Question about Samsung Laptop Keyboard for X20 X25 X30 X40 X50 Series
I cannot boot from cd i have change the boot order in the bios and i cannot boot from Cd or USB It does look like it has an admin password in the bios because it is not enaled
    Sergeant:
  • 361 Answers
It may help u. first keep sp-3 bootable cd. when it run few time after it ask to change ad pasword then u can change . if u have new password you can go ahead. thank
Posted on Jul 12, 2009
  • Roshan Rijal
    Roshan Rijal Jul 12, 2009
    it may help u. first keep sp-3 bootable cd. when it run few time after it ask to change ad pasword then u can change . if u have new password you can go ahead. thank
Forgot admin password cannot how to reset admin password gateway lt2104u
Look on Ebay for a password reset disk. Many vendors on Ebay sell a bootable "linux" disk that you boot from and then you can edit your password file on Windows. I have versions for XP/ Vista.Windows 7.
Be sure to get one that works for your version of windows. You must set the BIOS to boot from the CD drive first for this to work. About $5 to $10 for the reset disk.
Regards,
Dennis
Apr 18, 2014 | Gateway LT2104u Netbook
Tip
How to Boot From A Windows 7 Password Reset Disk?
<span>Forgot Windows 7 password? It seems to be a universal iusse as widespread of Windows 7. To solve this problem, you can either buy a burned Windows password recovery CD on-line or burn such a password recovery disk with<b><a href="http://www.passwordunlocker.com/knowledge/windows-7-password-reset.html">Windows 7 password reset</a></b><span> </span>software. But no matter which method you choose, you have to boot your locked computer from the password recovery disk. However, you will feel frustrated when you have little computer skill. Take these 2 methods as your reference when you encounter the similar problem.<br />Of course, firstly , you need to create a<span> </span><a href="http://www.passwordunlocker.com/knowledge/create-win-7-password-reset-disk.html">Windows 7 password reset disk</a>, and then pay attention on how to boot from the Windows password reset disk .<br /> Method OneInsert a burned Windows 7 password recovery CD in your locked computer boot the locked computer from the CD/DVD as follows:<br /> <ul> <li>1. Turn on or restart the locked computer, watch the screen for a message like "Press to http://www.passwordunlocker.enter SETUP "or something similar. Press this key as soon as you see the message to enter BIOS menu.</li><b>Note</b>: The key pressed to enter BIOS is different based on manufacturers, but F2 or Delete are the most common keys <li>2. Use arrows to choose Boot on the taskbar, select<b><span> </span>Boot Device Priority</b><span> </span>and press Enter.</li> <li>3. Set<span> </span><b>CD ROM</b><span> </span>to the first boot device according to the prompts on the right.</li> <li>4. Press<b><span> </span>F10<span> </span></b>to save and exit BIOS. You computer will restart with the changed BIOS settings</li></ul><br /> Method Two <p>If the method above doesn't work, you can also try to enter Boot Menu to boot the locked computer from the burned CD/DVD as follows:<br /> <ul> <li>1. Insert a Windows 7 password recovery CD in your locked computer.</li> <li>2. Start the locked computer and immediately tap and keep tapping<b><span> </span>F8</b>,<span> </span><b>ESC</b><span> </span>or other keys until the Boot Menu screen appears.</li> <li>3. Select<span> </span><b>CD ROM</b><span> </span>as the first boot device and press Enter. After that, your computer will restart with changed bios settings.</li></ul>PC users can not only set bios password for computer, but also set Windows logon password. If the BIOS is password protected, you need to clear or remove the BIOS password before you can enter BIOS to change boot order.<br />By the way, if you forgot Windows 7 password or Windows 7 password-protected, it is suggested to take Windows password recovery software to create a Windows password reset disk. Take<span> </span><b>Windows Password Unlocker<span> </span></b>for example, it takes you only 4 steps to burn a bootable CD/DVD or USB flash drive for Windows 7 password recovery in 5 minutes.<br /><b>Step 1:</b><span> </span>Download and install<span> </span><b><a href="http://www.passwordunlocker.com/windows-password-recovery.html">Windows Password Unlocker Professional</a></b><span> </span>in any availble PC<br /><b>Step 2:</b><span> </span>Burn a Windows 7 Password Recovery CD/DVD or USB flash drive.<br /><b>Step 3:</b><span> </span>Boot from the burned the Password Recovery CD/DVD or USB flash drive.<br /><b>Step 4:</b><span> </span>Reset Windows 7 password under Windows PE.<br /></span>
on Mar 23, 2011 | Computers & Internet
How do I bypass admin password
If you forgot the password then there are many password recovery tools you can download from the internet.
I will suggest you to download Hiren's bootable cd from the net which contantains powerful recovery and other tools also and it is freeware .
After downloading the hiren's bootable cd you need it burn it into a CD and boot your latop through Hiren's bootable CD.
Inside the CD you'll find password recovery tools which can remove your admin Password.
Hope you know to boot from the CD by changing your boot order in BIOS setting by slecting first boot First Device by slecting CD or DVD.
here is the downloading link http://softarchive.net/blogs/downloaddownload/hirens_bootcd.889895.html
Don't mis use the sofware to break other's password.
Jul 26, 2012 | Computers & Internet
How do I open windows xp on a sony vaio pcg-z505ls if I forgot administor password
Jul 26, 2012 | Sony VAIO Pcg-Z505LE Notebook
Hack a password
-Download an Offline NT password recover tool such as http://www.pogostick.net/~pnh/ntpasswd/ -Burn the image (tool) to a CD or USB drive. -Insert CD/USB drive into computer and reboot the computer. -Make sure CD/USB is set to boot first in BIOS. (To get to BIOS it is usually F1 F2 F9 or F10 while the computer is booting up.) Look for Boot Order and make CD/USB first and save and exit BIOS.
The CD/USB should then boot into the utility program. Follow the prompts to blank out the password (Just hit enter when it asks for a new password) Blanking it just usually works better than changing it.
Reboot and your account should no longer have a password.
Your other option is to reformat the operating system. (You can pull the drive and plug it into another computer if you need to backup data)
Aug 02, 2011 | HP Mini 1000 Netbook
I forgot my admin password. what can i do?
You need to prepare:
1:A blank CD/DVD or USB flash drive
2.A computer which can link to internet
3.A program called
Windows Password Recovery 6.0
Get started with this 3 simple steps:
Website: http://lost-password.net/products/windowspasswordrecoery.html
Step 1 - Download windows password recovery utility and install it.
Step 2 -Burn your Windows Password Reset CD:
To burn your CD, you'll need a blank CD-R and the .ISO file of Windows Password Reset.
Step 3 - Put in your newly created CD and remove your Windows password.
hope this helps
http://majorgeeks.com/download.php?det=5710
UBCD4Win is a bootable CD which contains software that allows you to repair, restore, or diagnose almost any computer problem also has a bios reset tool which can remove your password and bios password
you will have to burn it to a disk as an ISO then you will have to boot from the disc During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart (note after you have removed your password you will have change fist boot back to your hard drive) Hope this helps
Mar 29, 2011 | Dell Optiplex GX280 (99301) Motherboard
Stop c00002la fatal system error, when I hit F8 and try to start with last known good configuration, still get error, can't fix it?
Run The Recovery Console
1.Boot from CD or DVD (change boot order from BIOS F1,F2, or Delete key/ save changes on BIOS ) then Reboot to BOOT fron CD
2.Choose R to Run Recovery Console
3.Enter 1
4. Enter your Admin Password
5.Type: chkdsk -r
6. Done
Nov 16, 2010 | Dell Dimension 2400 PC Desktop
I cannot set password
There are 2 users in this router, 'admin. and 'user', default password is blank. admin can change password of user without having old password, user can change his own password, admin can change password of his own by supplying his old password then new password twice. To log in to this router, default address is http://192.168.0.1 user name admin and password blank. You may now change password from tools menu.
If you forgot user password then log in as admin and change password, If you forgot all password then only way is to reset router from rare pin hole. Pressing reset for 20 seconds.
Jul 15, 2009 | D-Link AirPlus DI-524 Wireless Router
Administrator password help/ password boot cd
Hello pink,
In order for your PC to read your CD on boot, you don't have to enter your BIOS settings. When you start your computer, press the F12 button repeatedly (like F12-F12-F12-F12), and your pc will ask you which boot device you would like to use.
http://ice.he.net/~hedden//images/F2_for_Setup_Dell.jpg
It will show you a screen like this:
http://www.prime-expert.com/ebcd/img/bios8.png
Just select your CDROM in the list, and hit enter. this will read your bootable CD.
I hope this helps.
Jerry.
Feb 23, 2009 | Microsoft Windows Server Standard 2003 for...
Samsung Laptop Keyboard for  X20 X25 X30 X40 X50 Series  Logo
327 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
