How do I reset central locking. left door open over night battery ran flat. Now I have lost central locking.
Re-charged battery I have lost the central locking. I can lock and un-lock with the key. It only gives me a few seconds to get in before the alarm sounds off. can any body help me??????????? Regards Roy
I had that problem the other day
Battery dead charged it fitted it started car central locking for other doors only let go after I drove the car down the road
So it might work for you as well
Raise the vehicle & put a battery charger on the starter battery cable terminal & ground the other charger lead to sub frame or motor to charge battery if it will take a charge
Providing central locking works when you insert key in lock,try programming keys
Enter car make sure all doors/windows are shut
Switch ignition on and off,remove key
PRESS AND HOLD UNLOCK BUTTON ON KEY
Press lock button on key 3 times whithin 10 seconds and release unlock
Central locking will lock/unlock rapidly to confirm reset
If your key is the type with bmw logo in the middle battery replacement is not possible,as it charges as you drive
try locking and unlocking the car with the key 3 times slowly ,other than that i have no idea ?? another trick is to disconnect battery and join the cables together for a few minutes to discharge any capacitors that may be holding a charge in the computer..Only other thing i can think of is the main dealers who have the right connectors and software to re set it all .sorry i havent been of any help
the key should open the door without any batt power central locking is batt , the key should open both front doors!!owered so it should not be a problem !
Your key should work manually (without battery) on at least one door or the trunk/hatch. Otherwise the world would be filled with abandoned hyundais with flat batteries and no way to get in! Try the passenger side door; don't expect to hear the central locking relay, but if you turn the key far enough, that door should open.
