Question about Western Digital Caviar SE16 (WD5000AAKS) 500 GB SATA Hard Drive
WD not turning
I am installing a new SATA drive to my PC. I have two SATA interface cards and getting the same problem. Windows says the device is working properly, but the dive is not seen by the analyzer and not feeling the disk turning in there. This is really a 320 gig HD not the 500. only option I had..
  • 67 Answers
First enable the hard drive in bios if you havent already .Then if you have windows xp click right on my computer and select manage,it opens up computer mangement, then go to the tab called storage and on the sub menu of storage click disk management . You should see you 2nd/other hard drive (labelled disk 1 at the bottom if it is the second hard drive) make sure its your 2nd HDD ( Look at capacity in properties by clicking right on it) .Click right on the 2nd hard drive and select format press ok when the new window comes up and its finished.
Posted on Dec 09, 2007
How to fix my wd scorpio and can use it again?
Open Control Panel ' select System ' select system devices ' look for yellow triangle on unknown device or under storage device / hard drives. Select detect / add new device with drive connected.
Feb 12, 2015 | Western Digital WD Scorpio Blue WD2500BEVT...
I have windows 7 on my acer aspire R1600 and i want to format it and install windows xp3 but it want find the hard disk, please help, it urgent
Your brand-new disk-drive probably has a SATA interface, whereas Windows XP expects that it has an PATA interface.
Thus, the Windows Installer does _not_ load the device-driver for SATA devices, and therefore "cannot find" your disk-drive.
Reinstall Windows 7 -- it's a much-better Operating System that the long-in-the-tooth Windows XP, and it will include support for all the other devices in your ACER that Windows XP will *NOT* support.
Aug 23, 2010 | Computers & Internet
How do I install a new CD drive in an old destop computer It is an old Compaq Presario 5WV254 The existing CD drive has a ribbon type connector that mates up to the pins on the drive plus a 4 pin module...
The Compaq Presario SWV254 Desktop PC uses IDE technology, not SATA.
In the specifications for the above Desktop PC, it states ATAPI is used for the interface technology, and connector, for the optical drive/s.
[IDE is also referred to as PATA. Parallel ATA
SATA is Serial ATA.
The PATA designation was implemented, so that computer users could easily distinct between IDE, and SATA technology]
1) The IDE interface cable, (Flat ribbon cable), has a connector on each end with 40 socket holes.
(39 are actually used. Most of the time, one socket hole is blocked off. (Pin 32)
2) The SATA interface cable has 7 contact pins. Also referred to as a Data cable.
3) The IDE devices, (Harddrive and optical drive), use a 4-pin Molex connector for the power cable.
4) The SATA devices use a 15-pin connector on the end of the power cable.
More info on SATA,
The Samsung SH223C optical drive is a SATA device.
You cannot just plug it in.
IF, you have an open, (Available), PCI slot on the motherboard, you can use a SATA adapter card.
The SATA adapter card plugs into the PCI slot, and has the necessary connections on the card, for a SATA interface cable.
Just for the SATA interface cable. Does not have a connection for the SATA power cable, you need.
You have to buy a 4-pin Molex to SATA power cable adapter, and connect it to an available 4-pin Molex power cable, on your power supply.
You will also need a SATA data cable. The interface cable that goes from the SATA adapter card, to the SATA optical drive you're trying to install)
This is an example of a SATA adapter card. It is not an advertisement for said website, nor manufacturer,
Jan 06, 2010 | Compaq Computers & Internet
I have a 320gb WD hard disk and it was working normally but few days ago when i plug it, it could not work. ( the light is on but there is no spinning sound)
Seems to me a defective interface circuitry.
These devices have a USB-to-SATA interface inside their enclosure. If you can find another enclosure with a similar interface (or buy a new enclosure), disassemble your hard disk enclosure, get the hard drive out & attach it to the interface in the other enclosure & see if it works.
Another possibility is that the interface could be fine, but the hard drive itself died. To test this possibility, try attaching the hard drive directly to a PC. Since the hard drive is a SATA drive, you will be able to do this easily.
Aug 28, 2009 | Western Digital Passport 320GB External...
My Computer did not access Western Digital Hard Disk, Model No. WD 1600 AABB Caviar SATA.
Good morning! Please make sure that the drive’s power and SATA cables are properly connected. If the Serial ATA host adapter card is installed in a 64-bit PCI slot on the system motherboard, move the card to a 32-bit slot.
Verify that only one power cable (either SATA or legacy) is connected to the drive. Check to see that the power connector and SATA interface cable are securely attached and that the
SATA host adapter card is properly seated in the PCI slot.
The Serial ATA interface connects each drive in a point-to-point configuration with the built-in SATA port on the motherboard or with the SATA host adapter card; therefore eliminating the master/slave relationship as required with EIDE. Each drive utilizes its own
cable for data transfer rates. Jumper settings for Western Digital Serial ATA hard drives are mainly used for enterprise storage environments.
Most third party controller cards and RAID adapters are recognized as a SCSI device under Device Manager. This is normal and will not affect your drive or system performance.
To verify if the Serial ATA drive is recognized by the system, Right-click on the My Computer icon, select Properties, left-click on the Hardware tab, and click on Device Manager in the window. Double-click on Disk Drives. Your new Western Digital Serial ATA drive should be listed as a "SCSI Disk Device" or "Serial ATA Disk Device." If not, make sure that all cables are securely attached and that your system BIOS has been properly configured. regards
May 12, 2009 | Computers & Internet
Can't install WINDOWS.
Install the XP Pro first, install the necessary drivers etc. Then after that load the other disk for windows XP Home install it choose the drive to install the OS, install the necessary drivers etc. you will see two operating system while going to boot section of the computer.
Mar 11, 2009 | Dell Dimension 8400 PC Desktop
IDE drive install in SATA computer
can you remove a disc drive and use the hard drive in the original ide slot?
you pci adapter may not work with your motherboard, not all cards are compatible with all boards.
Feb 27, 2009 | Maxtor Hard Drive
HDD Installation
Hi gravni,
The bios (MUST see the drive). If the bios does not see the drive neither will windows!
The down below port (as you mentioned) is for IDE devices. IDE1 by name. Use your ATA IDE port for the slower IDE drives or cd-rom drives. (This board does not have a second IDE port).
If the WD drive is a SATA drive connect it to the SATA 2 port. See your manual. Go to page 1-4.
As show in this pic below.
2711d19.jpg Is the WD 500Gb drive SATA or IDE?
It's suggested when adding a new drive into a working system, the user should setup the drive by using the manufactures guide. Click on this link & download WD's pdf file:
You mentioned the drive is hot. This only means it is running.
Include in this post the model number of your WD drive? So I can check the specs.
Oct 28, 2008 | MSI P965 Platinum Motherboard
Most of the new systems and motherboards support SATA connectors onboard. In your case there is none as you have found. So the best option is always upgrading to a new motherboard in case you need to add more SATA drives. You can also try to find SATA add-on cards, may a little costly types. These cards use PCI interface and very easy to install but hard to find one. I hpoe you could find one from a hardware store near you. If your motherboard has ordinary PCI slots then the SATA adpter will be less costly, otherwise (if it features a PCI-X slot) it will be costly. Following is a simple description on what the market has to offer: SATA II - 150 4Ports PCI-X with NCQ, Raid 0+1, Raid 0 and Raid 1 ! You can upgrade your desktop computer to have four Channels Serial ATA Generation 1 and Generation 2 transfer rate of 1.5 Gbps. The board provides a 64bit, 133 MHz PCI interface on the host side and four, fully compliant Serial ATA ports on the device side to access Serial ATA storage devices such as hard disk drive, ZIP drive, CD-ROM, CD-RW, DVD-ROM. Note: Fault tolerance: RAID 0 (Striping), RAID 1 (Mirroring), RAID 0+1 (mirrored-stripping) and RAID 1+S (Mirrored-Sparing) improve the data performance and provide the data redundancy and rebuilding.
Oct 09, 2007 | HP Pavilion 513n (P9850A#ABA) PC Desktop
Western Digital Caviar  SE16 (WD5000AAKS) 500 GB SATA Hard Drive Logo
251 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
