Question about Kenmore HE2 Plus Front Load Washer
How to fix machine when it is saying F22 error.
My cabrio dryer is overheating. I have replaced thermistor, thermostat, replaced control board but get f22 error code,
Dryers overheat because of reduced airflow. You need to fix that first. Remove the rear vent completely and check the hose for lint and birds nests. Check the flaps on the wall vent that they move freely. Then strip the machine down and clean all the ducting and the fan.
F22 Error Code
http://www.shopyourway.com/questions/1146749
Jan 24, 2017 | Dryers
F22 flashing on hot point washing machine
Google it this is not the hotpoint website .
Jan 06, 2017 | Washing Machines
Keeps saying f22 when trying to start wash
F22 means you have a door lock issue -- not sure what these other guys are telling you but you need to unlock your door to correct the problem. Remove the lower kick panel by taking out the screws on the bottom. reach up on the right side---attached to the door latch is a 2 inch long plastic bar you need to pull directly down to unlock the door. After this disconnect the power to your machine for 1 minute and reconnect the power. If the error comes back replace your door lock assembly. Here is the part to order. Below is a video to show you how to replace the lock.
Dec 05, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer F22 Error Code Follow-up
1) F22 mean DOOR LOCK ERROR , this problem can be a) switch for open or defective b) loose wires or broken wires, test by continuity VOM .
2) adjust the Door vs switch very well for propely closed, and test the closed switch.
3) see if the color are missing and put in the WRON terminal.
God bless you
Jun 28, 2012 | Washing Machines
I have a Whirlpool duet ht washer. It is giving me an F22 error. How do I fix it?
Whirlpool 'F22' decodes as 'control unit failure' which unfortunately is not normally something which could be fixed by the user.
I fear the only answer is to call for repair, sorry ;-0(
Good luck,
John C
Apr 07, 2011 | Whirlpool Washing Machines
What does an f22 error message on my Maytag 3000 series washer mean?
F22 is door lock error. This is usually fixed replacing the door lock. Connection from door lock to CCU (control panel) may also be responsible.
Nov 01, 2010 | Washing Machines
Close door, f22 message, won't start
"F22" is a door latch error. The following link explains:
http://www.fixya.com/support/r1976388-f22_error_code_whirlpool_duet_kenmore
Read through all the steps listed and let me know if you still require assistance. I hope this helps you.
Apr 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error code f22 whirlpool duet wash cycle
f22 is a door lock error try this hit cancel turn your dial to another setting, hit start and once it starts hit cancel again and it should unlock. thats what i did anyway.
If you're getting an F22 error, you will want to check anything to do with the door latch switch.
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpoo; wfw9200 F22, F28, A17 A27 error codes
f22 is a door lock error and f28 is a commication error you still have warranty thorugh whirpool. you're going to need pro. help
Dec 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
F22 Error Code
TAKE 3 SCREWS OUT THAT HOLD THE BOTTOM FRONT PIECE REACH UP BEHIND AND ON THE DOOR LOCK MECHANISM THERE IS A ROUND PLASTIC DOOHICKEY PULL IT DOWN ABOUT 1/2 AN INCH OR AS FAR AS YOU CAN AND IT WILL UNLOCK THE DOOR. I WOULD UNPLUG UNIT FIRST. I DON'T KNOW ABOUT THE F22 THING. MY JUNKER DOES THE SAME THING PERIODICALLY, I UNPLUG AND REPLUG IT TO CORRECT
Sep 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
112 people viewed this question
fordexpert
Kristen Denison
Kristen Denison
Level 1 Expert
Jim Chinnery
Jim Chinnery
Level 1 Expert
