would be looking for a grounding problem with the antennas or coax, possibly even a rub though on the coax somewhere in the dash.
