Question about Philips 60P8342 60" Rear Projection Television
Real problem Hello, I have a phillips 55" rear projection tv model #55P8342 chasis model # PTV-916 is this chasis compatible to the chasis model #PTV-780 I am switching parts from 2 tv's
  • 934 Answers
No - -
Posted on Nov 19, 2007
I have a 52 or 55 inch phillips magnavox ptv 805 rear projection tv but the color isnt right on it everything else works fine i can see the picture fine but its just the color what can i do
Thats a common problem caused by the CRT coolant needing replacement. The Phillips CRT coolant kit is available from which contains the coolant and the CD with instructions.
Jun 30, 2011 | Televison & Video
You will also need to check the 6.8 ohm resistors also. The sey uses STK392-120 ICs two of them. You can get the phillips DPTV305-DPTV345 convergence repair kit from which contains the two ICs and 12 6.8 ohm resistors plus instructions on CD. The DPTV and PTV chassis phillips all use that same kit.
May 25, 2010 | Televison & Video
Aspect ratio and tv type
The phillips 9P5544c isnt a HD tv so you will only have 4.3 formatt available
Jun 20, 2009 | Philips 9P5544C 55" Rear Projection...
Is a blu-ray player compatible with a rear projection tv phillip?
You need to use an HDMI connection from blu-ray player to the television. If your tv does not have an HDMI input the tv is probably to old and will not accept 1080P. If it does have an HDMI connection it should display a minimum of 1080i.
Jan 29, 2009 | Zenith E44W46LCD 44" Rear Projection...
Try the power supply. Look on the one in your TV for the part number ; mine is PH3501705441. I ordered one from and it was less than $60 shipped. Hope this helps, mine works fine now........and I have a 50P8342 chassis PTV 916
Dec 10, 2008 | Philips 50P8341 50" Rear Projection...
No sign of power on my Phillips Magnavox rear projection TV
try replacing the fuse. it should be behind the bottom panel near the power cord
Nov 17, 2008 | Televison & Video
Philips 60p8342 chassy ptv 916
check all your solder connection and test the resistors on the conversion IC's , also check oscilating circuts
Oct 27, 2008 | Philips 60P8341 60" Rear Projection...
Philips PTV840 55" rear projection TV
You canget a Factory Service manual from The manuals can be downloaded instantly. They are complete with over 2000 pages in all.
Their manuals cover all projection TV models with Chasis # PTV835, PTV836, PTV840, PTV841, PTV842,PTV843, PTV844, PTV847,PTV853
Apr 28, 2008 | Philips 9P5544C 55" Rear Projection...
Blue screen with sound but nothing else!
I, too, acquired a Phillips without a manual and was experiencing a similar problem. My model is PTV 916, but if your TV has a "source select" button, say a prayer and press the button. From that point, I don't know what else I did, but I do get TV programs now.
Jan 04, 2008 | Philips 50P8341 50" Rear Projection...
Philips 60P8342 60" Rear Projection Television Logo
135 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
