Question about HP LaserJet 1100 Printer
Printer won't print
Having same problem as another person on this site. Pressed the big button at left of printer - prints only the test page. Won't print anything else...even turned it off for 1 min...Nothing.
Please help.
Re: Printer won't print
The secret in the case of "smithprint" (me) turned out to be a loosening of the plug from the computer connection when I removed the jammed page. Pushed it in properly and everything worked properly.
So first step is always to check the cable connections - elec. supply and computer.
Elementary, but there are probably more ignoramuses out there besides me.
Posted on Apr 28, 2008
Had same problem as Guest posted on April 15, 2008. Using a solution found at another site, I:
1) unplugged power from the printer
2) disconnected printer cable from computer
3) plugged power back into the printer
4) printer completed its power-up steps and green light was solid once it finished (orange light was not on)
5) reconnected printer cable to computer
After that the printer worked great! Best wishes!!!
Paper start to feed but after some time not working
Posted on Dec 15, 2007
Hp LaserJet 1100- Toggle/ Re-plug in the power
That should print out the test page.
If it wont print anything else, then take out the catridge/toner, and check to see if anything is stuck in the inside, like little white plastic pieces. That should do it. It seems to be a manufacturing problem.
Posted on May 29, 2008
0 characters
3 Points
How do I make a test page for my printer to check color.
You need to clarify :
1. Your printer cannot print color even though it prints color well from a test page;
2. Your printer cannot print color in a test print page.
If it is the first one, then you have to set it properly in Window Print Configuration page of that printer;
If it is the second one, then you have to check whether you have installed the color ink cartridge properly in the printer. If the color ink cartridge is installed properly, try to replace another new color ink cartridge. Finally it is still not work, then you have to bring back to the repair center.
Jan 19, 2013 | Dell V715w All-in-One Wireless InkJet...
Printer won't print properly (missing lines)
try to print a test page with the printer itself , in the users manual there should be a way to do that without connecting it to a computer.
if the test page is OK ,than try to replace the cable and/or print from another comp.
if the test page fails ,you can try to load a new firmware from the manufacturer site.
good luck.
Jan 12, 2013 | Printers & Copiers
My HP Deskjet F380 will only print blank pages. There is plenty of ink left in both cartridges. I've been on the HP help site. It didn't help. It won't photocopy either. It printed the top part...
the body of text of the test page is black ink. From what you describe, the print heads are clogged. Most HPs use cartridges that have the head built in, but if not used for an externded period they can dry up and clog.
Try repeated head cleanings (10 or more) see if any change. If none, try new HP ink cartridges
Jul 12, 2011 | HP DeskJet F380 All-In-One Printer
Printer won't print. I went to printer and it says there are 9 items to br pringted in queue but they won't print Printer says it is ready
Good Day Nanawhit!
That happens all the times when first print job encounter a problem and stops printing and it was followed by series of print jobs. Some reasons for stop printing could be a printer out of paper and printer not set as default printer.
The best way to fix it is to cancel all pending jobs. When print jobs window is cleared off pending print jobs, restart your PC and your printer. Then go to your printer and make sure it is the default printer.
After that try printing a test page. Once a test page is successful, you can now print as many as you want.
Jun 10, 2011 | Lexmark X2670 All-In-One Printer
My HP deskjet 2050 all-in-one printer only shoots out blank paper and won't print. It used to say there was no paper in it, which there was. It scans & prints just fine - just won't print...
Any error messages on the printer digital screen or the desktop? I take it the "The ink is fine" means that there is ink in the cartridges!
Try a test print via the Control Panel> Printers and Faxes> properties > Print test page.
May 31, 2011 | HP PSC 2210 All-In-One InkJet Printer
I need your help my printer quit printing, I was low on ink and it quit printing after I printed a page. I changed cartridges and it still would not print, so I swapped cartridges with a different printer...
So it prints the self test (test page) or not?
If nothing is printing from at all (printer moves likes it is printing when in operation, but no ink hitting paper) there may be a blockage on the jets or the information is not getting to the printer properly if these same cartridges work on another printer.
I would lift lid and carefully check each one and wipe with a thin cloth the remove any clotted ink and dirt.
You have already reinstalled the drivers, but I would get the latest ones you can from
Finally I would cold reset the printer - usually holding the go button pressed in while hitting the power button on and off - will reset rthe calibration and give you a better chance of fixing.
Also if you have the cartridges for the wrong model, they may physically fit in, but the chip on the cart will tell the printer theres a problem and won;t print.
- Check cartridges - off the top of my head (please check!) you should be using HP 45 for Black and HP 68 for Colour (if using a different brand, fine but the numbers are thee same)
- Download latest drivers
- Cold reset printer and install again
Good Luck
Mar 14, 2009 | HP DeskJet 940c InkJet Printer
Printer DeskJet 820Cse didn`t work
test page printing but doc files not printing....
HP DeskJet 6940
Sep 26, 2008 | HP Deskjet 6940 InkJet Printer
Auto test page on the HP F 380
I don't know this personally, but you should be able to hit the power button and turn it off right after you load the cartridges. then power back on. That might do the trick.
Dec 08, 2007 | HP DeskJet F380 All-In-One Printer
HP LaserJet 1100 Printer Logo
242 people viewed this question
Top HP Printers & Copiers Experts
Brian Sullivan
Brian Sullivan
Are you a HP Printer and Copier Expert? Answer questions, earn points and help others
