Question about Sharp R-1481B Microwave Oven
Hood lights do not turn off...
Here are the details. I think it's the control board or a switch. but I just want to confirm before I order the part.
I replaced the bulbs in the hood with bulbs in spec according to the manual.
After replacing the bulbs everything worked normally.
The next morning I could not turn the hood lights off.
Pressing the "work light" and "night light" switches got me beeping sounds but no on/off.
Unscrewing one bulb an alternating which one is unscrewed does not change result.
Everything else on the unit functions normally including the rest of the control board.
Any ideas? Part numbers from partstore.com are helpful as well.
Thanks so much!
  • Sharp Master
  • 9,098 Answers
The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This is far less than a replacement circuit board, assuming it's even available anymore.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This often can affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on.
We have full details and critical safety information and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Posted on Nov 17, 2007
Ge lvm1750dm1ww microwave
<-- I see and repair this problem on a regular basis. Details are here.
This failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line, as the warning label near the light socket advises.
This causes a failure on the control circuit board.
The lights can can be inoperable, or stuck on, or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
You can get it your smart board repaired or order a replacement part number WB27X10935 here.
Whether you choose repair or replacement, the first step is to remove the controller assembly.
Here
is a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Next, disconnect the strip as shown in the photo below, then remove the screws that hold your circuit board in the old frame.
Then carefully (since the display is made of glass) move your circuit board to the new frame, and reassembly is the reverse of disassembly.
If you choose repair, do not disconnect the keypad connector and do not remove the board screws. Leave the controller assembly intact.
Feb 16, 2014 | Microwave Ovens
Hood under light does not work or the hood vent
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if the switch contact are not good then it will not trigger the processor to switch on the waveguides. If the lights or fan work without any display or action of program being triggered to start then it can be a possible fault on the main board or the processor. Sometimes insect secretion can short the board and display panel and so the processor can work in such an erratic manner. If so clean, solder and reset the board. Now identify the parts by clicking this link: http://www.espares.co.uk/advice/microwave/a/5/141/identifying-microwave-parts.html
If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron. Check this link to know how a microwave works:
http://www.espares.co.uk/advice/microwave/a/5/1443/how-a-microwave-oven-works.html
Nov 06, 2011 | Hotpoint RVM1435 Microwave Oven
Microwave refuses to work when START button is pressed. Oven light stays on when door is closed. Control panel seems to be working ok but nothing happens after cooking settings are set and START button...
That's probably a failed door switch or door switch mount.
It's a pretty simple do it yourself fix. See this helpful file on door switches.
You can find handy exploded views and order parts by model number here.
But if your cooktop lights failed recently, you have a damaged control circuit board, which we can usually repair for $39.95. Details are here.
Jan 11, 2011 | Whirlpool MH1150XM Convection/Microwave...
We replaced the light in the hood (over the stove) and there was a spark and now neither the hood nor the microwave works. We reset the circuit breaker but it did not fix the problem. Do we need a buy a...
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid with a one year guarantee.
This can often also affect the exhaust fan, cooling fan, turntable, and/or inside light operation, too.
Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you prefer, you can order a new control circuit board and install it.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below), remove the damaged circuit board and insert the new one.
Some connectors on the relays have a lock:
What you'd send
Jan 01, 2011 | Whirlpool MH1150XM Convection/Microwave...
Hi My exhaust fan for GE JVM1540SMSS 1000 watts microwave oven won't shutdown.
This is caused by either a shorted hood thermal cutout / hood thermostat, or your control circuit board may need repair.
You should first check your hood thermostat to be sure it measures open (infinite) and not shorted (near zero).
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
If it reads good, then your board will need to be repaired or replaced. You can order one here.
But we see (and repair) this board failure a lot, and we regularly repair them nationwide by mail for only $39.95 postpaid in most cases.
This failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Let me know if I can help further.
Aug 20, 2010 | GE JVM1540SMSS Microwave Oven
GE JVM1440BD Microwave hood lights don't work
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
If your relay is bad and you want to replace it yourself, it is part # 3501-001050 and you can find helpful exploded view diagrams of your microwave and order that part here.
Be sure to also do any needed circuit board repair with 30AWG wire to prevent it from doing worse damage if another bulb shorts.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Jan 09, 2009 | GE JVM1441 Microwave Oven
GE MIcrowave model JVM1631BJ01 hood lights won't work
The part that controls that is goes through your control panel on your microwave. For the lights to come on to start with the door being closed switches have to be working right and when you press start the lights come one. When the microwave is through cooking and you open then close the door then the lights should go out. The logic IC on the control panel board that detects all these events is not being reset correctly. Unless you get a microwave tech to track down the component on the control panel circuit board it is not something that you could do on your own since it takes voltage and signal checks with the proper equipment and then some soldering and desoldering of the defective component(s). Good luck and God bless.
Dec 22, 2008 | GE JVM1631 Microwave Oven
Turbo vent won't turn off
This is usually caused by a shorted hood thermostat or a shorted triac on the control panel circuit board.
The hood thermostat is usually located on the floor of the microwave chassis behind the control panel. It should read "open" or "infinity" on a continuity or multimeter resistance test.
At our site, we now have a video available showing how to remove a typical control panel assembly in under 5 minutes.
If the hood thermostat is bad, You can order Samsung parts here.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
Sep 03, 2008 | Samsung SMH7178STD Microwave Oven
Kenmore over the counter microwave problem
It has a bad relay on the control board. The board will need to be replaced.
Nov 13, 2007 | Kenmore 62642 / 62644 / 62649 Microwave...
Hood light will not turn off
The problem is damage to the control circuit board. This damage happens usually when the lamps are removed or installed without disconnecting the oven from the power line first. We regularly repair these boards for this very problem for customers from across the country for $32.50. We have an important file called "safety.txt" which you can find by a search on Yahoo.com. It's important information to consider before proceeding.
Aug 29, 2006 | Sharp R-1610 Microwave Oven
Sharp R-1481B Microwave Oven Logo
105 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
