Question about Kirby Ultimate G Bagged Upright Vacuum
The brush isn't spinning
When the vaccum is switched on the brush dosen't spin
  • 701 Answers
The belt is broken. You can get a replacement for that model here:
http://www.vacbelts.com/kirby-301291-belt.htm
Posted on Oct 22, 2009
    President:
  • 778 Answers
The belt has come of or broken. The link below is to a You Tube video on how to replace/connect the belt. Good luck.
http://www.youtube.com/watch?v=At7tqnjD-Kc
Posted on Jul 12, 2009
The belt is broke. you can buy a new one for around 5-10 dollars at target or walmart, or loews or homedepot.take the screws of the bottom panel to expose belt. you will have to pull out the beater bar to replace the belt. just pull on it after the bottom plate is removed the beater bar just slides out. slide the new belt down the beater bar then pull the belt over the spinning pin. now stretch the beater back to its original position it should slide right in. replace the bottom plate and your back in business
  • 641 Answers
SOURCE: brushes won't spin
open unit's bottem cover and look for the following: - Motor works - Belt which transfer motor's movment to the brushes, in place and not broken (most frequent phenomenon). - No mess on brushes axis which prevent their free movement. Good luck
Posted on Jul 16, 2007
SOURCE: Brushes on My Hoover Steam cleaner will not spin
We had same problem,Had to have bearings replaced at hoover store/service center. If you bought it within the last year it is under warranty and you wont be charged.
Posted on Nov 25, 2008
SOURCE: the vaccum turns on but the brushes dont spin
vacuum turns on and sucks but the brush does not spin and I have pushed the reset button
Posted on Mar 20, 2009
  • 39 Answers
SOURCE: bottom on the vaccum the spin brush will not spin at all
Double check for anything that might be holding it from spinning (shoe lace, string, hair, ribbon, etc)
If the brushes are free to move by hand, you most likely have either a broken belt or a belt that simply came off the motor. What you'll need to do in either case, is open up the vacuum cover. The screws are usually located at the bottom of the vacuum (where the brushes are) and remove all the visible screws you see.
Most of the time (being that I don't know what kind of vac you have, that is enough to remove the top cover off for you to inspect either the motor or the belt which attaches to the motor. I know on my hoover, the belt slips off very easily, so I always need to keep my screwdriver handy to perform this.
Hope this helps.
Posted on Apr 19, 2009
SOURCE: Hoover Empower Widepath, brush won't spin.
The belt needs to be changed, it's probably spinning in place which is causing the smell (burnt rubber).
Posted on Nov 20, 2009
Why is my Shark nv500 vaccum carpet brush is not spinning?
I am having the same issue. The brush won't even move when I turn it with my hand. I just posted this same question.
Aug 01, 2014 | Shark Rotator Professional Lift-Away...
Why beter bar dosent spin while in the vaccum mode only in up right position ?
Hello! The air pressure from the motor is most likely spinning the brushes in the upright position. This vacuum has a brush-roll on/off pedal located on the left side of the cleaner. To activate the brushes, power the vacuum on, recline the handle and then press the brush-roll on/off pedal. The brushes should begin to spin. If they do not the belt may need to be replaced. Hope this helps!
Jul 12, 2014 | Hoover Vacuums
I cant get my hoover vaccum brush to spin
First be sure the switch/circuit breaker on top of the nozzle is on. The brush also will not turn unless the handle is released and tilted back. This model of Hoover has a gear drive to turn the brushes. This was VERY prone to problems, and Hoover discontinued making replacement parts for it several years ago.
Mar 18, 2011 | Hoover U8147-900 WindTunnel V2 Bagless...
The spinning brushes on the vaccum no longer spin, how can i fix this? The vaccum picked up a very small wire from a video game and i turned it off immediately. I unwound the wire but the brushes no...
You have either broken the belt or more likely the clutch easiest is to replace cleaner head assembly £75ish or call Dyson and arrange a service if you're not DIY inclined but check belt !st
Oct 31, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
The main brush will not spin
I would guess the belt is broken. That happens often. Get a correct belt. Remove the brush roller. Wrap the belt around the roller and drive peg. Reasemble -- easier said than done, but keep trying.
Sep 27, 2009 | Dyson DC15 All Floors - The Ball Bagless...
Beaters stop when vaccuming rug...didn't when new
I believe you need to change the belt that drives the brushes. When it gets stretched out, it will just spin on the axle of the motor or spin on the brush and smoke.
Jim
Jun 01, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
The vaccum turns on but the brushes dont spin, and i have hit the reset button on it already...
Mar 20, 2009 | Dyson Slim DC18 All Floors HEPA Bagless...
Dec 04, 2008 | Sandia Plastics Super Hipster Power Hepa...
Nov 24, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Kirby Ultimate G Bagged Upright Vacuum Logo
460 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
