Same problemno proper driver toshiba a300
When going from vista to xp, the harman kardon speakers don't give proper sound output. The quality is bad.
The thing is: there is a xp driver available, but it's not a good driver. When trying to install the vista driver it doesn't work at all
Hi guys i got a harman kardon avr5000 receiver it comes on but gives no sound can you help please
Can be in protected mode. Maybe one output channel is defective and dc goes to the speakers. have speaker wires made short circuit?
Mar 19, 2017 | Harman Kardon Audio Players & Recorders
Harman kardon go and play don't have video out port
If I understand you correctly the Harman Kardon does not supply the output video and usb ports. Since this is a go and play they pobably felt it was not needed. to impliment these changes would require a complete design change.
Mar 28, 2012 | Harman Kardon Go + Play Portable Speaker...
Can I run 6 ohm speakers on my amp avt5000
Hello
You can run speakers in the range of 4 to 16 Ohms impedence with this amp. As the impedece go high, output will come less and sound quality will go up and vice versa. Never connect speakers of impedence less than 4 Ohms with this amp, as they will overload the audio output state. OK.
Sep 19, 2011 | Harman Kardon AVR 55 Receiver
Do you know if the harman/kardon avr125 reciever is 3d capable?thanks ..mrmitchfinance@yahoo.com
Actually Home theater sound, is 3D. (Three Dimentional) Your receiver, using surround speakers reproduces 3D sound.
i.e. It is Left to Right, and Front to Rear. Thus it's 3D. If your get a 3D TV, your sound will be just fine because it doesn't come from the set. The sound SOURCE is the DVD player, CD player or Cable Box. If you use digital audio outputs (optical cable or orange colored RCA cables) from these items connected into the Harmon-Kardon, your will get the full Home Theater sound. The Harmon Kardon does not have HDMI inputs however it will not need them for the purposes of sound. Your Receiver is a high quality unit. If you want the thrill of 3D TV, go ahead and get one. After you have set it up, if you then decide you want to go to 7.1 or some other SOUND upgrade, go ahead. One thing you should know, is that there is not a whole lot of audio quality improvement available after 5.1. Unless you have a very large living room. The real quality counts when choosing the speakers and sub woofer that go into the system, not the amount of speakers you have.
I have done a number of high end home theater installations and the experience of hearing the systems (mostly 5.1) has been a thrill for the owner.
I hope this helps you,
Best Regards,
Mark
Jan 20, 2011 | Harman Kardon AVR 125 Receiver
How can I get my Harman Kardon Soundsticks 1 to work on my PC?
The USB version of the soundsticks was specifically designed for the mac and they worked just by plugging them in and then telling the system to use them instead of the analogue outputs. Unless someone has produced drivers for Windows XP for these speakers I think that you will probably not be able to use them.
Jul 23, 2009 | Harman Kardon SoundSticks Computer...
Toshiba saltellite with internal harman kardon speakers, no sound
To solve your problem, please download and install this free software: driverupdate us. It wont take more than 5 min from you to update all needed drivers.
Wish you best of luck
Nov 30, 2008 | Audio Players & Recorders
Speakers not listed in sound output options
I would try un-installing the driver/ application that controls the speakers and re-instaling.
Jan 24, 2008 | Harman Kardon SoundSticks Computer...
Computers & Internet Logo
110 people viewed this question
Alun Cox
David Payne
David Payne
