Question about Dell Inspiron 15 3521 15.6" Laptop Computer - Black Matte with Textured Finish; Intel i5-3317U; Microsoft Windows 8 Home; 6GB DDR3-1600 RAM; 750GB 5,400RPM Hard Drive; Intel HD Graphics; 8x DVDRW Drive; 8-in-1 Memory Card Reader; 1703 802.11b/g/n Wireless
Why does it power on with no video and makes a clicking or a beeping sound?
IT POWERS ON ,NO PICTURE AND A CONSTANT CLICKING OR BEEPING SOUND.
SOURCE:
dragon_sun25
  • 107 Answers
SOURCE: no video and loud beeping sounds
Try a different stick of ram if avalible and open the case If i remember there should be 4 lights in there and If i remember that mean memory not reconized or being properly used
Posted on Dec 09, 2008
ginko
  • 19396 Answers
SOURCE: the lamp indicator turns on
The clicking noise is the protection switch that keep shutting down the unit. This happens when an internal fault had been detected.
Do the following:
Unplug the unit from power for some time.
Remove the bulp and refit it in place.
Restart the unit.
If still in protect mode (clicking , lamp light and no start), then there is a fault.
When the problem is the lamp, the lamp light will come on, but usually protection does not click.
Before buying a new lamp that is expensive, have the projector checked, testing with particular attention the high voltage board that will supply power to the lamp. That may be the fault.
If you have a replacement lamp in storage replace the lamp first.
Posted on Jul 20, 2009
jim4984
  • 797 Answers
SOURCE: when pushing the power button my computer makes a
This could be almost any fault but .... usually points to memory OR a bad power supply.
First thing I would check is the power supply. After that, if there is more than 1 stick of memory, try removing all but one. You may have to swap that one remaining one a couple of times (depending on how many sticks there are) as there is a 1 in x chance the one you leave in is the defective one.
Let me know how you make out.
Posted on Mar 12, 2010
  • 11 Answers
SOURCE: computer is making a clicking, and beeping noise
sounds like hard drive failure , but may be settings in cmos
Posted on Apr 22, 2010
mace1mace
  • 1138 Answers
SOURCE: high pitched beeping sound?
hi!
I'm not sure with your beep code.. but here is the list of known beep codes for dell motherboards
Beep codes Possible Causes Solution
1-2 no video card detected Reseat the video card
1-2-2-3 BIOS ROM checksum error
1-3-1-1 DRAM refresh error Reseat the memory card
1-3-1-3 Keyboard error Keyboard connector
1-3-3-1 memory card Reseat the memory card
1-3-4-1 RAM failure on line xxx Reseat the memory card
1-3-4-3 RAM failure on data bits Reseat the memory card
1-4-1-1 RAM failure on data bits Reseat the memory card
I hope it match your beep code..
Please rate this help.. thanks..
Posted on May 25, 2010
RCA ctc195 series won't power on constant small beeping sound
if its a high pitched squeek its a short in the deflection circuit, a common failure part here was the high voltage transformer.
Dec 11, 2012 | Televison & Video
Samsung 40inch TV DNIe DVB SRS TruSurroundXT (model:-LE4OTR73BD (R) s) -: power on but no picture or sound and makes a constant clicking sound.
hi the name is matt the problem i am having is the contrast and brightness constantly change by them self and it is near on impossible to see what you are watching was just wondering if there was anyway to sort that or whether im going to have to get a new tv be a big help thanks
Nov 15, 2012 | Televison & Video
On power up just get contant beeping won't boot
constant beeping sound is usually a key on the keyboard that is stuck. If it is not constant, like long,short,long beeps, that may indicate a problem. Let me know it is is constant or a beep code.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 23, 2010 | Acer Aspire 5315 Notebook
Constant beeping when powered up, no display
If the beeping is constant, check your keyboard for any keys that are stuck in the depressed position.
Jul 07, 2009 | Computers & Internet
Clicking sound coming from mother board
check your memory if the sound is continous beeping or your Video adapter. try to clean it and installed it again if problem occured use another memory or VGA for testing..
Jan 23, 2009 | Dell Dimension 2400 PC Desktop
Beeping Sound
Maybe the horizontal IC output are damaged need to be replaced
Nov 04, 2008 | RCA F36650 36" TV
No picture, no sound?!?!
This could be a number of things. Your lamp could be bad or it needs to be reseated to the ballast. The lamp is trying to light and it will make the ballast flicker (that is the clicking sound) or your ballast is bad and it needs replaced (it will flicker and click too). Or your color wheel is broken and it will make a clicking sound when turning. If the color wheel is not spinning or broken it will not light the lamp. No lamp no picture.
Dec 12, 2007 | Samsung PCN5425R 54" Rear Projection...
PC beeping, monitor will not display
we have different sound we can hear in cases of hardware problem, once the video card has loose contact it also beep continously, a beep sound also occurs when the ram(memory card) loose contact, one beep sound when it boot clearly it proceeds as go signal going to operating system. if you are using an upgraded video card remove temporarily and use the on-board from your motherboard. in case that it won't boot and still you hear a beep, beep ,sound then, switch-off the power take out the memory card clean the contact points(bronze color) with pencil eraser, make sure that no remaining residues of eraser remained before you install to the slot. i hope that this solves your problem
Dec 01, 2007 | Computers & Internet
Dell Inspiron 15 3521 15.6" Laptop Computer - Black Matte with Textured Finish; Intel i5-3317U; Microsoft Windows 8 Home; 6GB DDR3-1600 RAM; 750GB 5,400RPM Hard Drive; Intel HD Graphics; 8x DVDRW Drive; 8-in-1 Memory Card Reader; 1703 802.11b/g/n Wireless Logo
91 people viewed this question
Clive
Clive
Alun Cox
