I have cleaned the connector and the plug and tried again to no avail
SOURCE: Depth Sounder does not display depth
I will see if I can get mine off the hull for testing. Still have found no procedure. Thinking about just replacing the sounder with another unit.
SOURCE: My Garmin depth finder/gps combo
YOUR TRANSDUCER MAY BE SET FOR HORIZONTAL MODE...MEANING FROM BANK TO BOAT, NOT DEPTH...CHECK THE TRANSDUCER TO MAKE SURE, IT IS AIMING DOWN, NOT OUT...OTHERWISE YOU'LL NEED TO CHECK YOUR MODE SETTINGS IN YOUR MENU.
YOU CAN ALSO DO A TEST ON YOUR TRANSDUCER, BY SCREWING IT ONTO A BROOM STICK ...ADJUST THE TRANSDUCER DOWN, CHECK YOUR SETTINGS ON THE SCREEN, THEN DO A SIDE TEST WITH THE TRANSDUCER TILTED SIDEWAYS TOWARDS THE BANK AND CHECK YOUR SCREEN!
THEY CAN BE TRICKY...AND ARE VERY SENSITIVE, BUT ONCE YOU FIGURE OUT, HOW YOU WANT TO USE IT, YOU'LL LOVE IT!
HOPE THIS HELPS!
