Question about i-mate JAQ Pocket PC
Vibrate not working how can down load my system
    Guru:
  • 832 Answers
Hi thanks for using fixya!
Try to do a hard reset for your Imate JAQ, but before you do this, you have to make a back-up of all your important files so that you can easily retrieve it.
If you need further assistance, let me know!
Posted on Jul 12, 2009
2000 Dodge Dakota vibration while driving
sound like the u-joints in the driveshaft. Lay under the truck and where the u-joints are try moving the driveshaft up and down. If it moves then the u-joints are bed. This will cause a tremendous vibration under a load and the faster it spins it will smooth out.
Dec 05, 2009 | 2000 Dodge Dakota Quad Cab
Excessive drum vibration
Yes, look into trading in the Kenmore for one of only two manufacturers that employ a dynamic balance system built into the washer drum. Samsung and LG both use this dynamic balance system that balances the load while it is in motion. They also use a vibration sensing system to modify the time and speed of the spin cycles to minimize any vibration that might still be present. LG has this available on only their upper level models while Samsung's VRT is available on most all models. I believe that both of these manufacturer's are available from Sears.
Oct 03, 2009 | Kenmore 43142 Front Load Washer
Washing machine vibrates bad in spin cycle
dont put full load please check it with half load or add water excess
Sep 15, 2009 | Kenmore HE2 Plus Front Load Washer
Our front load washer vibrates so much durning the spin cycle it actually knocks the dryer off the top of it. It will also vibrate across the floor unless 2 people are holding it down. We have tried the...
make sure that the nut on the leg is tihgtend down. check level lower on wash machine if all else fails buy shake away pads follow the install directions and see if that helps. i love my shake aways my floor doesnt vibrate any more.
Jul 09, 2009 | General Electric WSSH300G Front Load...
Washing machine has a seizure during the spin cycle.
Try leveling the washer so that it is about half a bubble biased towards the rear. This usually helps front loading washers balance properly even if the installation instructions say that it should be perfectly level. This can also aid draining problems.
Also, some newer front loading washing machines are simply prone to dramatic vibration even when they is "anti-vibration" or "vibration reduction" systems. You can never go wrong installing an anti-vibration pad under the washer. Good Vibrations Inc, Kellett Enterprises and The Vibration Solution all have good products. The Vibration Solution seems to have figured out the best solution and offers excellent support and return policies.
Washer anti-vibration pads
If all else fails call the retailer and ask for an exchange.
Jun 05, 2009 | Frigidaire ATF6000ES Front Load Washer
Excessive vibration
hi! make sure the machines shock absorbers are ok and that the ballast block is intact and ancored down.
Dec 20, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Car will go dead while driving then restart.has a code in computer for crankshaft position sensor
Mine (quest) would do this at 80 miles per hour with loaded car. Since I keep it at 72, it has not reoccurred. I suggest that the sensor is working fine. There is just a slight engineering problem with my engine that does not produce heat/vibration beyond the calibration of my sensor, as long as I keep the speed down. Fewer traffic tickets also.
Jul 30, 2008 | 2004 Nissan Quest
Hello
I have the same above problem VIBRATION OPTION IS NOT FOUND IN S3 please solve my problem also. Also my S3 Sigmatel have not Internet browser can I down load it ..? if yes please advice me, From where..?
Jul 14, 2008 | Handmark Software MobileLists (950142) for...
80 Series top loader excessive vibration and noise on spin
check the screw feet, on the front corners, one may be not screwed down far enough to be 'tight' to the floor allowing a small movement that makes a lot of noise, halting under pressure suggests this is the case
May 26, 2008 | Kenmore 24032\24036 Top Load Washer
i-mate JAQ Pocket PC Logo
Top i-mate Computers & Internet Experts
Peter Dragonetti
Mohamed Ismail
Mohamed Ismail
Are you an i-mate Computer and Internet Expert? Answer questions, earn points and help others
