Question about Zenith Analog to Digital Audio Converter
I installed the zenith Digital converter box lastnight..used an digital amplified indoor antenna..only got 5 channels but today its not recieving signal at all and i bought another indoor antenna thinking it was the problem...obviously not and zenith has the simple install..
  • 78firebird Jul 17, 2009
    Thanks "rcirone203" for that bit of advice..it was very helpful! One would think that the switch between analog to digital might be a bit less time consuming, but then i am talking about the goverment! Again thanks...
    Sniper:
  • 70 Answers
I understand your issue as not getting the Digital reception from your converter box. The antenna plays an important role in what you can get. If you still have the Amplified antenna try to reduce the amplification and readjust the antenna positions. You might have to do this several times until you get it right. Also, if you live in a city and not a rural location do not use an amplified antenna and see if it is any better.
Good Luck.
Posted on Jul 16, 2009
Is the Ematic AT103B Converter Box compatible with Suddenlink cable/digital service?
No, the Ematic AT103B is an over-the-air digital ATSC tuner and will also can convert the digital signal to analog NTSC for older TV tuners. It will not work with any cable service and is for "cord-cutters". The AT103B requires an antenna to receive your local OTA channels. Depending on where you live, you may get some channels with an indoor antenna. You will get better reception with an outdoor antenna. See http://www.tvfool.com or http://www.antennaweb.org for details on the channels you can receive with an antenna pointed in a particular direction.
The Ematic set top box does provide an HD signal output and a DVR (time-shift function) so it is more advanced than the first generation OTA converter boxes. The original (available with the government coupon) converter boxes only gave an SD output.
I hope this helps.
(antennaweb.org gives a very conservative list of available channels but assumes an external antenna. tvfool.com lists the channels that are likely to be received with a variety of antenna strengths. An antenna signal amplifier can improve the reception. (Digital stations will not be seen if the tuner can't lock onto the signal.) However, when the amplifier fails, you may find some channels will not be received at all.)
Dec 08, 2016 | Televison & Video
Esa tv digital to analog
Hi.I assume you can watch some channels, using your indoor digital antenna. As far as I know, you need an intermediate "box", or interface between the cable TV coming in, and the decoder. This has to be installed by the cable company. Between the decoder and the interface, there are two connections. One signal connection and one UTP wire connection for communication between both units.At least, that's how it works in Belgium and most other countries.
Jun 24, 2014 | ESA ET427E 27" TV
Input signal.
You should be able to connect the TV to the antenna without the tuner converter box. If you still do not get signal you may need some type of signal amplifier between the antenna and TV. Hope that helps.
Dec 08, 2013 | Zenith Dtt901 Digital Tv Tuner Converter...
FixYa: Thank you for choosing to chat with an expert. FixYa: Please describe your Flat Panel Televisions problem in detail so we can match you with the best expert for your needs. I have got a TV...
You will not find any channels with this old TV. All channels in the USA switched to digital 1 1/2 years ago. You will need to connect a digital converter box to get any channels.
Feb 27, 2011 | Zenith SY2768S TV
Terk od amplified indoor digital antenna installed after install of wintv-hvr 1600 internal hdtv card. win7 opens, followed instructions to scan for atsc digital tv.....NO CHANNELS FOUND. cables...
Unless you are very close to the TV transmitter aerial it is very unlikely that you will get adequate signal for digital TV with an indoor antenna. Check with your neighbours to see what they use and where the nearest transmitter is.
Unfortunately, with indoor an antenna, the amplifier also amplifies any electrical interference from other devices in the building.
First step would be to try taking it outdoors (use an extension cord to get well away from any buildings, trees or large metal objects that could block the signal).
Feb 09, 2011 | Terk FDTV1A Flat Digital OmniDirectional...
I get no stations on my tv
Use an Antenna that Provides Good Reception of All Channels
  • Most existing antennas used by consumers will provide good reception of DTV signals. (Before making any changes, try your existing antenna first to see of it allows you to receive all the stations you normally watch.)
  • For watching DTV signals, you will need an antenna that provides good reception of both VHF signals (channels 2-13) and UHF signals (channels 14-51) to reliably receive all of the digital signals broadcast in your area.
  • Many antennas are designed only for reception of either VHF or UHF signals (but not both). For example, the commonly used “rabbit ears” indoor antenna is only suitable for receiving VHF signals. To receive UHF signals, an indoor antenna should also include a wire loop or other feature for reception in that band.
  • The reception capabilities of TV antennas also vary considerably, so be sure to talk to retail consultants and look at information on the packaging and/or the Internet to make sure that any new antenna you may choose provides good reception of both VHF and UHF channels. In addition, if you use an indoor antenna and receive signals on VHF channels, you may need to use an antenna with amplification.
  • Many antennas currently being sold as “HDTV Antennas,” perform best at receiving UHF signals; some of these models state that they provide reception of signals on channels 7-13 but actually perform less well receiving those channels. If you obtain one of these antennas, be sure it provides good reception of all the VHF channels as well as the UHF channels.
  • To check for the DTV signals that are available at your location, use the DTV Reception Maps available at www.fcc.gov/mb/engineering/maps.
Check Your Connections
  • Check that your digital-to-analog converter box or digital television is connected properly. Make sure your antenna is connected to the antenna input of your digital-to-analog converter box or digital television. If using a digital-to-analog converter box, also ensure that the antenna output of your converter box is connected to the antenna input of your analog TV. Refer to the owner’s manuals of your components if you are unsure of the proper connections.
  • Ensure that your components are plugged in and have their power turned on.
  • If you have a digital-to-analog converter box, tune your analog TV to channel 3. You should see a set-up menu or picture displayed on your TV screen. If you do not see a set-up menu or picture, tune your TV to channel 4. If you still do not see a set-up menu or picture, recheck your connections.
Perform a Channel Scan
  • Digital-to-analog converter boxes and digital televisions have a button, usually on the remote control, that is labeled “set-up” or “menu” or some similar term. Press that button to access the set-up menu. Using the directional arrow buttons on your remote, scroll to the option that allows you to perform a “channel scan.” The channel scan will automatically search for digital broadcast channels that are available in your area. Consult the owner’s manual of your digital-to-analog converter box or digital television for detailed instructions on how to perform a channel scan for your device.
  • Once the channel scan is complete, you will be able to tune to the digital channels received by your antenna. You should perform a channel scan periodically to check whether additional digital channels have become available.
Adjust Your Antenna
  • Small adjustments to your antenna can make a big difference in the number of digital channels you can receive. If you have an indoor antenna, try elevating it and moving it closer to an exterior wall of your home. After adjusting your antenna, perform another channel scan to see if your reception is improved.
  • While adjusting your antenna, it may be helpful to access the “signal strength meter” on your digital-to-analog converter box or digital television to determine whether your adjustments are improving the signals’ strength. The signal strength meter is usually accessed through the menu feature on your remote control. Refer to the owner’s manual of your device for detailed instructions on how to access its signal strength meter. Remember to do another channel scan after you have adjusted your antenna.
  • Television stations broadcasting in digital use both the VHF band (channels 2-13) and UHF band (channels 14-51). Many indoor antennas use “rabbit ears” for the VHF band and a “loop” or “bow-tie” antenna for the UHF band. Make sure you are using an antenna that covers both the VHF and UHF bands and have connected it properly.
If You are Still Having Difficulty:
  • Until June 12, 2009, some stations will be operating at reduced power levels. If you are not receiving certain digital TV stations, this does not necessarily mean there is a problem with your antenna or digital-to-analog converter box or digital television. Check with the TV station to find out whether they are planning changes that will improve reception.
  • When an analog TV signal is weak or receives interference, static, snow, and distortion will often appear on the screen. Digital broadcasting will provide a clear picture; however, if the signal falls below a certain minimum strength, the picture can disappear. This “cliff effect” means that if you watch analog TV stations that have static and distortion, you may have to adjust or upgrade your antenna system.
  • Simple indoor antennas provide minimal performance that may not be suitable for your location. If you are unable to obtain satisfactory DTV reception with your current indoor antenna, you may wish to obtain an indoor antenna that includes features for better reception of UHF signals, as well as VHF, and/or an amplifier to boost the received signal (often referred to as an active indoor antenna).
  • Generally, an outdoor antenna will get better reception than an indoor antenna. However, the performance of outdoor antennas can degrade over time due to exposure to the weather. If you are having problems, check for loose or corroded wiring, broken antenna elements and that the antenna is pointed in the right direction.
  • Try to keep the length of wire between your antenna and digital-to-analog converter box or digital television as short as possible for best reception.
  • “Splitters” that are used to connect a single antenna to multiple digital-to-analog converter boxes or digital televisions reduce the amount of signal available to each device. If you are having problems, check whether reception is improved without the splitter. In some cases an “active” splitter that includes an amplifier can solve the problem.
  • If you are near a station’s broadcast tower, reception of that station, as well as other stations, can be impeded by strong signal “overload.” Consider using an “attenuator” or removing amplifiers to improve your reception.
  • If you decide to replace or upgrade your indoor or outdoor antenna, many types are available from electronics retail stores at a variety of prices. Websites such as www.antennaweb.org provide information on the locations of broadcast towers and the types of outdoor antennas appropriate for the stations you wish to receive. If you need assistance with upgrading your antenna system, check with a local antenna retailer or antenna installer.
Hope it may helps:
Regards:
VOTIT
Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
Poor reception on atsc portable tv
an external or outside antenna will improve the amount of stations picked up and maybe a amplified antenna will help
but the boxes they sell seem to do better in reception even with only a rabbit ear antenna.
I use a box on my 32in LCD because the internal tuner just does not get all the channels without having to get up and move the antenna and the outside antenna , well I'm not going to go out there to move it all the time , and the amplified antenna I still have to keep getting up to move the antenna
so in all the box( "zenith","digital stream"are good , have yet to test others) works the best in recieving the digital channels without much worry of the antenna
Mar 13, 2009 | RCA 9V345T 9 in. Portable Television
IS MY TV DIGITAL?
yes you will. either install an outside antenna or get a good amplified indoor antenna. try your old antenna first, but when your picture freezes or it says something like " weak signal " you will need that new antenna
Jan 24, 2009 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Insignia digital tv converter/indoor antenna no signal
Ok first I can save you some money. Take your "HDTV" antenna back. There is nothing different about the antennas needed receive analog and digital signals. If you got reception without your converter box, use the same antenna with your converter box.
Next let's see if there is a problem with the box. Hook up a television with the antenna. How many stations do you get? Now hook up the same television & antenna, but this time put the converter box between the antenna & the TV. Do not turn on the box. Now how many stations do you get? If the number is different, the box is not allowing the antenna signal to pass through. That is bad. You want your signal to pass through the box so you can still pick up stations that don't broadcast digitally. Some areas of the country will not be covered by digital stations from all major broadcasters when the changeover happens in Feb.
My suspicion is either you did not have the antenna hooked up to the converter box when you searched for channels OR you are in an area that is not yet broadcasting digitally.
I hope this helps you solve your problem. Thank you for using FixYa and feel free to add more questions here by using comments.
Jan 09, 2009 | Insignia Digital-to-Analog Converter for...
No antenna reception with digital converter box.
Hello Faznmc,
I have found that with an ordinary antenna connected to the converter box it can receive nearly all channels, however I have run into cases where I had to use an amplified TV antenna to pick up signals. I have started telling folks that when they install their converter boxes to try to use the plain old rabbit ears antenna, but if that does not work, use an amplified antenna, and that usually does the trick.
I hope this helps
Thank you,
Shuttle83
Nov 02, 2008 | Televison & Video
Zenith  Analog to Digital Audio Converter Logo
259 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
