Question about Samsung Televison & Video
Samsung tv model no LE40R74BDXIXEU TV IS USUALLY
Samsung tv model no LE26R7 TV IS USUALLY LEFT ON STANDBY, TV WILL NOT SWITCH ON IT JUST CLICKS CONTINUALLY HELP?
  • 304 Answers
First the main bd controls the "Turn on" sequences". When you press the Power on button the Main bd sends a "Turn on" signal to the Power supply. The clicking you hear is the Power on relay ativating. If the tv does not turn on and the relay keeps clicking then you might have a bad Main bd or there is s shorted board somewhere else in the set. The Power supply can also be bad. Have a trained Samsung tech troubleshoot the set.
Posted on Jul 17, 2009
Sky remote code for model UE40J5100AK
Programming the remote control
To control your TV firstly switch on the TV set, point the Sky remote at the TV, press the "TV" button on the Sky remote, then press and hold the "Select" and "Red" buttons together until the red light at the top of the Sky remote control flashes twice. Press "TV" again then enter the code for the TV listings below (Use the 4 digit codes from the left hand column), the red light will flash twice if a valid code has been entered. Press TV then the standby button on the Sky remote control, this should switch the TV set off, if so then press the "Select" button to store the settings. You should now be able to switch the TV back on and use the volume control button from your Sky remote.
If the TV did not switch off then it may require a different code, you can either start again using one of the alternative Direct codes below or continue with this process by continuously pressing "TV" then "Standby" then "TV" then "Standby" etc until the TV set switches off. This will provide a manual scan for variations within that product code.
If you are still unable to control your TV from the remote control see: Programming The Sky Remote or go to Sky's official website where you can see if a particular remote control version number will operate your make of TV, this can be found at:Skyplease remember to use your back button and come back to us.
www.electro-medical.blogspot.com
Samsung brand code 0060
3 digit code for Samsung
065, 584, 037, 245, 476, 398, 516, 292, 318,037
Oct 13, 2015 | Samsung Televison & Video
LCD LE26R7 won't turn on after switching off
This is almost certainly a bad main board and it will almost certainly need to be replaced, not serviced.
I'd google for "LE26R7 main board" - check on eBay as well - but frankly if all you have to do is re-plug the TV in order to watch it I'd probably recommend sticking with that.
I predict there won't be a quick fix to this problem other than replacing the main board.
Don't kill the messenger :-)
bobby @ coppelltvrepair . com
Aug 25, 2012 | Samsung Televison & Video
Trying to retune Samsung LCD TV LE26R7 but settings (4th option on menu) is greyed out and won't let me access to retune was okay before sept 30th
HI,this might just help!...
1.press D.MENU on youre tv remote
2.scroll down to SYSTEM
3.access the RESET function
4 enter 0000
5 follow on screen instructions
TV will then wipe all existing channels and start from scratch.
worked a treat on my SAMSUNG LE26R7........However i noticed my signal strength dropped significantly!!...obviously them at the other end (digital tv boffins)have been mucking about,A bit of fiddling about with my existing arial did the trick!!
REGARDS.......G WATSON
Oct 02, 2009 | Samsung Televison & Video
Icannot access dmenu on the remote. samsung le26r7
my samsung le32 tv is stuck on BBC 1 Mono. i cannot access the D menu or change on to any DTV channels. I am in an area that broadcasts in digital. the tv works ok if I connect a freeview box
Oct 01, 2009 | Samsung LE32R41BD 32 in. HD-Ready LCD...
My tv wont switch on its clicking and led is flashing?
Your power supply will most likely need to be replaced which is actually a common problem in new electronics. If you have a relay next to the power supply, you can check with a multi-tester or ohmmeter to determine if relay is faulty. Most likely faulty capacitor in the power supply
Aug 24, 2009 | Samsung LN40A450 LCD TV
Samsung LE26R7 TV not coming on
Check for main fuse open 4amps. Maybe pwr supply is going. Other possible thing Horizontal transistor ( short) stop run B+. Thank you
Jul 27, 2008 | RCA P52926 52" Rear Projection Television
Televison & Video Logo
581 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
