Question about HP iPAQ 510 Voice Messenger Smartphone
Need a bluetooth pin for Samsung SGH-E250 to pair it with hp iPAQ 514
BearWeb
  • 357 Answers
SOURCE: SAMSUNG SGH-E250 puk blocked
Hi everyone
Every PUK code is unique so nobody can tell you your PUK number, but i will tell you what you can do!
1) If you still have your packet that your Sim Card came in, you should find your PUK number in there, if you don't have the packet, please read bellow.
2) You must get a phone that is on the same network as your phone and call the networks Customer Care and ask them for your PUK number, they will ask you for your phone number, then they will tell you your PUK number. Once you have done this, you will be able to reset your Pin number so you will be able to go into your phone again.
Please also remember to give me a good rating on my profile.
Kind regards
Dustin Ellse
Posted on Jun 26, 2008
called my T-mobile Customer Service and talked to another lady that helped my out and finally got it for me
Posted on Jul 09, 2008
SOURCE: HP iPAQ Bluetooth GPS, IPAQ has no signal
I noticed now that the 'green lite' on my receiver does not come on at all. I can not find where I can get a replacement receiver
Posted on Sep 10, 2008
pongta_rajku
  • 55 Answers
SOURCE: download Java games free to samsung SGH E250
at first go to the google.then write in edit box (free java games for samsung sgh e250)
ok thank u
Posted on Apr 09, 2009
NEXTLAB
  • 58 Answers
SOURCE: charging pin of my ipaq damaged
hi
I can fix your sync&charge connector very fast in our lab.
you can send your device to us and we will charge you by paypal and return it to you in less than one week.
thanks
Gery
ipaq Lab
Posted on Jul 07, 2009
What is Bluetooth PIN or pairing code?
bluetooth pairing or PIN is a secure way of connecting two unit exclusively
Sep 03, 2015 | Samsung Sgh T401g - Black straight Talk...
I need a driver of my hp ipaq 514 voice messeger so i can connect my phone into a pc
You an download the driver from hp to your laptop / PC and connect the 514 via USB cable .the link is http://h20566.www2.hp.com/portal/site/hpsc/template.PAGE/public/psi/swdHome/?sp4ts.oid=3360097&spf_p.tpst=swdMain&spf_p.prp_swdMain=wsrp-navigationalState%3DswLang%253D8%257Caction%253DlistOS&javax.portlet.begCacheTok=com.vignette.cachetoken&javax.portlet.endCacheTok=com.vignette.cachetoken Cheers Brian
May 13, 2011 | HP iPAQ 514 Smartphone
How to pair your phone to the bluetooth on th kenwood kvt-514
Go into your Setup menu and scroll down to bluetooth settings.
From here you should see a screen that says "HFP connect device", "A2DP connect device" and "Receiver pin code".
Press the "Set" button to the right side of "A2DP" and it should bring you to another screen that says Pair device.
Go onto your phone settings and make sure you have your bluetooth setting on your phone set to "make discoverable"
Press the search button on the Kenwood unit on the right side and it will start scanning for available devices in the vicinity
Also press the Search button on your phone so it also starts scanning.
Next you should get a message on both your phone that shows the Kvt-514 and also a message on the Kenwood that shows either the model of your phone or your "nickname" (if you named your phone)
Select the Kvt-514 on your phone and it will prompt you for the pin code that was on the first bluetooth setup screen...most likely 1111 (you can also set a different pin code using the "set" button to the right side of the "Receiver Pin Code" on the first bluetooth setup screen)
Enter the Pin code and select "Pair" on your phone.
You should get a confirmation on both the Kvt-514 and your phone that they are connected and you're good to go.
Apr 02, 2011 | Kenwood KVT-514 Car DVD Player
My friend gave me his bluetooth but i need the pin to connect it to my phone and i cant get it .how can I pair it to my phone without using a pin or making a new pin?
The pin or the passkey is "0000". To pair the SGH-T749 (Highlight) handset with a Bluetooth Device follow the steps below:
  1. Place the Bluetooth device in discoverable mode
  2. From the standby screen, press on Menu
  3. Press on Settings
  4. Press on Bluetooth
  5. Search for the Bluetooth device by pressing on Search, located at the bottom
  6. Press on Yes to Activate Bluetooth and start the search
  7. Press on the desired Bluetooth Device (if not shown press on the left or right arrows until displayed)
  8. If prompted, press the Passkey "0000" then press on OK
  9. You will get a brief message stating connecting followed by connected, if prompted press OK again
Note: The first time you try to pair with another handset, you and the owner of the other handset must enter the same PIN. Once the handsets have been paired, you will not need to use the PIN again.
Mar 30, 2011 | Samsung OEM Travel Wall Charger for...
When I try to pair my Samsung e250 with my P.C. I get a pop up message that requires a pairing code and I don't know what that is and I don't even know where to get it because this e250 is a second hand I...
Mahamban,
Paring code is nothing but any number given as code to both the bluetooth devices. Just any number. Both the devices will ask for the code. Please give the same number at both the places.
Feb 08, 2011 | O2 Samsung SGH-E250 Cellular Phone
I need the factory pin code I have lost it
Hi,i think you have problem with the code used in pairing your bluetooth device,the default code to connect to your bluetooth device is "0000".
Good luck
Jun 11, 2010 | Samsung SGH-U600 Cellular Phone
Unable to pair samsung t729 blast with bluetooth on hp nc8430
Read the manual that came with your device. It should tell you in the manual what the default pin is. You can try 0000, or 9999, or 1111 just for the heck of it...it's usually something like that. (not sure on the number of digits for your device, but I think it would be 4)
Jan 13, 2010 | HP Compaq nc8430 Notebook
How to transfer game on Samsung SGH E250 on
You can only download the games thru GPRS,E250 do nat have a facility to run games when tranferred by bluetooth or data cable
Feb 26, 2009 | Samsung SGH-E900 Cellular Phone
SGH-E250 internet access via data cable or blue tooth to PC
You have to buy a data cable or use bluetooth.Create a dialer which dials *99# using your samsung modem over bluetooth
Dec 11, 2008 | O2 Samsung SGH-E250 Cellular Phone
HP iPAQ 510 Voice Messenger Smartphone Logo
378 people viewed this question
Top HP Cell Phones Experts
D. E. Hev
Andrew Taylor
Andrew Taylor
Gil Shultz
Are you a HP Cell Phone Expert? Answer questions, earn points and help others
