Question about Kenwood Food Mixers
I have Kenwood Chef KM 001, the problem is why my mixer can't whisk eggs?But for K-beater and spiral hook there's no problem. I mean when I use for make bread and butter cream is fine. What's wrong with my mixer?Please help me, thanks before.
A mixer blade for an Oreck MKT800
Hello, Gary -
From what I have found about the Oreck MKT800 Vertical 5 Speed Hand Mixer, there is no "mixer blade" attachment for the appliance. The attachments for the mixer are:
- 2 beaters
- 2 whisks
- 2 dough hooks
You can see an image of the hand mixer with all 6 attachments here:
http://www.qvc.com/Oreck-Vertical-5-Speed-Hand-Mixer-with-Attachments.product.K6135.html
If you mean a replacement beater, whisk, or dough hook for your Oreck MKT800, so far, I have not found a source for those replacements.
Best wishes.
Mar 24, 2018 | Oreck Food Mixers
Kenwood chef keeps curdling eggs
Put water in Kenwood and a bowl inside the Kenwood to hold eggs. Eggs need to be done SLOWLY. Can also add a LITTLE water to aggs as they cook to slow down curdling . Basically you need to turn Kenwood into a double boiler. Lift bowl with eggs in and out of Kenwood to control temperature and whisk away now under control. Lift bowl and cool and slow down cooking and lower back in water and Kenwood to hear back up. Keep whisking and lift and lower bowl as needed. Some melted butter doesn't hurt either!
Jan 11, 2015 | Kenwood Food Mixers
Cannot remove the flexi beater
I have read on other posts that it is the nut at the top of the beater that is causing the problem. You need to rotate it downwards toward the beater in order to have sufficient room to push and rotate the beater out. This didn't work for me, nor did attempting to remove the whole plate by undoing the lug beside the beater insert. Now that I have worn the lug and the nut I cannot get it repaired at a Kenwood service specialist as I have attempted the repair myself.
My advice is to go straight to a professional. Whatever they charge it will be cheaper than being stuck with a machine you can only use some of the time and have to replace!
Dec 31, 2012 | Kenwood KM400 / KM410 Chef Classic Stand...
Kitchenaid difficulty removing whisk
It is not uncommon for gunk batter sugar eggs or other stuff to get up inside the attachment shaft of the mixer and if you don't use it for a while it can turn to glue. remember school flour and water = glue. well add some sugar and some eggs and "wallah" you got glue. How to fix? Get a squirt gun. yep fill it with hot water and squirt it up in the hook and loop portion of the attachment shaft let it sit for 5-10 mins and repeat a couple times. the beater should come off, clean the shaft and then the whisk soak the attachment portion in hot water and let soak to soften the gunk and the spray it out with the sink sprayer. hope that helps. There could be one other mechanical problem and that is the hook that the beaters hang on could be coming out and caused the attachment to jam up ther take a pencil or pen and while pressing the beater up see if the pin wiggles or wobble and most importantly goes back into the mounting shaft. let us know if this helps at all.
Sep 17, 2012 | KitchenAid Food Mixers
Have a 20 plus year old Kenwood chef [navyblue and white] don't know the model number. When the K beater or whisk are attached they rotate for a few seconds then fall out any ideas what to do
for both attachments to fall out the planet hub must be worn out. check that there is a spring clip in the groove of the beaters. if you have had it repaired recently it may be running backwards which woluld eject the attachments.
Aug 18, 2010 | Kenwood KM300 Chef Stand Mixer
Hi,we have an old kenwood chefette hand mixer with worn parts.
does anyone know how I could get the whisk beaters for a Kenwood A375? Was given mixer but no whisks!!
Jul 29, 2009 | Kenwood Food Mixers
New Kenwood chef km 001 - I can't get the beaters out!
Try turning the beater in the reverse direction to the direction it normally turns - clockwise looking at the beater (I think), this should make the shaft pins ride up on some cams which should release the beater.
Sep 23, 2008 | Kenwood KM800 Major Classic Stand Mixer
SILLY QUESTION
Push the whisk attachment post up into the mixer, turn counter-clockwise and it should lock into position.
Apr 03, 2008 | Kenwood KM800 Major Classic Stand Mixer
Kenwood chef excel attaching blender
http://www.kitchenmanuals.com/manuals/mfg/kenwood/km300_km400_km600_km800.html
hers the manaul for u rate me as fix ya ok its a pdf file also thx nick use adobe reader to view it 43 pages thx agian for using fix ya
Feb 04, 2008 | Kenwood KM400 / KM410 Chef Classic Stand...
Grease coming out of ballon whisk
I think you should contact a service rather than opening and cleaning your device for you to be sure that your device will be fixed correctly...
Jan 18, 2008 | Kenwood KM400 / KM410 Chef Classic Stand...
Food Mixers Logo
107 people viewed this question
Top Kenwood Food Mixers Experts
jason
Steve Allison
Steve Allison
Marvin
Marvin
Are you a Kenwood Food Mixer Expert? Answer questions, earn points and help others
