Problem w/new Acer X203h 20" LCD Monitor
I have a similar problem. I just bought an Acer X203h LCD Monitor today and came home to to try to connect it to my Macbook laptop, using a
DVI - to - VGA Cable and a Mini DVI - to - DVI Adapter. I also hooked everything to have the monitor give me a "no signal" and to turn and stay orange. Help? Anyone? Thanks!
PhxBird
  • 15 Answers
SOURCE: no signal
Weegee, Unfortunately you are trying to mix two different video types: VGA is an analog video interface found on most computers (except for latest with flat panel monitors, which are usually DVI). Your TV DVI interface is digital (although there is a DVI-A, which is an anlog DVI interface, it is unlikely that your TV has this). So, what you are trying to do probably won't work. I assume your computer does not have DVI output (otherwise you wouldn't have bought the adapter), but some monitors have VGA inputs; does yours? What kind of DVI adapter did you get? Is a DVI-A? Check out http://en.wikipedia.org/wiki/Dvi for info on DVI interfaces.
Posted on May 12, 2007
  • 13433 Answers
SOURCE: Visco LCD TV VSC-32V3 32
Which one is your problem the one on BOLD or the one on normal text?
You have to enable to 2nd screen, is there another computer available to you where you could try this lcd?
Posted on May 20, 2008
SOURCE: Insignia LCD TV won't recognize computer input...
Heres the dealyo.
Click start button
Click control panel
Click display
Click settings
adjust screen resolution (probably have to go down) until the tv displays your computer
if this did not work, you will have to adjust bit rate from 32 to 16. Fiddle with the settings until the magic happens.
You will not get any sound unless you use an audio jack plugged into t.v.
Im here all week
Posted on Oct 27, 2008
ehsan_bba
  • 112 Answers
SOURCE: No Display from new Acer Desktop AX1700
check all power cable. check vga cable,
Posted on Jan 26, 2009
SOURCE: Have a new Acer LCD monitor -- will not power on.
I checked all cords connecting the monitor to the computer, made sure nothing was loose.  Then I re-booted the computer, and the monitor is on.
Posted on Apr 11, 2009
How to set Acer x203h monitor to 6500K
Get the manual for the monitor so you can be guided accordingly. They have that info in them.
Aug 24, 2017 | Acer X203H Monitor
I have a cable not connected message on my screen even though I have all cables connected. I have a Acer X203H.
You might have a bad video card. Most of the new computers come with an "integrated" video card, meaning most of the components are 1 piece.
If you have another cable, try that, same with another monitor. Then if you are able, purchase a video card and test to see if that fixes the problem.
And if you have a warranty, this should be covered.
May 02, 2011 | Acer X203H bd Monitor
My monitor is an Acer 20". model # X203H I am using a MSI MEGA computer which has a VGA connection. My Acer monitor has two connections aVGA and DVI , I am using the VGA connection from the ACER Monitor...
There is both an analog and digital setting on your monitor settings. Bring up the monitor settings and toggle between the digital and analog settings until you get a signal.
Sep 13, 2010 | Acer Computers & Internet
I have an acer x203h monitor. it has horizontal lines going up and down the monitor constantly.
Your LCD panel is going bad and it will get worst, it is due to the TFT (Thin Film Transistor) driving circuits are bad, it is part of the LCD panel assembly.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Sep 10, 2010 | Acer X203H bd Monitor
How can I adjust the aspect ratio on an acer monitor x203h,so a circle looks like a circle and not an ellipse ? qtom@bellsouth.net
Usually under the menu function there is an aspect ratio adjustment. At that point you're going to end up with an 18.5" monitor with black letter box on each side.
May 22, 2010 | Acer AL2016W 20" LCD Monitor
Acer x203h monitor picture goes blank after about 5 seconds... turn off and back on same result...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
May 20, 2010 | Acer AL1711 17" LCD Monitor
I have a new Acer X203H 20" wide computer monitor. All of my photos are streched wide, and everyone looks fat. Can I adjust this ?
You need to set the PC video resolution to 1600 x 900 for proper 16:9 wide screen format. But if your pictures that you taken with your camera were not 16:9, IE 4 X 5 then it will be stretched side way to fill the screen.
Jan 07, 2010 | Acer X203H bd Monitor
I can connect my new acer X203H LCD monitor to computer
Open your cpu cabinet.
Refix RAM memory .
Pull cmos cell from motherbord for 10 minutes.
Pull processor fan and processor then refix both clean dust from all parts.
Remove pci cards from pci slot then check.
Let me know if you need more assistance.
Thanks.
Oct 02, 2009 | Acer X203H bd Monitor
Apr 10, 2009 | Acer Computers & Internet
Computers & Internet Logo
564 people viewed this question
Alun Cox
k24674
