Question about Brother MFC-6490CW Inkjet All-in-One Printer
When I print from my Brother MFC 6490cw No image appears on the paper? What 's the cause? How to fix?
When I sent document to print, it transmits to the printer. However, no image appears on the paper. Ink cartridge is full.
  • 746 Answers
Was it working and then stopped? Do you have the latest software drivers installed?
Try the easy things first:
Be sure that all the ink cartridges have ink in them.
Make sure the cartridges are all installed and seated properly. How old are the cartridges?
Try turning the machine completely off for about two minutes and then turning it back on, then try again. Try printing something using a different computer program. Re-boot your computer.
Make sure there are no paper jams.
When was the last time the print heads were cleaned?
Here is a link to the Brother support page for this MFC unit:
http://www.brother-usa.com/support/ModelInfo.aspx?R3ModelID=MFC6490CW#.VcvHPHfbK1t
Posted on Aug 12, 2015
SOURCE:
My mfc 6490cw sends blank faxes
Normally this is caused by not loading the item being faxed in the ADF (Auto Document Feeder) correctly. Try sending a Fax of only one page by putting the page Face down on the Scanner plate (Lift the top of the printer to access the scanner plate). if this works then check the ADF scanner plate is not obscured.
Oct 20, 2014 | Brother MFC-6490CW Inkjet All-in-One...
I have recently installed a Brother MFC-6490CW printer on an iMac with OS X 10.6.6. When attempting to print, I have a choice of two printers: 1) Brother MFC-6490CW (default) or 2) just MFC-6490CW. When...
You have 2 printers because it was inadvertently installed twice. You need to un-install both of them and reinstall the printer again.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Mar 11, 2011 | Brother MFC 6490CW InkJet Printer
Trouble printing
It'll be better for you to use the built-in A3 paper size, otherwise you'll not be able to print it perfectly. I you would like to do it, You can try this, after setting the documents and the documents size, give the print command, and under the printer properties, select the paper size, you'll see an option (custom) from the drop down list, select it an set the size, but you must leave a space for the printer to hold the paper. Good luck. Thanks for using FixYa.
Jun 02, 2010 | Brother MFC 6490CW InkJet Printer
Paper jams??
click here to download yor required drivers
May 12, 2010 | Brother MFC 6490CW InkJet Printer
How to print using ADF feeder?
You take the paper with face to print Up and the top of the paper towards the interior of the ADF. You can also put a stack of papers. When you press the copy/scan command from the machine console or the computer, the automatic document feeder starts.
Jan 06, 2010 | Brother MFC 6490CW InkJet Printer
Where does the paper go on a Brother MFC 6490CW?
theres a menu button on the wireless printer..go to network and set the configuration from there if your using wireless just set the configuration to the existing wireless device you have and thats it...instant wireless printer connection...also check the manual..hope this helps...
Aug 28, 2009 | Brother MFC 6490CW InkJet Printer
MCF 6490CW SCAN AS A PDF
I was trying to figure out how to scan multi-page documents to a single file and found this on the Brother website:
Double-click on the ControlCenter3 icon located in the Task Tray to launch the program window.
Click on CONFIGURATION -> SCAN.
Choose the type of scan you require. The choices are: IMAGE,
E-MAIL, and FILE.
The Scan to configuration window will appear.
The SOFTWARE BUTTON tab configures the Scan to button within theControlCenter3 software interface. The DEVICE BUTTON tab configures the Scan to key on the Brother machine. Choose the tab you want to configure.
Under FILE TYPE select an option that allows multi-page documents:
a) PDF (*.PDF)
b) Tiff Multi-Page # Uncompressed (*.tif)
c) Tiff Multi-Page # Compressed (*.tif)
Click OK.
Apr 28, 2009 | Brother MFC 6490CW InkJet Printer
Printing double sided with MFC-6490CW printer
Hee is you support website See if they have directions(manual ) to download for instructions. I take it that this printer is designed to print double sided else I can tell you the method that works on all printers.
http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_top.html?reg=us&c=us〈=en∏=mfc6490cw_all
Mar 13, 2009 | Brother MFC 6490CW InkJet Printer
Brother MFC-6490CW Inkjet All-in-One Printer Logo
127 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
