Question about HP Compaq Presario CQ60-249US Notebook
My mobile phone's joystick not working properly !
I am having N91 with me. its joystick respond mine sideways direction but not responding the upward and downward motion. its volume keys also not working at all.
please guide why is it so ?
Cursor up and down did not move
Is it the directional buttons or the joystick that isn't responding, and does it not respond with everything or just certain games or menus? First thing you could try that would be the easiest is with the system off and the battery out put some rubbing alcohol or windex into the buttons or joystick. Not a lot just enough to get it into and under the contacts. After doing this work the buttons a bit or spin the joystick around to try to loosen any dirt build up. Then use an air compressor or a can of air and spray the buttons or joystick to disperse the fluid so it can dry. Let it set for about a half an hour or longer to dry and give it a try. If this doesn't work you may have to take it apart to replace either the joystick or the directional pad strip. You can find easy tutorials on youtube for disassembling it.
Good luck and happy gaming!
William
Jan 25, 2011 | Sony PSP (Piano Black)
Its touch screen doesnt work properly.
It is a problem in this set... after some time, your screen will stop responding at all... there is one solution I found on the internet...
just follow this link
http://www.handcellphone.com/mobile/forum/screen-freeze
mine is working now
But try it at your own risk
Mar 24, 2010 | Samsung U900 Soul Cellular Phone
N91 keypad doesn't work
hey there, please flash your cell or take it to a cell repair shop and they will do it for you no need for screw drivers only cable for that prob.
Aug 31, 2009 | Nokia N91 Cellular Phone
The only solution for that problem is to send your phone to your Local Nokia Service Centre.
My nokia n91 8gb's joystick doesn't scroll upwards and downwards while it does sideways. also the call button(green) does not work
You need to get it repaired from a Nokia Service Center near your. This is a hardware issue.
Regards,
Waqar
Aug 03, 2009 | Nokia N91 Cellular Phone
My sony erricson k750i phone's joystick is not responding
you have to clean the joystick by using contact cleaner. open the cover of joy stick, there is a switch inside it having a metallic cover. use contact cleaner and let it for few minutes.
DONT FORGET TO REMOVE LCD FIRST. it can be damage with contact cleaner. i had a bad experience of it.
btw it happens with sony ericsson phone joystick problem.if joystick problem still persist u have to show it to sony ericsson repair centre or your warranty center of mobile.and u can also use the keys your keypad keys for up down left right.
thankyou.
May 06, 2009 | Sony Ericsson K510i Cellular Phone
My phone fell in water and the joystick no more respond to stimulus, the * key, 0 key and the c key. what can i do to solve this problem
my phone fell in water and the joystick no more respond to stimulus, the * key, 0 key and the c key. what can i do to solve this problem
Oct 22, 2008 | Sony Ericsson K320i Cellular Phone
Directional stick is unresponsive
your joystic was damaged, you nedd to replace it
Jun 16, 2008 | Sony Ericsson K750i Cellular Phone
Nokia 6600 joystick (to the left) not working
I HAD THE SAME PROBLEM WITH MY NOKIA 6620 FOR 3 DAYS. AND I OPEN THE PHONE AND PLAY WITH THE JOYSTICK AND IT STARTED WORKING. TRY THAT...
Sep 10, 2007 | Nokia 6600
Open Questions:
hp presario cq60 connects to network but not to internet hp presario cq60 connects to networkb but not to internet. I replaced the wifi card. I've tried to connect to hot spots and to wireless routers. I can connect to them, but no internet. Says Local Only. I have tried the following... 1- Click Start, then type ncpa.cpl and press Enter 2- The "Network Connections" window will show up 3- Right click Wireless Network Connection and select Properties 4- Click the Networking tab. Click Internet Protocol Version 4 TCP/Ipv4 and then click Properties 5- Select "Obtain an IP address automatically" 6- Make sure also that "Obtain DNS server address automatically" is selected 7- Click OK Then please follow the steps below also: 1- Open Internet Explorer (even if you use another browser) 2- On Internet Explorer click Tools, then click "Internet Options" 3- Click Connections 4- Click "Lan Settings" 5- Make sure "Automatically detect settings" is SELECTED 6- Make sure "Use automatic configuration script" is UNCHECKED 7- Make sure "Use a proxy server......" is UNCHECKED 8- Click OK 9- Click Apply then Click OK I've also tried...1- Click Start, then Control Panel 2- Now click "Network and Internet" 3- Then click "Network and Sharing Center" 4- And then click "Manage network connections" on the left 5- Right click "Wireless Network Connection" and select Properties 6- Click the Networking tab. Click Internet Protocol Version 4 TCP/Ipv4 and then click Properties 7- Select "Use the following DNS server addresses:" and enter the following 8.8.8.8 8.8.4.4 (remove the old ones if you have it) 8- Click OK and wait 60 seconds or so. I've also tried... Please click on Start->All Programs->Accessories, then right-click on Command Prompt and click on Run as administrator. Then type: netsh winsock reset , and press Enter. ipconfig /release , and press Enter. ipconfig /flushdns , and press Enter. netsh int ip reset netshlog.txt , and press Enter. Then restart the computer and check. Nothing has worked. Still allows me to connect to a wireless modem or a hot spot but not to the internet. It displays "Access: Local Only". I've tried other laptops and they allow internet access using the same wireless modem or hot spot. Yet, as I stated before, When I was in the hospital, I could connect to their wi-fi and get internet access. I also can connect this laptop to an ethernet cable and connect to the internet.
Nov 16, 2011 | HP Compaq Presario CQ60-249US Notebook
See all HP Compaq Presario CQ60-249US Notebook Questions
HP Compaq Presario CQ60-249US Notebook Logo
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
