Question about Sony Audio Players & Recorders
I have a Sony DA555ES receiver. Even if all I have hooked up is two speakers (left and right channel), it only sends sound to one of them (whichever is hooked up as left). If I switch, then the other speaker works. I took it to a Sony certified repair shop, they said they fixed it (two separate times). The 2nd time they said they replaced the entire main board. I swear it appeared to be working in their shop. When I got it home, same problem. (I'm just using FM to test sound now so as to isolate the problem and have as little hooked up as possible.) Also, I've tried it with 4 ohm speakers, 8 ohm speakers, and 16 ohm speakers. Same problem, regardless of which set. I've also used two different sets of speaker wires. Finally, the only other thing that seems slightly strange is that it won't work if I put the receiver on the 4 ohm setting (only the 8 ohm setting). Also, even in the repair shop, when I had the guy hook up two sets of speakers and set it to play A and B, it stopped working after 3-7 seconds (sound fading out to nothing). Please help.
  • Anonymous Mar 26, 2014
    THe Receiver was connected for two days to 6 Ohm Speakers while the 4-8 Ohm switch on the back of the receiver was set to 8 Ohm.
    It was used twice, for about 5 hours total. then, the next day, the sound was low and suddenly became loud, as i had the volume setting at about 40%. I just bought this unit
    and connected a pair of speakers to test it.
    Before buying, i checked that all, front, center and rear speakers had sound and it was right.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 65 Answers
I really want to tell u sony is the worst ever.....even my friend had the same probs........u just unplug the wires and buy a 2-4 feet wire of the same kind and attach it urself making the connections properly or just get it attached at any electric repair shop...........
Posted on Jul 12, 2009
Hello I have another question but this is containing my back up surround sound receiver til I can find a Sony receiver that I like. Ok this receiver is a AV receiver model ht-r420 onkyo surround sound...
Subwoofer sockets
The HTR-420 has only a single subwoofer output. It is the socket on the lower left corner. The other subwoofer socket is part of the multi-channel input.
Because of the age of the 420, it comes from a time when optical and coax connections were not so common and DVD players had 6x phono/RCA sockets to send out the surround signal in analogue format. The multichannel input is for sending a signal in to the amp, and not for getting a signal out. That's why the sub doesn't get a signal from that socket. Use the proper subwoofer out. That's what it is there for.
Speakers A+B
The 420 was designed to run Speakers A+B together if required. However, you must observe the minimum impedance loading if you connect up two sets of front speakers and run them simultaneously.
The minimum Impedance for each set of front speakers is 8 Ohms. If you're recycling old surround speakers from a Home-Theater-in-a-Box system, or the speakers have no labels for impedance on the backs then you can be fairly sure they are not 8 Ohm. That could be the problem.
Sep 09, 2014 | Audio Players & Recorders
Subwoofer
go to audio set up and configure the system for 5.1 or higher sound output.then only all the speakers ll work
Jan 03, 2008 | Yamaha RX-V640 6.1 Channels Receiver
Str-gx800es sony receiver problem- right channel speaker sound is 'static', low and distorted. I have checked checked all speaker and output/input source cable connections with no luck. All left channel...
If you have checked the speakers and wiring, the right channel has a audio driver or output problem, which explains the low volume, static, and distortion. A service technician will be required to fix the receiver so it will balance the left side.
Jan 10, 2011 | Sony STR-GX800ES Receiver
Right front channel not working
try to check balance adjustment if working.
Apr 16, 2010 | Sony STR-DE475 Receiver
No sound from front left channel
Try swapping the connectors for front-left and front-right (just swap right at the back of the amp)
After the swap, does the front-left speaker work, and now the front-right is dead? If so, then it's a problem in the amp.
If not, then the problem is in the wiring and/or the front-left speaker itself.
Post back here with your findings, and we'll troubleshoot whichever part of the system is broken.
Apr 08, 2010 | Onkyo TX-SR605 Receiver
SONY RCD-W100
Can you please update this with your connections. I assume that you are connecting the turntables to the mixer? Verify that the mixer is set to send out true stereo. What mixer are you using?
Note that most mixers "pan" all of the channels to the center sending out mono to the left and right. In most live shows, it makes no sense to send out true stereo. The left and right are for the speaker chains. In order to get true stereo out of the mixer, you wil need to pan the input channel for the left side all the way to the left and the input for the right channel to the right.
Dan
Mar 17, 2008 | Audio Players & Recorders
Lost instructions
The 'Subwoofer' output on your receiver is used to connect to a powered subwoofer with a built in amplifier. Your KLH speakers use what is called a 'passive' subwoofer, it gets its power from the receiver and then passes the higher frequencies to the left and right front speakers after taking out the low frequencies for the subwoofer. A speaker system with a passive subwoofer is good for casual listening, but a powered subwoofer is required for really hearing low frequencies and rumble in movies. The KLH speakers you have were highly rated in their time for their price. The four satellite speakers and center channel speaker have very good sound compared to the little 'midget' surround sound speakers most people buy today.
Here's how you hook them up:
- The left and right front channels from your receiver terminals should go to the terminals on the subwoofer marked 'From Amplifier'
- Your left and right front speakers are then connected to the subwoofer terminals marked 'To Speakers', they do not connect directly to your receiver.
- Your center speaker is connected to your receiver terminals marked 'Center'
- Your rear speakers are connected to your receiver terminals marked 'Surround'
That should get you up and running. If the bass isn't good enough with the passive subwoofer, you can get a decent powered subwoofer like the Velodyne VX-10 for about $150 and 'kick it up a notch'. Good luck and enjoy....
Jan 07, 2008 | KLH HT-9900 System
No speaker sound
check the 2 buttons under the source selector knob they are labeled A and B check to make sure both are not pressed in just the one you have your front speakers hooked up to
Sep 10, 2007 | JVC RX-770V Receiver
Both left and right speakers play audio for right speaker
I think you mean the left channel is out but when you use test tone, the sound comes from left and right channels through the right channel speaker. If this is case, the switching IC is malfuncting. Unit needs service
Mar 15, 2007 | Sony STR-DE545 Receiver
Distorted sound on all right channel inputs
yep but if your not a tech you should take this easy repair to a pro. Your problem is an open emitter resitor and happens when the units over driven or a speaker is bad for a while while it was working. if your a tech then check all of the emmitter resistors. also it could be a bad output device. Good Luck
May 27, 2006 | Yamaha RX-V496 Receiver
201 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
