Question about Haurex Unisex "Piranha" Watch
The rubber watchband is broken apart from the screw in two areas. Is there a replacement band available?
    Scholar:
  • 57 Answers
Yes,if your watch is in guarantee period then go to company's repair centre they will replace it for free.
and if your watch is not in guarantee period then
go to any watch repairing watch shop ,they will insert a new,it costs you according to the material you want for the watchband.
enjoy
please rate me
Posted on Jul 12, 2009
Need the replacement strap for Timex watch M805
Timex Watchband - watchbands.com
www.watchbands.com/Departments/Timex-Watchbands.aspx
Original Timex® Replacement watchbands and straps designed to fit Casio, Seiko ... Currently the Timex bands we have are below. Leather Timex Watch Bands.
Jan 01, 2016 | Timex Watches
I need an Ann Klein watchband replacement - model 10/9168 (has gold hardware in the band). Where can I go for this replacement?
You can just call 818-2496007 (in LA) and order any anne klein parts you need. For 10/9168 watchband, its price is about 22$.
Oct 19, 2012 | Anne Klein 10 6419SVTT 106419SVTT Watch
Looking for a replacement watch band for SEIKO SPORTURA HONDA F1 RUBBER BAND/STRAP SNA749P1 Where can I get one and what is the best price for customer in UK?
I've been looking for a replacement for the Seiko SNAE93p1 and have seen the replacement for this in several places. I only remember because it has a red and black band similar to the one on the watch I'm wanting, and I figure that I should get a replacement band when I buy this new watch, as the synthetic bands on Seiko watches tend to break after about 3 years or so.
Watchbands.com has it for $65 I believe. watchbands com
Jul 20, 2011 | Seiko Sportura BAR Honda Racing F1...
I cannot put the new replacement watchband on the movado sport watch. It is the rubber watch band.
Hi, On most watches they have two pins that you have to remove with a small flat screw driver.
These pins are spring loaded so watch out. You will need some patence to do this. Good luck
Jul 09, 2011 | Watches
Omega watchband adjustment (Metal) pins or screws?
mcdevito75 here, That would depend on the band itself, I would figure most are pins, your best bet though is to look for a small watch repair shop in your area for this adjustment, special tool needed.
Aug 11, 2010 | Omega Watches
I need to replace the watchband.
mcdevito75 here, Best Bet, Look for a small watch reoair shop in your area for the strap and instalation.
Jul 27, 2010 | Skagen Titanium Rubber 235LTRB Wrist Watch
How to change watchband Casio WVA106HA watch
Hi I have a WVA 106HA, the band has broken and I am looking fdor a band can you assist me
Jun 18, 2010 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
I have an new band for the G-shock 500A but can't figure how to get the screws out of the old band to replace it. The screws turn both ways and don't seem to move. Is there some trick or special tool I...
Yes, You need two screwdrivers. One for each side. One screw on one side is long and goes all the way through the watchband and threads into the screw oon the other side which is smaller. Once you have backed the longer screw all the way out, you should be able to give the watch band a few light taps and the long screw should fall out. The screw on the aother side may require a bit more tapping or coaxing with the screwdriver to remove it. Once both screws are out, you can remove the watchband.
Sep 22, 2009 | Casio G-Shock GW500A-1V Wrist Watch
How do i change watchband for casio bg169wh
Take the watch with the broken watchband and place it on the table. With a ruler, measure the width of the broken band at the point where it is attached to the watch. Now, measure the total length of the watchband when it is in one piece and fits around your wrist. There will be a crease on the band where it is normally buckled.
  • Step 2 Go to the local store and select a band that you like. You should make sure that the width of the band at the point of attachment to the watch is the same as the old band. Also make sure that the new band will be long enough and not too long to fit your wrist. Purchase the band and return home to change the band.
  • Step 3 Clear a spot to work and make sure that there is a small towel covering the table top so that you can see anything that may drop or pop out during the process of changing the band.
  • Step 4 Use a magnifying glass to look at the point where one side of the band is attached to the watch. You will see a small pin connecting the band to the watch on either side of the band. Carefully use the jeweler's screwdriver to depress the spring loaded pin from the watch to the band and release it from the watch. When the tension on the spring pin is released it may pop out of the band and you will want to take care not to lose it. Repeat this process with the other half of the band.
  • Step 5 Take the new band and slip the spring pins into the small holes on the end of the band where it will attach to the watch. Working with one end at a time, slip one side into the pin hole in the watch body.
  • Step 6 Use the jeweler's screwdriver to depress the other side of the spring pin and guide it into the pin hole in the other side of the watch body. Repeat this process with the other half of the watchband and other spring pin. You now have a new band for your broken one.
  • Jun 20, 2009 | Casio BabyG BG169WH3V (Size: ) Watch for...
    Haurex Unisex "Piranha" Watch Logo
    481 people viewed this question
    Top Haurex Watches Experts
    Arturs Kalnins
    Arturs Kalnins
    nypr66
    Level 1 Expert
    Are you a Haurex Watch Expert? Answer questions, earn points and help others
