Question about LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard Drive
Since a couple of days ago my LaCie 500GB external hard drive is making odd sounds, and eventually freezes, leaving the blue light flashing at the front and an inability to close the connection without shutting down the machine using the switch at the back. The sound that is made is always when the disk powers up and begins to spin (if that's what happens); it makes a kind of scraping sound and suddenly the 'power up' winds down, then the flashing. I can still turn it back on, it appears on my desktop, and access it, but I'm afraid this is going to change soon. I have done nothing out of the ordinary with the unit, and purchased it just over a year and a half ago.
  • 5 more comments
  • richard_s658 Jul 12, 2009
    Thanks a lot, Ekse. To be honest I'm not entirely sure if I'm outside the warranty or not, and I should definitely check that out (it's probably a one year warranty). I don't honestly think it's an adaptor problem; the sound is most certainly inside the unit. If I could describe the sound in terms of metaphor, it's like the sound a bicycle tire might make when the speed increases (such as going down a steep hill) and either the tire is warped or the break is touching it at one point, but it has that scraping sound every revolution. I'm not big on mechanics, and no technical wizard (hence I put this message on here without trying anything much on my own), but if there's a disk spinning in there it's rubbing against something, or the head is not lifting properly or something like that.
    As for files, I can still access them no problem. My concern is that when the unit freezes and I have to shut it down manually since it won't eject (can't disconnect via the desktop), it will eventually not power up at all and/or will be wiped.
    For now I'll check the warranty and do as one other person who offered a solution advised and check the disc utility. After that, I'll just hope for the best... for now :)
    Thanks again.
    TechRobert: I will indeed do that. Thank you. And yes, it does sound like a mechanical problem.
    Thanks, Ginko. There is no beeping, and no clicking sounds; instead there is a scraping noise as it powers up (the head?) and then the motor quits and the light starts flashing. From the comments on this problem it sounds like the head is indeed the problem. I've never touched any of the settings, so it shouldn't be a problem like that.
    I'll check the warranty first and see if I'm still covered. If not, I'll think about what to do next. Thanks.
    Thanks again, Ekse. I should perhaps make it known I'm working on a mac, if that makes any difference. I'm currently verifying the drive using the Disk Utility.
    I have received zero alerts as to errors. Only alerts that I disconnected properly, of course, after shutting it down manually.
    Oh, and I meant to comment on your post earlier and added it accidentally to my main post (this may go there, too). Did that help you understand the problem at all?
    Just checked using Disk Utility and it says the volume LaCie seems to be OK.
    Well, gents, so far so good. Despite nothing wrong being reported in the Disk verification I was able to disconnect and power down the drive no trouble at all this time. Here's hoping it continues to work that way.
    That being said, I appreciate anyone who wishes to offer any additional insights and/or feedback. I came on here to check if there were any similar problems and if this were perhaps a tendency in the LaCie product in question, but haven't seen any and so posted this. I apologize if it was in haste and the solution was so simple. Again, I appreciate the time you took to post comments.
  • richard_s658 Jul 16, 2009
    Hi again, all. Well, the problem seemed to go away for a short time, but today when I turned on the LaCie drive it won't load onto my desktop at all. There is a constant clicking sound inside the machine, and if you listen closely to the device it sounds like a fan is powering up and down but can't quite make it to full speed. It's obviously a mechanical problem. Going to call the Apple shop I bought it at and see if there's still a warantee, as well as what I need to do and if it's salvageable.
    Hope you're all well.
  • LaCie Master
  • 13,433 Answers
So your outside of warranty?, if your drive uses a external power adapter, you might want to try another adapter or connecting the drive directly to your computer.
To connect it directly to your computer, you would need to take the case apart and take the hard drive out, depending on what kind of connector it uses, connect it inside your desktop computer and see if it works.
If its a ide drive inside (40pin wide cable and 4pin power cable) the jumper setting needs to be set correctly, reads on the top of the drive on the diagram. On Ide if theres another device connected to the ide cable, the other one needs to be Master and the other Slave.
if its sata, you just connect it to a free sata connector and power.
The drive should come up on your computer just like any other drive.
If the drive continues to make strange noises, its most likely crashed possibly a head crash. Seems your outside of warranty, you may be able to recover some of the files by contacting the data recovery service @ the drives support website.
The drive will need to be replaced or repaired.
These drives can not be repaired at home.
Posted on Jul 12, 2009
  • Ekse Jul 12, 2009
    I disagree with ginkos solution, I've had few external drives that refused to start up properly and kept clicking, also device manager showed error code 10 device unable to start- I connected the drive directly to my machine and it worked perfectly later replaced the power adapter which was about 2 years old, the case and the drive worked perfectly in its case again.
  • 26 Answers
Hi dear.
your drive have mechanical issue and most probablay would be difficulat to repair.
try to check with disk doctoring utility.
gudluck
  • LaCie Master
  • 19,396 Answers
When an hard drive start freezing and you start getting noise, that means that there is a physical fault.
If the hard drive is clicking repeatedly, and and then freezing, it is usually because of a broken head, or motor problem. Usually the problem get worse in time, and you will lose all your data. If the hard drive is instead beeping, then it can be physical damage (head or motor), or logic board problem.
Note: this is not jumper settings or PSU problem. When jumper settings are incorrect (PATA) the hard disk is not detected by BIOS, or sometimes not detected by USB adapter board, moreover if you did not change jumpers they do not come out alone. It also does not look like a PSU problem, when PSU is faulty or power insuficient, the hard drive does not run at all.
Regards.
My lacie external hard drive doesn't show up on my desktop the light just flicker
When it eventually will, check the disk (all terms may vary, depending of your version of Windows) :
Right-click the icon of the disk, then click "properties".
In the "Properties" window, select the "Tools" tab, and click "Check now". Check both checkboxes, and run.
This should fix the access problems on your drive.
Aug 28, 2014 | LaCie External USB 2.0 500GB 7200 RPM 500...
I bought a few years ago a Lacie d2 safe hard drive with AES Encryption (with biometric fingerprint sensor). Currently not my Toshiba desktop or IBM laptop pick up the hard drive when I switch it on. The...
Hi... Problem with your external hard drive, pc don't recognize it...
it possible you have bad sector in your disk drive, or your usb cable is not responding.... the best way to find out open your box then take off our hard drive and install it into a pc and see if the hard drive work... or you box it self the controller inside our external box maybe damage,
Oct 20, 2010 | LaCie External USB 2.0 500GB 7200 RPM 500...
Not recognised by computer
You gotta partition it first. http://windowshelp.microsoft.com/Windows/en-US/help/d9a4d35e-efdf-406c-a049-0860180129a71033.mspx
Except don't format the ones that already have a Letter (or u screwed urself there)
Sep 27, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
I WANT TO OPEN THE LACIE 500 GB HDD AND USE THE HDD IN MY DESK TOP
Go for it. There's a chance the internal drive will be PATA (IDE) but odds are good it's a SATA drive with standard connections.
Make sure your PC has connections for SATA drives, and you'll need to buy a SATA cable since the one in the LaCIE case won't connect from your drive to your motherboard.
Sep 08, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Device i/o error on 500gb external usb hard drive, less than 6 mo
perhaps this? http://www.lacie.com/us/support/support_manifest.htm?id=10253&guideid=10167
Apr 01, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Lacie 1TB External Drive flashing blue light, not being found
Hey
I know this arent a solution
Tho I have the same problem atm, this is just a networkstorage device, and this is a newly 1.
Feb 04, 2009 | LaCie d2 Extreme 250GB External with...
Lacie 500gb external drive
The disks inside the HD are not spining. The creaking noise is the HD trying to start. Next time when it does start transfer all the files ASAP cause your drive is about to die.
rmatheson@wowway.com
Sep 30, 2008 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
External hard drive
500Gb Lacie D2 Quadra with the same problem of flashing led and not mounting on the desktop (Mac G4 Mirror), traced to the power supply (57w) going down on power, both 12v and 5v supplies are available but the main power to run the drive drops to below an adequate output, hence the clicking and whirring evident from the drive with simultaneous flashing led.
Testing with another Lacie power supply (250Gb D2) this time a 34w unit got the drive up and running, however, and this is the reason for this post, this lower power PSU failed a week later whilst waiting for a warranty replacement from Lacie (5 weeks and still waiting for the new PSU from them. they have no stock)
Message for all Lacie D2 users, check the power supplies first, test with another Lacie PSU, do not run the drive on a lower rating (34w) PSU it will fry it and leave you with another failed power supply.
If you are in a tight spot use the temporary power supply to move your data to another drive and get the correct 57w power supply before running the drive again.
Don't do as I did assume any Lacie power supply will run any Lacie hard drive, they won't, fortunately I had a second back up, but am 2 drives down and no new PSU's available to buy anywhere.
Try and purchase another spare 57w power supply, something all D2 users should do for long term security, as these do not seem to be very reliable and getting warranty support from Lacie on these is currently impossible.
The lack of 57w power supplies from Lacie and its distributors across the world is surely a warning to be noted!!!!!!
Buyers beware!
Aug 08, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Lacie hard drive 500gb
Ther is no problam remove from the system and re fit the drive this type of opration do rarley but dont do regulary only some times
Jul 17, 2008 | LaCie Computers & Internet
Lacie hard drive nonfunctional
I ran into this issue this week with my lacie big disk 500G external. Unit would power on when plugged into a pc blue light would flash and nothing no connection ding from windows.
Blue front light would flash repetedly slight ticking sound from drives but no connection i finally fixed this and gained access to my data by opening up the case and pluging my pc 12v connectors into both drives to power them up but leaving them connected to the lacie internals worked instantly and ive since copyed all my data off my 500 and will just transplant the drives to internal use on my pc. you cannot connect the drives internally and then copy the data due to the fact that they are raid 0 stripped drives so this hybrid setup works if your external case isnt powering up the drive correctly as mine wasnt.
Mar 02, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard Drive Logo
859 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Marvin
Marvin
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
