Question about Polaroid FLM-3201 Television
Audio problems when playing dvds
Hi - I have a Polaroid lcd tv which works fine except when I play dvds. The picture is great but the audio sucks. It's really low on some dvds, weirdly not all of them, so low that I have to crank the volume setting all the way and it's still too low to hear all of the dialogue. I've looked in the owner's manual, checked all of the settings that I can find, but I can't find anything that helps.
Any ideas would be greatly appreciated.
Thanks - Angela
  • 44 Answers
Re: Audio problems when playing dvds
Your problem sound like it is in the dvd player. Try a dcd disk cleaner .
Lou Margo
Posted on Nov 16, 2007
0 characters
3 Points
We just bought a new 32" panasonic led tv. Hooked everything up and works fine with normal television broadcast. However, we have a Sony DVD/VHS combo hooked up that doesn't perform well. When we play...
If you are using the composite cables (RWY) make sure the red and white are plugged into the audio jacks and NOT the component cable plugs (RGB.) If you have the red audio cable plugged into the red component plug this will cause issues, especially with the sound.
Aug 10, 2010 | Panasonic Flat Panel Televisions
Polaroid Flat Screen TV not working
Ur LCD inverter board is dead.Replaced this board will get ur picture back.Tries websites, to buy a refurbish LCD inverter card to replaced.The board shape is a long board.
Apr 05, 2010 | Polaroid FLM-3734B 37 in. LCD HDTV
My Samsung TV picture is supplied via a HDMI lead
yes you need to connect audio out from the tv to audio in on the dvd surround. you need the red/white phono to phono leads, simply connect together and select audio (av,au) on the input selection.
Feb 20, 2010 | Samsung LN46A650 46 in. LCD HDTV
Blue screen, no picture, audio works fine. TV
I have the same issue. I am thinking I need to replace the T-con board. Did you get your fixed and what did you need or do?
Oct 01, 2009 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
DVD Player stopped working... will not LOAD/PLAY dvds
DVDs will not load / play... problem just started... TV approx 14 months old. Recently DVD was working and the TV just "SHUTOFF"?
Mar 03, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Have a Polaroid TDA-03211C tv with dvd player. Won't play DVDs
As long as you know a disc is not stuck inside I recommend taking it to your local svc center to be looked at.
Feb 28, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Dvd playing blue picture
if it is hooked up with componant, thats the red blue green cables for video, and red white for audio, then you probabily eather dont have the red pluged all the way in, or you have the red audio, and red video---reversed, make sure to check them on the dvd player, and on the tv, if there correct, try using the composit input, that is the yellow red and white
Jan 11, 2009 | Samsung Flat Panel Televisions
Sharp Aquos 37" Audio Static Issue when watching DVDs
i have had to replace the hdmi input board on these units to fix them.
Jan 08, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
I can hear audio on all stations except one?
Check on your remote for a button labeled MTS/SAP or something similar -- try pressing it (possibly more than once). Sometimes this can cause audio to be heard on some channels but not on others...
Jan 01, 2009 | Polaroid FLM-4201 42 in. LCD Television
Polaroid FLM-3201 Television Logo
52 people viewed this question
Top Polaroid Flat Panel Televisions Experts
Dave Naylor
Dave Naylor
matt martin
matt martin
Are you a Polaroid Flat Panel Television Expert? Answer questions, earn points and help others
