SOURCE: I have cub cadet 129 with 12 hp kohler cast iron
This would most likely indicate an air leak in the intake tract. Another possibility would be a partially clogged main jet in the carb. Either problem results in a lean running engine with VERY high exhaust temps. Bad news if not corrected.
Hope this helps,
Dolf_
Testimonial: "thanks"
SOURCE: Kohler 20 HP engine
air filter might be too dirty.. causes the air to **** too much fuel. almost like Choking the carb.
