Question about Samsung CLP-510 Laser Printer
How do i reset the toner cartridges
I know you can reset the cartridges. someone told me to use tape across the chips on each cartridge but this hasn't worked for me!
does anyone have any idea hos to get round this problem without buying reset chips and having to solder. I am a lady and no good with soldering irons!
please help.
  • 3 more comments
  • Anonymous Nov 30, 2007
    Samsung CLP-510 is leaving black ink on the left side of document.
    Troubleshooting cleaning heads of reseting catridges
  • SueB2012 Dec 03, 2007
    I tried the tape over the contacts and the 'uncheck consumables' and it looks as if the printer is going to work, but then just sticks on 'processing' and doesn't actually print anything out. Any suggestions gratefully received! Thank you
    I've had CLP 500 cartridges converted to CLP 510 ones apparently - new chips put in. Still not working. Tried the tape over the chips and 'uncheck consumables' and it looks as it will work, but then doesn't actually print and gets stuck at 'processing'. Any help gratefully received! Thank you
  • happiness_gr Oct 03, 2008
    I'm maintaining 2 samsung clp 510 printers at work. I was trying to
    find a way to completely empty the toners before having to replace them
    when I found this forum.
    The tape thing was very helpful and it
    had worked like a charm on one of them (big thanks are in order here :)
    ). My problem is that the same method does not work on the other
    printer :\ I follow the same method, ie power down, press n hold menu
    key, power on while holding, but I never get the "uncheck consumable
    mode" message. The printer just proceeds to initializing and still
    shows the "replace toner" messages.
    I noticed a difference between
    the two printers. When they power on they display on the screen some
    info. The one that got "fixed" displays "os 1.17" and "engine 1.18",
    while the other one shows "os 1.15" and "engine 1.17". I tried
    downloading and installing the latest firmware from the samsung
    website, but nothing changed.
    Can anyone help? Those of you that
    used the tape method and worked, could you tell me which version os and
    engine your printer shows?
    Thanks in advance.
    Novelist:
  • 217 Answers
You simply can't reset the chips by using tape on the contacts.
The 'chip' on the CLP-510 cartridges has a counter that is updated by the printer when it is used (even if it is only a single dot of that colour).
The ONLY way to reset these chips is to use s special device that writes data to the chip placing a ZERO into the page counter. Or to solder in a new chip. FACT.
The 'chip' also identifies the colour of the cartridge and its capacity. If you cover the contacts the printer doesn't know a cartridge is there, can't tell what colour it is, and can't tell what the capacity and current page count are.
If you use (say) a Cyan chip in a Black cartridge, it just won't work.
Chip resetter boxes are not cheap, being around £150, as they are intended for the cartridge re-manufacturers.
If you want to be able to re-fill your Samsung CLP-510 cartridges yourself, you'll just have to learn to use a soldring iron.
Posted on Jan 11, 2008
Put tape across the 3 contacts on the side of the cartridge, reinsert cart into printer, restart printer, holding down the Menu key until a message "Uncheck consumables" appears, then let Menu key up.
Posted on Dec 01, 2007
    New Friend:
    Problem Solver:
If you own a Raspberry Pi, then you can also use this open source tool to reset the toner cartridge:
http://www.netzgewitter.com/projects/speer-samsung-printer-eeprom-resetter/
how do i reset the toner cartridges - d4c1e76d-964e-45ae-ba90-0af12ba3525d.jpg
Posted on Dec 08, 2014
I'm no expert, just reporting what i've done: my method above about the tape does work; however, if you do it with ALL 4 carts, it will result in the endless "processing" message and no printing. So yu will need to get a chip resetter (by buying a set of refills that includes one) or use the Dunfield method (Google it) which is fiddly, but did work for me.
Posted on Jul 31, 2008
Just go to Ebay and buy the chip resetter, works great every time.
Posted on Dec 28, 2007
How to reset expired hp 02 cartridge
I'm not sure what you mean by "reset" and whether you are speaking of ink jet or laser cartridges. From my experience all HP laser cartridges have a small chip (with a little circuitry) that counts down your pages and when it decides your cartridge is out of toner you cannot "reset" that chip, you can only replace it, so like when you refill the cartridge. Some of the HP laser printers let you override these toner level chips (my HP 1518ni does) but in many laser printers you are stuck when the chip counts down to '0' pages. Some printers will run if you remove the chip from the cartridge but from my experience most will not.
Ink jet cartridges are somewhat similar but I gave up on ink jet printers several years ago. I know for some brands (Epson?) you can buy a small tool that somehow resets the cartridge chip (so if you refill cartridges yourself); possibly there is something similar for HP ink jet cartridges.
Feb 13, 2015 | HP Office Equipment & Supplies
Replace drum in xerox phaser
asic technical parameters forToner cartridge chip of Xerox Phaser 3450B:
chip-b.jpg" ]
Version: No area limited
Yield: 5,000-10,000.
Printers Model compatible: Xerox Phaser 3450B
Toner cartridge Model: Xerox 106R00687-BK and Xerox 106R00688-BK.
Manufacturer regulations pages yield ofToner cartridge chip for Xerox Phaser 3450Bis 5,000-10,000 then printer do not print andDrum chip for Xerox Phaser 3450Bhas mission paper pages count.You should resetDrum chip for Xerox Phaser 3450Bcaused by following reasons:
And then, you can choose one in three following plans: replace Toner cartridge, replace Drum chip or reset Toner cartridge chip.
1.Replace new Toner cartridge for Xerox Phaser 3450B:
- If you choose plan replace Toner cartridge then cost is too high. Each Toner cartridge for Xerox Phaser 3450B (Xerox 106R00687-BK and Xerox 106R00688-BK Toner cartridge) costs about $150 - $200
- With replace new Toner cartridge solution is not optimal, because the price is quite expensive.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new unit.
2.Replace new Toner cartridge chip for Xerox Phaser 3450B :
khe-chip-b.jpg" ]
- If you choose plan replace Drum chip then cost higher than reset chip. EachToner cartridge chip for Xerox Phaser 3450Bcosts about $6 - $10/color.
- With replace new Toner cartridge chip solution is cheaper replace new Toner cartridge.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new Toner cartridge chip.
3. Reset Toner cartridge chip for Xerox Phaser 3450B
If you choose plan resetToner cartridge chip for Xerox Phaser 3450Bthen that is best plan. It cheaper than replace Toner cartridge or replace Drum chip
The phenomenonToner cartridge chip for Xerox Phaser 3450Bout of count are printer do not print and display error on the LCD monitor:
-"Drum low", "Drum eppty", on monitor laptop or desktop appear yellow exclamation mark corresponding color, on monitor printer report Drum empty.
-"Tone life end", "Replace new unit"
- "The x unit an error". In that "x" is color of Toner cartridge or code of Toner cartridge
How to fix the errors:"Drum low", "Drum eppty", on monitor appear yellow exclamation mark corresponding color,"Tone life end", "Replace new unit", "The x unit an error"? cheaper, the most effective.
We use unismart device toreset Drum chip for Xerox Phaser 3450B
Unismart is a device reset Drum chip. Unismart can reset for many Drum chip of manufacturers: Samsung, Hp, Canon, Epson, OKI, Xerox ...
Unismart system is designed to offer a complete solution for writing, resetting, testing various chips with the combination of Unismart Box and Unismart chips. Unismart include: unismart box and test head, power adapter, Data wire, flat writer.
unismart1.jpg" ]
Test head is used for data transmission between Unismart Box and Unismart chips. There are 20 types of test heads designed according to different chip shape, which can be used for operation on all chip models that
current Unismart system supports. Please choose the right test head in accordance with the PCB code. Some PCBs share a same test head, which is clearly indicated in the chip compatible list.
In Case You Still Having Problem Then Follow Us For On :Xerox Printer Support
Jan 23, 2014 | Xerox Phaser® 860, 8200 Standard Capacity...
Installed new toner cartridge on hp laserjet 2300 and getting install cartridge error on LCD
Its possible that you just got a bad toner cartridge. There is a chip on the toner cartridge that could be bad. I would shut the printer off and then back on. Confirm that the tape has been removed then firmly reset the toner cartridge back into the printer. If that doesn't work then try another or the previous cartridge. This could be an issue with the printer but I find that very unlikely.
Aug 31, 2010 | HP LaserJet 2300N Printer
Do the reset chips really work on the cartridges of HP 2500N laserjet printer
Yes, reset chips really work on laser printer cartridges, if you have a know good source for the chips and if you know what your doing, you can't put a new chip on an old cartridge, the chip is what registeres how may prints you will get out of the cartridge if you put a new chip on an old or 1/2 empty cartridge of course it will say it's full but then try and print.It will register as a full cartridge but it can only print with the amount of toner that is actually left in the cartridge, be careful there are alot of remanufactures out there that don't put new chips on or that do but don't fill the cartridge full, or replace all the wipers and drums, they just dump some toner in and say here you go, Only buy your remanufactured cartridges from a reputable company, do your research on them first or you'll be sorry
Aug 14, 2010 | HP LaserJet 2500N Printer
I have M1522n HP Laser printer and keep getting message 10.1000 supply memmory error can anyome explain what this means
The HP LaserJet 2300 toner cartridge has a smart chip on the top left side. This chip tells the printer when the toner is low.
Recycled toners do not or can not reset the chip, therefore when you use a recycled toner you may get toner low messages although the toner is good.
Also, you may get the 10.10.00 error. We have devised a work around to fool the printer into not displaying the message.
Place a stip of opaqe tape or paper or the chip. When the printer detects a non-standard cartridge press the green (go) button. It will then reset the LCD to Ready.
Found this info on a recycled manufacturer site.
Feb 12, 2010 | Office Equipment & Supplies
Black toner empty!!!! After refilling all of the dell 3110cn toners myself, I have re-sealed the toner input with some duct tape (fairly small, similar size to original seal) and inserted all the toners,...
This cartridge has a chip which stores the pagecount (for that cartridge).
You can re-fill these as much as you like, but unless you change the chip (it's NOT resettable) the cartridge will still think it is fully used.
Chips are available (different ones for each colour, and different again for the standard capacity and high capacity). You'll find them on a certain internet auction website.
Jan 05, 2010 | Dell 3110cn Laser Printer
I am trying to reinstall the black ink cartridge to a hp2605dn and it keeps saying the error 10.1000
I found this info on the web for you, guessing you are using a recycled or generic cartridge:
Also, you may get the 10.10.00 error. There is a work around to fool the printer into not displaying the message.
Place a strip of opaque tape or paper on the chip. When the printer detects a non-standard cartridge press the green (go) button. It will then reset the LCD to Ready.
No guarantees but it seems plausible.
Jun 19, 2009 | HP Color LaserJet 2600n Printer
Low toner/toner empty
Toner cartridges have more then just "toner ink" they also have developer and sometimes a chip that says how many times the cartridge has been used.
Also some refill places can be a bit dodgy so I know it might not seem like the best thing right now but try buying a real replacement cartridge and if that doesn't do it beg and plead to return it saying it was the wrong model.
If it does fix it then you might have a bad cartridge that either has the "chip" or the cartridge itself is simply worn out and in need of developer as well.
Apr 16, 2008 | Brother MFC-8440 All-In-One Laser Printer
Samsung CLP-510 Laser Printer Logo
5,324 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
