Question about LG GCC4522B CD-RW/DVD-ROM Combo Drive
Help! my dvd rom is reading the disc but not showing the data present in it.
  • 152 Answers
You need to clean the lens with a lens cleaner...
Posted on Jul 12, 2009
Remove Write protection from DVD disc
1. Insert the DVD disc into the computer's DVD-ROM burner drive. Click on "Burn files to disc" from the window that automatically pops up.
2. Type a name for the DVD disc in the "Burn a Disc" box. Click "Show formatting options" and choose a formatting option.
3. Choose "Live File System" to allow files to be copied immediately to the DVD disc, much like sending data to a USB flash drive or floppy disk. Live File System discs can only be read by Windows XP or later versions. Choose "Mastered" to have files be copied to the DVD all at once. This is the standard burning method; discs can be played back on any DVD-ROM drive.
4. Click "Next" to prepare the disc. Files can now be copied to the disc using the selected method.
Sep 04, 2012 | HP Computers & Internet
I put in a blank cd and I cannot burn it because in my computer it shows that there is no cd inserted
Here you go...I hope this works for you....
CD/DVD Is Not Recognized
spacer.gif spacer.gif spacer.gif spacer.gif Many times, after inserting a disc into the CD or DVD drive, the disc is not recognized by that drive. CD-read and DVD-read issues can be caused by many sources. Perform the procedures presented in this General Computer Advice article when troubleshooting CD-read and DVD-read issues.
Begin with the first procedure and continue through the list. Try using the CD or DVD after each procedure is completed. For any procedure that requires changing current system settings, record the original settings before completing the procedure.
  1. Verify that the correct disc (CD/DVD) is used when prompted to insert the disc.
  2. For programs on DVD, verify that the drive containing the DVD is a DVD drive and not a CD-ROM drive. Most DVD drives will haveDVD printed on the front of the drive. For programs on DVD, consider the following:
  • DVD drives can read both DVD's and CD's.
  • CD-ROM drives can read only CD's.
  1. If multiple disc drives (e.g., CD-ROM and CD-RW, or DVD and DVD-RW, or CD-ROM and DVD-RW, etc.) exist on the computer that can read the disc (refer to the items under Step 2), insert the CD or DVD into the other drive and try the program again.
  2. If you are attempting to install a program and the installation does not begin after inserting the CD/DVD into the proper drive, refer to the program's instructions for the installation procedure.
  3. Clean the CD/DVD in the following manner:
  1. Place a small amount of nonabrasive liquid soap on the shiny side of the CD/DVD.
  2. Using your fingertips and warm water, gently rub the soap on the CD/DVD in a circular motion.
  3. Rinse the CD/DVD thoroughly and dry it using a clean, soft T-shirt or lint-free towel. (Do not use paper towels or tissue paper.)
  1. Try to use a different CD or DVD in the drive to see if that disc can be read.
  2. If possible, insert the problem CD or DVD into the DVD or CD drive of another computer to see if the issue persists.
Apr 01, 2010 | LG GSA-H55N DVD-RAM Burner
I am having a problem with my DVD rom. I put a disc in there (DVD or CD) and it shows what the disc is and even names all the songs on it, but then a message comes up saying- ? Windows Media Player cannot...
It just might be a problem with the laser carriage motor that moves the laser assy back and forth to read from the inner portion of the disc to the outer portion. If it can't move from the reference position, it won't read anything more than the initial data on any disc. Hope this helps. Good luck!
Nov 07, 2009 | Hitachi GD-8000 16x 40x IDE DVD-ROM Drive...
No disc present
Try running a cleaner disc in the unit if that doesnt work try the following.
Starting at my computer... Right click on my computer icon.
Go to properties.
Then Hardware tab then go device manager. Right click on cdrom in device list. Select uninstall then reboot the computer. If this doesn't help replacing the unit will be necessary.
Jan 19, 2009 | LG GCC 4480B CD-RW/DVD-ROM Burner
My NEC-6650A DVD RW (on Dell Inspiron 6000) won't read DVD ROM
mine does just the opposite. It will read DVD-ROM Games but it wont read data discs or DVD Movies.
Dec 06, 2008 | NEC ND-6650A DVD RW Dual Layer Burner
CD-Rom
Shut down PC & disconnect the wide flat data cable connecting the device to the motherboard. Boot the PC and do nothing. Shut down again and reconnect the cable as it was. If possible replace the old cable with a fresh one.
Try & reply.
Sep 11, 2008 | Computers & Internet
Data are not shown
most older drives can't read multi session... you need to have a drive installed to be able to read multi session burn. there is no software tweak that can fix this... you need to replace the drive. otherwise burn the data as single session.
Jun 03, 2008 | ASUS CB-5216A (90D70001UAYZ) CD-RW/DVD-ROM...
R40 DVD Read Problem
Unable to read a CD-R or other recordable disc. DVD recordable discs - If you have a DVD recordable disc and are unable to get it to read verify that the DVD drive is not a Gen 1 DVD drive and/or that it .
Computer DVD Support The DVD technology is very different from the technology used in standard CD-ROM drives. DVD uses shorter wavelength lasers to read smaller pits and lands.
Computer CD-ROM drive help and technical information. However, DVD-RAM discs cannot be read by standard DVD-ROM drives because of the differences in both reflectivity of the medium and the data format.
Read & follow instructions/Please dont for get to Vote/Thank You.
Dec 23, 2007 | IBM ThinkPad R40 2722 Notebook
Can't read cd data
Have your tried to run other discs?
if same problem for all the discs then their is problem with your ROM Lens! you need to replace it! or get it repaired!
Check with all the discs and if same problem occurs then get your ROM/writer repaired!
Dec 08, 2007 | Televison & Video
LG GCC4522B CD-RW/DVD-ROM Combo Drive Logo
81 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
