fuel pump going out and it will not run at all
coil problem will starteasy but fail after running for a while
fuel pump relay again it is running after starting and if the relay is no good , it will not pump fuel
try having the fault codes read first then have the faulty sensor replaced
There are MANY things that can cause this type problem...
BUT, If the cause of your problem is no fuel getting to the engine, and you've check the fuel pump (not just the relay, you need to make sure the pump is ACTUALLY pumping fuel), try checking the fuel filter?
DISCONNECT YOUR BATTERY AND RECONNECT, THIS SHOULD RESET THE BRAIN.
ALSO...WHEN YOU TURN THE KEY, LISTEN TO HEAR IF YOU CAN HEAR THE FUEL PUMP COME ON...IF NOT, GUESS WHAT? HOPEFULLY NOT!... BUT,YOU MAY NEED TO REPLACE THE FUEL PUMP, IF YOU CAN'T HEAR IT WHEN YOU TURN THE KEY, AFTER YOU'VE RESET THE BATTERY!
