I have creek 5350SE amplifer that both left channel A and B is not working. When I turn off the volume, I can still hear a very weak signal from the left speaker. When I turn on the volume, it remain the same.
It's the ribbon cable that is likely at fault. There are actually three computer type ribbon cables in the amp. I believe the cable that is responsible for the drop-out of a channel is the widest (longest) of the three, but you really need a tech to look at it and replace the cable. But please note that the new cable may also have defects in manufacture and that it may take some time to order a new cable from Creek. I had a tech solve the problem permanently by removing all three ribbon cables and then hard-wiring the connections together - that is to say, point-to-point wiring. My cost was about $250, but as you can imagine, there is extensive labor involved. Good luck!
Soundcraftsmen A5002: When turned on the ''Protect'' light comes on and stays on, the ''Truclip''...
(More)
Soundcraftsmen A5002: When turned on the ''Protect'' light comes on and stays on, the ''Truclip'' lights come on one at a time, either once or twice before alternating, no sound. There is a clicking sound as lights switch.
I have a creek destiny integrated amp left channel does not work and smell like a some transistor...
(More)
I have a creek destiny integrated amp left channel does not work and smell like a some transistor explode when i change the fuse happens again would you help me. thank you very much
I have a Uniden cordless phone system with base unit and two cordless handsets for two years. Today...
(More)
I have a Uniden cordless phone system with base unit and two cordless handsets for two years. Today I found no light on display, no connection at all for these three pieces. I checked the phone line is working fine with old phone. So the problem is the phone itself. Is it something burned out inside the machine? Plese give me ideas. Thank you Jenny
