Question about JVC GR-D20EK Camcorder
JVC Camcorder - used wrong power lead to charge battery
I used the wrong power cable to charge the battery and it would not charge, I then found the correct power cord and still nothing happening. The correct lead has a current adapter near the end of the cable, whereas the wrong one I used didn't.
I think I may have blown the circuit on the power supply, is there an easy fix, spare part I can get and replace without paying £100 to have it done??
Peter
  • 156 Answers
There is a circuite protector near by the connector which is coming from the battery to mainboard.Just replace the same.
Posted on Jan 01, 2008
I have a new replacement battery, yet when plugged into AC power is not charging...HELP!!!!
Are you waiting at least 5 minutes before you think you have a problem. A new battery will have resistance to its first charge then it will start charging, that is of course providing there is nothing wrong with the charge part of the motherboard.
Jun 20, 2011 | Dell Vostro 1500 Notebook
What to do when the battery wont charge on my DVD player. Its plugged into the correct cords and outlets, the light is on indicating charging. When I take out the cords and go to play nothing happens. ...
sounds like your battery is faulty return the dvd to where you bought it ask for refund or replacement or you could by a replacement battery of ebay but personally i'd return it
Jul 09, 2010 | Televison & Video
Battery will not charge, I've used the usb cord, plugged in and left to charge, but nothing happens. What am I doing wrong???
you must use the battery pack charger;/ it will never charge by the usb connection;; it's only for the picture transfer......
hope that help you
have a nice day...
Apr 13, 2010 | Cameras
They sell external battery chargers for these for around 10 bucks at Amazon. Just pop the battery in the charger. Beware the battery itself can be worn down or dead. It also has protection circuits right inside the battery that can be blown (maybe a small fuse too). A new high capacity battery (3 times the recording time) is also at Amazon for around $25.
Mar 31, 2017 | JVC Everio GZ-MG130 Camcorder
Hp laptop 9720us screen wont brighten or dim. last week my screen went blank brought it to a shop they changed the inverter and also some cable connection . works fine just not quite as bright as before ....
You got the wrong inverter fitted - i'm sure your unit requires a sinle lamp inverter and they have cheated - putting in a generic lamp inverter and branching togeather the wires to accomodate the single plug thus reducing the available volatage for the lamps - this is why it's dim - correct part is 431391-001 Display panel power inverter - For use with single lamp display panel
Mar 10, 2009 | HP Pavilion DV9720US Notebook
Laptop turns off intantly, when I unplug the charging cord
For those of you having the problem of a HP laptop shutting off when you unplug the charger and your battery is fully charged, I can help you. There is nothing wrong with the laptop, battery, or computer, it is a power management setting. If you go to display properties, select the screen saver tab, then click the "power" button, in the power schemes field is a drop down window, click on it and select "Rixane Power Scheme", it is a power switching utility that quickly switches between AC and Battery when the power cable/charger is plugged in or unplugged while the laptop is on. If you have it set to "always on" it will shut off when you pull the power cord, even if the battery is charged. This will also happen on many non-HP laptops, if you don't have a HP laptop or there is not a "Rixane" option available, select the "Portable/Laptop" power scheme. Hope this helps!
Dec 27, 2008 | HP Pavilion dv9000z Notebook
Powers on immediately powers off
ok well there is somwhere to start i would see if you can get it to take a charge ok and if it does than try to start it without the ac power on and see what it does if it wont take a charge your battery may be bad or your charging circuit may not be connected correctly ok lrt me know best regards mike
Aug 27, 2008 | Dell Inspiron 5160 Notebook
IPAQ Not Charging from AC Outlet
If you are not using the original chargers it could be the type of charging cable. Not all cables that fit will charge the device correctly.
Aug 10, 2007 | HP iPAQ hw6515 Pocket PC
Power cord and battery's support NO power to Video Camera
This incident happens often and damages the camcorder's power board. Replacing power board and some adjustment should resolved the problem. Your cost may run from $175-$225 in US for this model. Whenever you are transfering and connecting to pc, it is recommended to connect AC adapter power for this. Do not rely on a charged battery. Good luck.
Mar 17, 2007 | Canon Optura 50 Mini DV Digital Camcorder
JVC GR-D20EK Camcorder Logo
317 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
