Question about Acer AL1916W 19" LCD Monitor
Acer lcd monitor ''no signal''
Well my computer was originally windows vista, but after it crashed once and i sent it for repair, it came back with this ''windows vista not genuine'' problem. I always clicked ''activate later'' for the past few weeks and it was fine. But today when I tried to switch the computer on, my Acer monitor showed the acer logo followed by a ''no signal'' message and finally a blank screen. The CPU began to make the same noises as it usually did when it starts up (i.e. fan turns on & makes a humming noise).
so i'm wondering, is it just my monitor that's not working, or has Windows prevented my computer from starting up because the version is not genuine? Is there any way to fix it?
Thanks in advance! :)
  • 2 more comments
  • sh4d0ws0ul Jul 12, 2009
    erm but if i can't see anything how to i reset the screen resolution?
    oh and the keyboard isn't lighted up as well (i.e. no power)so could it be the CPU which is the problem?
    President:
  • 1,383 Answers
It is screen resolution problem.
when you power up the computer press F8 key thene nter in enable vga mode then go to diaply property and set screnn resolution to 1024*768 thenh apply and ok.
Posted on Jul 12, 2009
  • kishor
    kishor Jul 13, 2009
    check your smps is working or not?
    Refix RAM memory aslo pull cmos cell from motherbord for 15 minutes so all settings are reset to defaults.
I have ac Acer S202HL LCd monitor. When I booted up one day it didnt come on.
first check with your both power supply out put is coming 19 Volts dc.
if its not coming check with multi meter primary and secondary of your adopter continuity.if no continuity replace with proper working adopter.
Nov 07, 2013 | Acer S202HL LCD Monitor
No signal from computer after Windows XP loading screen comes up: when I turn the computer on, there's video signal to the monitor, but once it gets to Windows loading, it stops and goes black.
Does it do the same when you bootup in safe mode (hit f8 key while booting up)? if it is OK in safe mode, then it is software problem, not hardware.
Post back what you find.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Oct 27, 2010 | Acer X233H 23" Monitor
Input not Supported
The signal being sent is outside of the rated limits of the monitor (vertical or horizontal synch rates). Boot up in safe mode (by hitting F8 during the initial startup of the computer, before the windows logo screen comes up). Select Safe Mode. If you get a display in this mode, then you know your graphics card is sending a signal outside of the monitors limits, if not, then the monitor itself is probably bad. NOTE: The following steps are for Windows XP only... if you have a different OS, please reply and I'll research the steps for you.
If it is your graphics card, while in safe mode, right click on My Computer and choose Properties. Click on the Hardware tab. Click on Device Manager and double click the Display Adapter entry. Right click on your graphics card and click uninstall. This will force the computer to reinstall the graphics drivers at bootup and, hopefully, reset the adapters output mode. Reboot the system and once in, set your display settings to the best for your monitor (Windows XP should pick the best setting if the monitor is plug and play).
Feb 19, 2010 | Acer 22" X223w LCD Monitor
Acer laptop stuck on Aspire screen
i/run operatin disk take prompt comman and type chkdsk/rr 2-3 times it can be repair your system 2/ repair by operating disk if not work by two methode reinstal operating system.
Oct 14, 2009 | Acer Aspire 5500 5570-2609 Laptop
"No signal" msg on new Acer X193W LCD Monitor with Vista 64-bit
this should be easy...go to your desktop...right click on it and choose "personalize" it will open up a window. on the bottom it will say display settings...click on it...at the top right it should say "identify monitors" click on that...if that dosent work.click on the monitor that has a 2 on it and it will ask you if you want to add a monitor...it should work
if not, post a comment and i will check back with you
Jun 21, 2009 | Acer X193W LCD Monitor
After loading windows Vista screen says no signal
steve, i dont think there is any problem with monitor. restart ur pc in safe mode, change resolution to 1440X900.
Mar 02, 2009 | Acer AL1916W 19" LCD Monitor
How will my brand new monitor work with windows vista?
Hi , The reason monitor does not sync , You need to reduce the resolution and then connect the Acer monitor and then adjust the display according to your requirement.
Jan 11, 2009 | Acer 19" LCD Monitor
Acer monitor lcd problem
Try the monitor with another known working computer, If ng there also, then have unit repaired under Acer warranty.
Aug 31, 2017 | Acer Professional P211 21" CRT Monitor
No driver appearing in Vista
Sorry this is late but:
Unplug the monitor from the PC and then boot.
after you hear the windows starting sound wait for it to load everything up (say 1 min) and plug in the monitor
Windows then plays the "i have found an unknown device" sound and begins to search for drivers
Wait 5 min for it to do this and then shut down the computer with the power button.
Re boot
Monitor should work.
Note: you must be connected to the net for this to work.
- Adyhood
Dec 14, 2007 | Acer AL2017 20" LCD Monitor
Monitor repeatedly flashes Acer logo and computer display in cycles
We had the same problem with the 17" we bought in Aug. Sent it back for repair. Acer sent it back without fixing the problem. Started doing it again in Nov. This time I called a supervisor and they sent me a new monitor. Well yesterday it started doing the same thing. You can fix it temp buy unplugging it and holding down the on-off switch for 30 seconds. Please let me know if you have a better fix.
Dec 13, 2007 | Acer AL1715 (Black, Silver) 17" LCD...
Acer AL1916W 19" LCD Monitor Logo
2,892 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
