Question about EliteGroup P4VXASD2 Motherboard
Dear Sir, Have P4VXASD2+ with AMIINT - 10 BIOS (07.00T 02/4/01?)Release 09/05/2002. 512MB memory in 2 sockets. Try to replace with 2 of 512MB but computer part boots, closes down and re-boots etc. OK with just one of the 512 MB modules in one socket. What is latest BIOS and what prog to install it? ECS website leaves me very confused!Any other ideas! T Westcott (England)
  • timwestcott Jul 16, 2009
    Sergio,
    The motherboard manual for the P4VXASD2+ states that it supports up to 2gb of memory and I have checked that used singularly in one of the memory slots either module works correctly to provide 512mb memory.
    Thanks for your suggestions!
    TJW
When I upgraded this motherboard to 1 gig of ram I had to set a long line of jumpers. It explains it in the manual.
Posted on Dec 17, 2009
  • 33 Answers
Does your motherboard support 1 gb memory? sometimes motherboards have limitation when comes to memory!!or try to check the modules if it is functioning!!
Posted on Jul 16, 2009
GA-EP43 -UD3L motherboard will not boot with 16 GB of memory
Time to RMA, sounds like you have a faulty memory channel on the MB. Possibility the slots are not getting enough power to handle all 4, you try to see if you can increase power in bios.
Mar 01, 2017 | Gigabyte GA-EP45-UD3L Motherboard
Need to install memory on a veriton Z290G desktop but dont know how to open the computer
1 Turn off your computer and all the peripherals connected to it before
opening it. Then unplug all cables from the power outlets.
2 Place your computer on a flat, steady surface. If your computer is in the
vertical position, rotate the plastic stabilizers and lay your computer on its
side.
3 Turn the screws counterclockwise to release the cover.
4 Hold the sides of the cover with both hands.
5 Slide it back about an inch and then gently lift it upward to detach it.
6 Remove the side panel.
7 Locate the memory DIMM socket on the mainboard.
8 Press the holding clips on both sides of the memory DIMM socket outward
to release the memory DIMM (a). Gently pull the memory DIMM out of the
socket (b).
9 Align the memory DIMM with the socket. Press the memory DIMM into
the socket until the clips lock onto the memory DIMM.
The memory DIMM sockets are slotted to ensure proper
installation. If you insert a memory DIMM but it does not fit easily
into the socket, turn the memory DIMM around and try to insert it
again.
10 Align the cover's hinges to the housing frame; then gently push it in to
slide it back into place.
11 Secure the cover with the screws.
Oct 03, 2011 | Acer Veriton Z290G 185 320GB
Sir,i have install 3 sata hdd on my motherboard gigabyte 945 GCM-S2L 1. 160gb 2. 500gb 3. 1 tb. my pc many times hangs on bootup and freezes then i disconnect the cable to turn off. how to fix that...
Do extensive diagnostic tests:
1. Set BIOS to default settings and do not use overclock settings, check.
2. Memory test, download ISO image, burn it onto cd and boot from it.
If memory fails after several hours testing: Replace memory
3. Flash the latest (original)[beta] BIOS version.
4. Connect just one (1) harddisk and test for longer time. *
5. Add second harddisk and test for longer time. *
6. Add third harddisk and test for longer time. *
* If connecting or adding harddisk leads to freezes, exchange that harddisk and retest.
Sep 25, 2011 | Gigabyte GA-945GCM-s2C socket LGA775...
The PC does not start.Only it beeps and a red light blinks,also fen is not working.
here are some of the basic codes, depending on which BIOS you have...
Also you do not indicate which fan? I would guess you mean the main Power Supply (PS)? In which case it could just be you need to replace the PS.
Here is a link to some other codes as well...
http://www.computerhope.com/beep.htm
AMI BIOS ERROR BEEP CODES
  • 1 Beep - Memory Refresh Failure (check memory)
  • 2 Beeps - Memory Parity Error in first 64KB block (check memory)
  • 3 Beeps - Memory Read/Write Error in first 64KB block (check memory)
  • 4 Beeps - Motherboard timer not functioning (possible motherboard replacement)
  • 5 Beeps - Processor Error (may need replacement Processor)
  • 6 Beeps - Gate A20/keyboard controller failure (possible motherboard replacement)
  • 7 Beeps - Processor Exception Interrupt Error (may need replacement Processor)
  • 8 Beeps - Display Memory Read/Write Failure (reseat or replace video card)
  • 9 Beeps - ROM checksum Error (replace BIOS chip or motherboard)
  • 10 Beeps - CMOS shutdown Read/Write error (possible motherboard replacement)
  • 11 Beeps - Bad Cache Memory - test failed (replace cache memory)
Phoenix BIOS ERROR BEEP CODES
Phoenix BIOS beep codes are a series of beeps separated by a pause, for example:
beep --- beep beep --- beep --- beep beep would be 1-2-1-2
  • 1-1-4-1 - Cache Error (level 2)
  • 1-2-2-3 - BIOS ROM Checksum
  • 1-3-1-1 - DRAM Refresh Test
  • 1-3-1-3 - Keyboard controller test
  • 1-3-4-1 - RAM Failure on address line xxxx (check memory)
  • 1-3-4-3 - RAM Failure on data bits xxxx of low byte of memory bus
  • 1-4-1-1 - RAM Failure on data bits xxxx of high byte of memory bus
  • 2-1-2-3 - ROM copyright notice
  • 2-2-3-1 - Test for unexpected interrupts
I hope this helps.
Mar 29, 2011 | HP Computers & Internet
PC power on but doesn't display anything on the monitor and has a beep code of different intervals of time. Here are the beep codes: 2 beeps, after 1 sec, 8beeps, after how many seconds 2 beeps after how...
AMI BIOS beep codes
Below are the AMI BIOS Beep codes that can occur. However, because of the wide variety of different computer manufacturers with this BIOS, the beep codes may vary.
Beep Code Descriptions Document
1 short DRAM refresh failure CH000996
2 short Parity circuit failure CH000607
3 short Base 64K RAM failure CH000996
4 short System timer failure CH000607
5 short Process failure CH000607
6 short Keyboard controller Gate A20 error CH000383
7 short Virtual mode exception error CH000607
8 short Display memory Read/Write test failure CH000607
9 short ROM BIOS checksum failure CH000607
10 short CMOS shutdown Read/Write error CH000239
11 short Cache Memory error CH000607
1 long, 3 short Conventional/Extended memory failure CH000996
1 long, 8 short Display/Retrace test failed CH000607
For more information go to: http://www.computerhope.com/beep.htm#04
Jan 09, 2011 | EliteGroup P4VXASD2 Motherboard
My lan is regulary disconnicting
first check for lan cable or jack it might be loose, second check the same at the other end
Oct 05, 2009 | EliteGroup P4VXASD2 Motherboard
Memory upgarade
Yes, it will work. Remember that all memory will operate at the speed of the slowest memory though so unless you're completely replacing the memory it won't increase the speed of the memory.
Jul 21, 2009 | ASUS A7V400-MX Motherboard
I want my display drver
http://www.ecs.com.tw/ECSWebSite/Downloads/DownloadFile.aspx?catid=1&driverid=1704&areaid=2&LanID=0
thats the driver for the intergraded video on a ecs P4VMM2 motherboard
Driver Name : S3 ProSavage Display Driver P4M266_KM266-P
Nov 27, 2008 | Computers & Internet
Dell webpc,,2 short beeps and keyboard error
i can help you with the Post-Code Beeps.
AMI Bios= 2 Beeps. Parity error In First 64k Ram. ( reseat Memory ) Post Failure 1 or more Of the Hardware test Have Failed.
IBM Bios= 2 short Beeps. Post Error ( Memory Possibility ) review screen for details.
AWARD Bios Codes = 2 Short Beeps. Any Non-Fatal Error. Enter CMOS setup to reset.
I,d go for Memory ( RAM ) But first enter bios setup Usually F2 Or Delete escape et,c. Reset to defaults, and see if that solves your Problem.
Mike @ Compurepair.
Mar 07, 2008 | Computers & Internet
Starup and Shutdown problem
i checked the system heat within 105 C and above restart issue
Sep 30, 2007 | Intel D945GNT Motherboard
EliteGroup P4VXASD2 Motherboard Logo
759 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Computer Links
Matson Kurian
Matson Kurian
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
